Re: Not much quicker with 410" stroker??
[Re: vern73]
#1473056
07/26/13 08:35 PM
07/26/13 08:35 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Definately wouldn't stand the cam straight up. Cam is just real small and is barely opening the valves maybe 1/2 inch if that after deflection. Small cam and small heads on that many inches is a governor on performance, you are running real stout with what you have.
[Re: B3422W5]
#1473057
07/26/13 11:31 PM
07/26/13 11:31 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
yeap I agree with some other post 1 no where near enough cam, need more head work and more carb and I will tell you I was running 4.88 gears with my 416 and it was very happy.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
