Re: red header tubes
[Re: boomerodell]
#147408
11/08/08 06:16 PM
11/08/08 06:16 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
if those tubes are glowing at idle, I would say too lean. you will need to remove the front carb to get to where you can remove the float bowl on the center carb. glowing like that I would jump 2 to maybe 4 jet sizes larger.
glowing while driving it could be a lean condition or to much timing. more info is needed..
I am truckless..
[Re: boomerodell]
#147409
11/08/08 06:16 PM
11/08/08 06:16 PM
RapidRobert
yes check timing but LEAN like my oxy/acet torch when I add oxygen
[Re: boomerodell]
#147412
11/08/08 06:32 PM
11/08/08 06:32 PM
RapidRobert
(retarded) timing. See what your initial is & that it is advancing. See that the fuel level is at the bottom of the sight plug on the center carb.
[Re: boomerodell]
#147415
11/08/08 07:38 PM
11/08/08 07:38 PM
RapidRobert
your initial is fine. run it up a bit & see how much you have at the point where its glowing red. EDIT note the timing & the rpm. & if that's close to good then we can move on to mixture but with that being said you did change the DIST & with a six pack I'm sure that it wasn't changed.
[Re: boomerodell]
#147417
11/08/08 08:12 PM
11/08/08 08:12 PM
RapidRobert
You run it up to ~ 1500-2000, what is the timing at that point. EDIT Am I reading this right that when you run it up it's still at 15?
[Re: goldmember]
#147421
11/09/08 12:02 AM
11/09/08 12:02 AM
Posts: 10,693 Surface of the Sun, AZ
Hotwheelsjr
Timings retarded or very rich mixture. Start with more timing advance,are you using vaccum advance? If not, you should.
Very 'lean' mixture -- a rich mixture would cool your exhaust from unburnt fuel.
[Re: goldmember]
#147424
11/09/08 12:18 AM
11/09/08 12:18 AM
Posts: 388 Southington, Ohio
dm69charger
Southington, Ohio
Not the case. If a cylinder is very lean it will misfire creating less exhaust heat. Very rich mixture will still be burning as in goes out the port creating alot of heat. Advance the timing lean the rich cylinders and the problem is cured.
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: dm69charger]
#147425
11/09/08 02:18 AM
11/09/08 02:18 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
but, don't forget, if it's not timing, lean enough to still burn without a misfire, will also burn hot.
so...could be lean, could be rich, could be timing.
**Photobucket sucks**
