Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472392
08/11/13 12:42 AM
08/11/13 12:42 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Put both in reverse and make sure the rod is adjusted properly.
You mentioned you had the tool to line up the box, maybe your trans needs a little bit more or less.
I can't afford this. mark
Re: Hurst Shifter - Bent Lever? [Re: a12superbee] #1472393
08/17/13 11:44 PM
08/17/13 11:44 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
Disconnected the R rod and put in reverse by moving the trans lever, then increased the length with two turns and reconnected the R rod. Also tweaked the 1-2 rod by one turn. Noticed there is a lot of front back play in the 1-2 rod when it's in the neutral position. I suspect this isn't normal.
Seems like the tweaking improved things as I'm able to now get the shift into reverse. A bit tough to get it there... but seems to be working.
Thanks for all the suggestions.
-Rob
RobH
72 Plymouth Duster 360
73 Dodge Charger SE 318
74 Dodge Challenger 340-4
74 Dodge Challenger 440
