Re: 800+ hp on e85
[Re: WHITEDART]
#1474543
07/26/13 09:39 PM
07/26/13 09:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I forget his name but he is on here... he built up a hemi that was 1050 hp and he was looking to make more.. that was on E-85.... what the heck are you saying about RPM... nope... well we will put it this way.. it works fine at 10,000 rpm
Re: 800+ hp on e85
[Re: Quicktree]
#1474545
07/26/13 09:45 PM
07/26/13 09:45 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
not really sure about the rpm limit just a rumor I have heard. im shooting for 800 hp with this small block which will need some rpm behind it.
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: 800+ hp on e85
[Re: WHITEDART]
#1474547
07/26/13 10:00 PM
07/26/13 10:00 PM
MR_P_BODY
what carb are you using MR P im looking at Quick fuel e85 1050 dominator
Same carb your looking at... you might want to go bigger.. as you said you need RPM and RPM takes air and fuel
Re: 800+ hp on e85
[Re: MR_P_BODY]
#1474548
07/26/13 10:30 PM
07/26/13 10:30 PM
WHITEDART
bean town ....Ca
how close was that carb out the box..and did they build it for your combo
Re: 800+ hp on e85
[Re: WHITEDART]
#1474550
07/26/13 11:09 PM
07/26/13 11:09 PM
MR_P_BODY
They built it for my engine specs... was almost dead on.. I ended up jetting up 2 jet sizes
Re: 800+ hp on e85
[Re: dusturbd340W5]
#1474552
07/26/13 11:44 PM
07/26/13 11:44 PM
MR_P_BODY
I believe that was DTHEMI maybe
Yes... thats who it was
Re: 800+ hp on e85
[Re: dizuster]
#1474557
07/27/13 04:29 PM
07/27/13 04:29 PM
Posts: 2,578 sweden
1Fast340
sweden
It's most definitely NOT only 105 octane either... maybe on a test stand, but not in real world applications.
Almost as good as 116 from what I've seen with the turbo guys...
Won't make as much power as Q16 though. Lots of guys making over 800hp with it.
when it comes to the turboguys the E85 has the advantage of cooling stuff aswell and i bet it does that part better than 116 therefore makeing E85 a good fuel for forced induction
back to the topic of 800HP N/A on the E85,yes it works and is more than just tried. there is streetcars running in the 8īs on that stuff.
Re: 800+ hp on e85
[Re: dizuster]
#1474558
07/27/13 04:56 PM
07/27/13 04:56 PM
Quicktree
says 105 octane on the pump, but what do they know?
