Page 2 of 3 1 2 3
Re: another broken valley pan!! [Re: dUmB cLuCk…] #1473813
07/26/13 02:24 AM
07/26/13 02:24 AM
california
hornetnut Offline OP
california
ill be pulling the plugs tomorrow and comp test, the carb i started with was a holley 750 dp, now has an 850 dp holley, same issue with both.. now time to spend a lil diag time...
Re: another broken valley pan!! [Re: hornetnut] #1473814
07/26/13 05:23 PM
07/26/13 05:23 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
If there was a dead cylinder, wouldn't it be blowing the pan at any engine speed? He only cracks the pan at WOT
My engine cracked 2 of them, one was a used original so I thought maybe it was already weak, but a week later the brand new one did too.
Only at WOT
I checked my breather (remember, PCV only works when there's manifold vacuum, at WOT it closes, so the only way to evac blowby at WOT is through a breather). And I could barely blow through it by mouth. I pushed open the metal more (it resembled a pop can that was just cracked open) and then removed a big wad of padding. Replaced it with some paper towels to catch any oil vapors and never cracked another pan.
At engine idle, air would suck in at the breather, which is another check the OP could do... Of it was cracking from excessive blow by due to bad rings, hole in a piston, etc, wouldn't it be lightly puffing out of the breather at idle?
**Photobucket sucks**
Re: another broken valley pan!! [Re: 70Cuda383] #1473815
07/27/13 12:59 AM
07/27/13 12:59 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The engine is basically a compressor , the faster you run it the more pressure will build in the crank case . So at wide open throttle if there is a problem there becomes more crank case pressure than the PCV or vents can dissipate. So what is causing the crank case pressure to build up to push the valley cover inside out. Broken rings, hole in the piston, wiped exhaust lobes all would be likely candidates. It might seem to you that it's running OK but your engine has a problem that stuffing in a rag is not the proper fix.
Re: another broken valley pan!! [Re: rowin4] #1473816
07/27/13 02:04 AM
07/27/13 02:04 AM
california
california
i knew it wasnt the proper fix, but we all do weird things at the track to keep going rounds..
ill keep you posted as i get things sorted out... thanks guys
Re: another broken valley pan!! [Re: hornetnut] #1473817
07/27/13 02:14 AM
07/27/13 02:14 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
my stock valley pan expanded all the way up to the intake one day-----it was the one day I didn't have my collector vacuum lines hooked up.
Re: another broken valley pan!! [Re: hornetnut] #1473818
07/27/13 03:12 AM
07/27/13 03:12 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
tell me about it, i cut a daiper into sections & foil taped it over a crack in the pan between rounds. only had to get past the startline without being seen dripping oil. made it all the way to the finals.
Re: another broken valley pan!! [Re: rebel] #1473819
07/31/13 11:28 AM
07/31/13 11:28 AM
california
california
comp test was perfect, so i used a friends timing light just to be sure mine wasnt bad... boy was it off!!! initial was at 25 and total was over 50.... i did check the marks with the num 1 plug out at tdc and they are in place so im in high hopes that this change will fix it, its getting a pan a vac evac this weekend anyway.. set total timing at 34 degrees and it def likes it...
so i guess because i run 110 fuel thats why it didnt ping??
Re: another broken valley pan!! [Re: rowin4] #1473820
07/31/13 01:12 PM
07/31/13 01:12 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Absolutely correct. For some reason, the engine is building too much crankcase pressure. Timing has nothing to do with the problem. I'd bet there is either a broken ring or too much ring end gap.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: another broken valley pan!! [Re: 68LAR] #1473821
07/31/13 01:25 PM
07/31/13 01:25 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Either one of these things would cause excessive smoke and leakdown, I would do a leak down vs. a compression test. What CI? Is it blowing oil out the breathers? Perhaps too much oil causing windage?
Re: another broken valley pan!! [Re: camastomcat] #1473822
07/31/13 02:36 PM
07/31/13 02:36 PM
california
california
440 ci, eddy heads, .030 overbore, its a truck pan with a windage tray and only put 5 quarts in it.. it does show a lil over the full mark
Re: another broken valley pan!! [Re: hornetnut] #1473823
07/31/13 03:28 PM
07/31/13 03:28 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Does the oil want to come out of the breathers, and does it smoke out the exhaust?
Re: another broken valley pan!! [Re: camastomcat] #1473824
07/31/13 09:21 PM
07/31/13 09:21 PM
california
california
absolutely no smoke out of the exhaust... i have seen a lil oil dripping from the breather but only at the track
Re: another broken valley pan!! [Re: hornetnut] #1473825
08/01/13 12:11 PM
08/01/13 12:11 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Last 440 I saw that ran around that way for a little while, ripped the mains right out of the block. The spot where the main bolts thread in, just broke.
The guy set his timing by ear, and he said he ran race gas because he liked the way it smelled. I believe he had 55 degrees in it.
anyway good catch, hope no other damage was done.
Rich H.
Esse Quam Videri
Re: another broken valley pan!! [Re: hornetnut] #1473826
08/01/13 05:21 PM
08/01/13 05:21 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I would try running a tad less oil, maybe a 1/4-1/2 qt. I would prefer you do a leak down, but if you don't have the gauge or can't borrow one,that's your only option. The only other thing I can think of that would cause crankcase pressure other than a worn out engine, worn cam,etc. is too much oil. Are you sure you only have 5 qts? Stupid question....how old is this motor? If there is any way you can leak it down, do it.
Re: another broken valley pan!! [Re: camastomcat] #1473827
08/02/13 02:06 AM
08/02/13 02:06 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Is there only a crack but the shape hasn't changed? Because when you really have excessive crankcase pressure, the bathtub will balloon "upside down" before cracking. If not, then I believe you've got somekind of harmonics that crack the pan. I believe that's the reason why factory also used a "sandwich" between the intake and valley pan, to avoid cracking caused by harmonics.
Plynouth VIP '67 TT IC EFI
Re: another broken valley pan!! [Re: jyrki] #1473828
08/07/13 01:52 AM
08/07/13 01:52 AM
california
california
that makes sense... the second pan wasnt ballooned at all, just cracked.. another question though.. i installed the panny vac and while the engine is running im only getting a pulse type vacuum, not solid, is that normal?
Re: another broken valley pan!! [Re: hornetnut] #1473829
08/07/13 02:39 AM
08/07/13 02:39 AM
western PA
Sb Valiant Offline
Sb Valiant  Offline
western PA
I'm surprised you don't have a messed up head gasket with the timing being way off like that I could be thinking way wrong
Re: another broken valley pan!! [Re: Sb Valiant] #1473830
08/07/13 07:02 AM
08/07/13 07:02 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
When I had this problem it was an over site on my part. My breathers were too close to the deflector inside the valve cover and wasn't letting the CCP out until the pressure built up a little causing the valley pan to pulse. I corrected this and never cracked another valley pan.
Re: another broken valley pan!! [Re: mac56] #1473831
08/08/13 02:21 AM
08/08/13 02:21 AM
california
california
so is the pulse vacuum from the header normal? it is a vacuum, just not solid so if its normal then im going racing...
Re: another broken valley pan!! [Re: hornetnut] #1473832
08/08/13 08:08 AM
08/08/13 08:08 AM
ill
dennismopar73 Offline
ill
2 other things can cause the 'pulse' , could be the evac tube is in wrong place on the collector, to clost to a tube end? or the evac insert is improperly put in??
just sayin!
Page 2 of 3 1 2 3
