Re: Crossmember spacers on Ramchargers??? [Re: 76dodgeboy] #1472414
07/25/13 12:13 AM
07/25/13 12:13 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Im starting to think it was 2wd only. Haven't seen any 4was with them yet when searching pics.
That explains the reason why they're not in the can of bolts for the last 4wd RC that I parted out
Re: Crossmember spacers on Ramchargers??? [Re: BulletBob] #1472415
07/25/13 01:51 AM
07/25/13 01:51 AM
Nevada
dezduster Offline
dezduster  Offline
Nevada
I have 4 R/C to reference all 4x4 no spacers under cross members. Years are 84,86 and two 85.
Re: Crossmember spacers on Ramchargers??? [Re: dezduster] #1472416
07/25/13 02:52 AM
07/25/13 02:52 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Must be a 2wd only than. Hey Bob can you check your 2wd and measure them if it has them? I think we should still is them for clearance even if its under an inch Mr Johnson.
Re: Crossmember spacers on Ramchargers??? [Re: 76dodgeboy] #1472417
07/25/13 03:38 AM
07/25/13 03:38 AM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
my Johnson is over an inch!
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Crossmember spacers on Ramchargers??? [Re: hp383] #1472418
07/25/13 03:42 AM
07/25/13 03:42 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
And the spacers may indeed be a good plan. I did have the taller diesel style blocks installed in the rear, so the spacers would help correct the driveshaft angle.
I know the diesel truck crosmembers had a special spacer attached to the t-case mounting surface that is about an inch to help with driveline alignment.
So if I could find an inside diameter, and length. I can either buy some, or find some.
I have 1"OD and 0.50"ID aluminum readily available.
Re: Crossmember spacers on Ramchargers??? [Re: 76dodgeboy] #1472419
07/25/13 08:20 PM
07/25/13 08:20 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I sure can ! I'll be home in 30 mins or so
Re: Crossmember spacers on Ramchargers??? [Re: BulletBob] #1472420
07/25/13 10:03 PM
07/25/13 10:03 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
They are 5/8" tall
Re: Crossmember spacers on Ramchargers??? [Re: BulletBob] #1472421
07/27/13 04:17 AM
07/27/13 04:17 AM
Ca
76440 Offline
76440  Offline
Ca
Never seen those spacers on a 4x4.
The cross-member is different between the 77 and 93. Going from the 727 to the 518 in a 77rc...used the 518 crossmember and reused 4 of the holes in the frame for each side(top&bottom.
The holes will be there since it had a 518 before...just a matter of using the right crossmember.
Are you using the JW ultrabell to adapt to the 440?
Re: Crossmember spacers on Ramchargers??? [Re: 76440] #1472422
07/27/13 02:20 PM
07/27/13 02:20 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Yes he has the ultra bell. I think its been the same crossmember that it had with the 518 because the transfercase bolted to it as well.
