Torsion Bar removal tool? #1473435
07/24/13 06:25 PM
07/24/13 06:25 PM
rtplumcrazy1 Offline OP
do they sell a special tool to remove torsion bars, I believe I have seen something for this procedure for sale somewhere. Can you help point me in the right direction
Put a big block 4 speed Scat Pack Dodge in your garage.
Re: Torsion Bar removal tool? [Re: rtplumcrazy1] #1473436
07/24/13 06:30 PM
07/24/13 06:30 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Loosen the adjuster nut, loosen the lca nut but leave it on by about 5 threads. Then use a pry bar to move the LCA and therefore the TB back. Then tap the LCA off the TB and she's out.
Sheldon
Re: Torsion Bar removal tool? [Re: rtplumcrazy1] #1473437
07/24/13 06:34 PM
07/24/13 06:34 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
if you are going to junk the old ones just clamp a vice-grip on there and wail it - works but damages the bar. otherwise a clamp-type tool is available, I think I gave mine to mperry after I used it years ago. Many here have made good tools for this tho.
Ride eternal, shiny and chrome
Re: Torsion Bar removal tool? [Re: DirectSubjection] #1473438
07/24/13 06:43 PM
07/24/13 06:43 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Yep still have it and it has come in handy quite a few times.
I didn't expect you to give it to me so if you need it back let me know.
Re: Torsion Bar removal tool? [Re: MPerry] #1473439
07/24/13 06:52 PM
07/24/13 06:52 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
heard of using a bicycle handlebar clamp/steering stem clamped on to the torsion bar and of course a BFH
Re: Torsion Bar removal tool? [Re: MPerry] #1473440
07/24/13 06:57 PM
07/24/13 06:57 PM
Here
Here
Nah -enjoy removing bars with it
Re: Torsion Bar removal tool? [Re: MPerry] #1473441
07/24/13 07:02 PM
07/24/13 07:02 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
If it is good for squishing spiders, can I borrow it next?
(PS as for torsion bars, I never needed a tool either, just moved the control arm back enough to get the bar to move, then just slide it out by hand the rest of the way)
Re: Torsion Bar removal tool? [Re: OzHemi] #1473442
07/24/13 07:12 PM
07/24/13 07:12 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I don't think you could get close enough to use it with any accuracy.
Re: Torsion Bar removal tool? [Re: RUNCHARGER] #1473443
07/24/13 07:18 PM
07/24/13 07:18 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Sheldon
X2^ Very easy, no tool needed.
Re: Torsion Bar removal tool? [Re: Lefty] #1473444
07/24/13 07:29 PM
07/24/13 07:29 PM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
In case moving the lower control arm back doesn't get it, you can use a couple of 1" wire rope clamps tightened back to back on the 'bar. Then you can bang on them and not hurt the 'bar.
Master, again and still
Re: Torsion Bar removal tool? [Re: Lefty] #1473445
07/24/13 07:30 PM
07/24/13 07:30 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Torsion Bar removal tool? [Re: 70AARcuda] #1473446
07/24/13 07:31 PM
07/24/13 07:31 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Get the tool AARcuda mentioned, works great, won't mess up the old bars,
Re: Torsion Bar removal tool? [Re: 69CHARGERMD] #1473447
07/24/13 08:37 PM
07/24/13 08:37 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
less than $5 in junk from the local big box store and a piece of scrap...
Re: Torsion Bar removal tool? [Re: rtplumcrazy1] #1473448
07/24/13 09:26 PM
07/24/13 09:26 PM
AndyF Offline
AndyF  Offline
Yes, there is a tool called out in the service manual. Most Mopar parts places will carry a version of it.
Re: Torsion Bar removal tool? [Re: AndyF] #1473449
07/24/13 09:36 PM
07/24/13 09:36 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The real thing.
Re: Torsion Bar removal tool? [Re: 62maxwgn] #1473450
07/24/13 09:49 PM
07/24/13 09:49 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I have been making them for years. They are made from 1"X 1" steel with a knurled handle. .The tool uses 4 contact points to clamp on the bar (the factory tool only has 3. Also the tool has 2 3/8 grade 8 bolts instead of the factory 1/4 inch bolts. I have them available here http://www.custommachinecomponents.com/shopdisplayproducts.asp?page=3&id=8
Re: Torsion Bar removal tool? [Re: johnscudashop] #1473451
07/25/13 07:54 AM
07/25/13 07:54 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I'm going to simply say this. Your tool worked for me when all the DIY Mickey Mouse methods were just a waste of time. My T-bars were IN THERE!!
Nice product. Thanks.
BTW, I learned something when using this tool. You really, REALLY (!!!) to need to crank down on the bolts to way beyond the tightness you think you need. Those GR 8's can take it. Then it works like a charm with the handy old BFH.
Re: Torsion Bar removal tool? [Re: Commando1] #1473452
07/25/13 11:32 AM
07/25/13 11:32 AM
AndyF Offline
AndyF  Offline
I had a car in the shop the other day and both torsion bars had been twisted out of shape. I had to really beat on those bars to get them out of there. A lightweight tool wasn't up to the task, had to use the real deal.
On a car that hasn't been abused, doesn't see any salt, is always kept lubed and garaged is a different issue. The bars will usually slide right out once they are unloaded.
Re: Torsion Bar removal tool? [Re: AndyF] #1473453
07/25/13 11:49 AM
07/25/13 11:49 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
I also have one of those factory Miller Special Tools, torsion bar removal tool.
It's a heavy duty, well manufactured tool, for the removal of some really stuck torsion bars.
Without that tool i wouldn't have been able to get some bars out of cars, that i had to work on at the shop, or wrecking yards.
Yes, sometimes the home made, Mickey mouse, tool may work for you, but in a lot of instances they won't.
And by the way, the Miller tool uses big,1/2 diameter bolts, and not 1/4 inch, like one other poster wrote about, for his tool.
Have no idea where he came up with that kind of measurement.
Mine has been beat on many times, to get stuck bars out out their mounts.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Torsion Bar removal tool? [Re: A12] #1473454
07/25/13 12:01 PM
07/25/13 12:01 PM
Cedar Lake IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Cedar Lake IN
Thats what I did, used the old motocross style one on the right.
