Re: does buildsheet show if a 22" rad car gets a shroud
[Re: TONY_DAGOSTINO]
#1474024
07/26/13 11:19 AM
07/26/13 11:19 AM
Posts: 705 Morningside, Long Island
scatcity
hi all
as far as my original question, I would think the same would apply from B to E body.
to be exact it is a 70 e-body with a 440 and a 2998960 radiator, with a #224 fan + a 1.6" spacer.
let me ask this question, is there anywhere on a buildsheet that has a box or place to list if the vehicle would use a shroud?
thanks again tony
NO-again..
[Re: moparfan53]
#1474026
07/26/13 12:11 PM
07/26/13 12:11 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Soooo...
No on the BS callout
Yes on the 22" rad in this application
Yes on the shroud in this application.
...that about cover it?
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1474027
07/26/13 12:57 PM
07/26/13 12:57 PM
Posts: 17,529 Las Vegas, NV
6bblgt
Las Vegas, NV
Soooo...
YES
#1474029
07/26/13 01:03 PM
07/26/13 01:03 PM
6bblgt
Las Vegas, NV
so, with no callout on the BS, then how do you know which B+E body 383-440 22" radiator applications cars use the shroud?
With the exception of a few "typos" on the FSM Barracuda page posted above .....
HP engine'd e-bodies w/22" radiators received a shroud.
[Re: 6bblgt]
#1474031
07/26/13 01:57 PM
07/26/13 01:57 PM
scatcity
Is this regardless of SPD's and LA vs.Hamtramck and Exports ?
[Re: m46rat]
#1474032
07/26/13 02:09 PM
07/26/13 02:09 PM
6bblgt
Las Vegas, NV
ALL B and E Body cars with any 22" rad. will have a shroud on the rad. I have three 70 22" rad cars(including a 440+6 car and a 383+2 car) and two 71 22" rad cars which all come with shrouds. Bob from Glen Ray should chime in and clear all this up.
The Charger/Coronet/Belvedere/Fury version of the Barracuda FSM section 7-11 Specs. posted above all show the same info (although the "960" radiator is listed correctly as a 22" radiator under 440).
383 2bbl without A/C received the 22" radiator & no shroud. & any non-HP 383 4-bbl without A/C received the 22" radiator & no shroud.
The non-HP 383 4bbl (330hp) is the blue painted Carter AVS carb'd engines available in Satellite/Coronet 500/Gran Coupe/Challenger SE/Sport Fury/etc.
Dwight, what evidence do you have that the above mentioned non-HP cars would/should receive a fan shroud?
[Re: m46rat]
#1474033
07/26/13 02:17 PM
07/26/13 02:17 PM
scatcity
Contrary to the above LP engines as well ??
[Re: scatcity]
#1474034
07/26/13 02:26 PM
07/26/13 02:26 PM
6bblgt
Las Vegas, NV
Yes, the FSM shows no deviation based on where the car was assembled or where it was shipped to.
#1474036
07/27/13 02:26 AM
07/27/13 02:26 AM
I'll have to check the build sheet on our 70 challenger and see what it says for the shroud section. I would imagine that this is an early built car as well? I can't see why they wouldn't have listed it on the build sheet as they list a choke number on the build sheet and other smaller detailed stuff on there also.
Maybe Lynn can chime in with info pertaining to what is on the build sheet or what came on early promo cars?
[Re: 6bblgt]
#1474038
07/27/13 03:02 AM
07/27/13 03:02 AM
sometimes early cars got things that later build cars didnt and vice versa. Our 70 chally has a black steering column and carpeting while the rest of the interior is red. Typical of early build cars.
Either way there is factory proof if it would or wouldn't have a shroud by means of the service manual. Or they could just talk to the prior owner of the car and see what it had on it at the time the prior / current owner had it.
[Re: krisiesmopes]
#1474039
07/27/13 07:41 AM
07/27/13 07:41 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
So, my guess is that as a possibility, they ran out of some rads on the line. Shift supervisor ok'd a replacement, and those were used. It was noted, and made it into the final version of the parts book.
FYI, my GTX was built third week of October 1969 so Mopar was already slapping 22" radiators in 440 cars. Looking at the radiator list link provided above it shows the same thing in '68 and '69.
[Re: 6bblgt]
#1474040
07/27/13 07:07 PM
07/27/13 07:07 PM
Posts: 628 Mass
Mike Mancini
Mass
What does early and/or promo cars have to do with the subject?
Absolutely nothing...considering all the challenger promo cars were 440-6, 4-SPEED, 26" RADIATOR cars!
[Re: Mike Mancini]
#1474041
07/27/13 09:48 PM
07/27/13 09:48 PM
Mike,
I am sure that you know this already but when it comes to Mopars.... never say never. I came across an early hemi charger that was the press release car and that had a lot of 68 parts on it and stuff that it should not have had.
As with this charger, I am sure that there are other cars out there that were supposed to get one thing that it didn't for certain reasons. I know our 69 GTX vert is supposed to have a white stripe on it as per the fender tag. Talking to the third owner who had the car in all original state, it came from the factory with a red stripe. My charger was supposed to have the metal tabs that hold the engine harness onto the fire wall. The indicator is there and the nub where the tack weld should have been but no evidence of it ever having them installed. Again, hard to say why stuff like that happened since we were not there on the assembly line but as others have come to learn, never say never when it comes to mopars!
