Question on Cam/lifter failure #1472095
07/22/13 12:07 PM
07/22/13 12:07 PM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
Guys,
I have an engine with roughly 1000 miles on it. I have had a problem with a lifter(s) ticking for about the last 500 or so miles. I've worked with the cam supplier to try and troubleshoot it, but nothing seemed to work. I finally pulled the intake and lifters. The lifters appear to not have been hardened properly by the wear marks and pits on the bottom of some of them. The cam is showing pits on a couple of the lobes. I have not removed it yet, but will Tuesday. From the attached pic, does this look normal for an engine with such low mileage? I sent a ton of pics of the lifters to the cam supplier and am waiting his response. I'm wondering what you guys think as I'm no expert and would appreciate your thoughts.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Question on Cam/lifter failure [Re: Dixie] #1472096
07/22/13 12:38 PM
07/22/13 12:38 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
That wouldn't be normal on a 100,000 mile engine. I would definitely cut the oil filter open and check for debris. You may get lucky and not have to completely disassemble the engine for cleaning and probable bearing replacement, but I wouldn't count on it.
Re: Question on Cam/lifter failure [Re: 5spdcuda] #1472097
07/22/13 01:19 PM
07/22/13 01:19 PM
dogdays Offline
dogdays  Offline
You had a textbook cam failure.
Those "pits" on the bottom of the one lifter are from microwelding the lifter to the cam lobe then tearing it away. The other two lifters just aren't that far along.....
Your cam is shot, take it out.
Small consolation is that you are not alone. Cam failure on break-in is rampant.
R.
Re: Question on Cam/lifter failure [Re: dogdays] #1472098
07/22/13 01:35 PM
07/22/13 01:35 PM
Dixie Offline OP
Dixie  Offline OP
Only a few cam lobes show pitting, wouldn't a failure to break it in, take out all the lobes? And faster than a thousand miles?
Re: Question on Cam/lifter failure [Re: Dixie] #1472099
07/22/13 02:15 PM
07/22/13 02:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just a small amount of hardness difference in the lifters can
cause some to fail and not others... your cam is gonna
have to come out... I hope your cam company will work
with you on this
Re: Question on Cam/lifter failure [Re: dogdays] #1472100
07/22/13 06:57 PM
07/22/13 06:57 PM
dogdays Offline
dogdays  Offline
Camshafts are lubricated mostly by splash. Some of the lifters get more splash than others, so I don't think it's a sign that three went bad. The situation muust have been borderline for it to take 1000 miles, although back in the day it wasn't uncommon to see engines go 50K - 70K miles and THEN develop a flat lobe or two. Of course those were mild cams and wimpy springs....
If I'm the cam company and have had hundreds of cam failures in the last couple of years, which the large volume manufacturers certainly have had, if I say "you get a new cam and lifters" to every one, I'm going out of business. So don't expect anything except sympathy from your cam manufacturer.
At best maybe they'll offer a discount on replacement parts.
R.
Re: Question on Cam/lifter failure [Re: dogdays] #1472101
07/23/13 10:00 AM
07/23/13 10:00 AM
Dixie Offline OP
Dixie  Offline OP
I just posted pics of three lifters. They all have issues. I talked to the cam supplier and so far he is saying the cam and lifters are good and they won't warranty anything. I find that position hard to believe. I got the cam from a well known guy who has his cams custom ground. He is not the manufacturer, Engle is. But, he said no one warranty's their cams now days. Which is not true according to my engine builder. I don't know about all that, but I do know, the lifters were failing which is why I pulled them. The pitting I found is a secondary issue after pulling them.
Pulling the cam today and putting in a new one from a different company.
Re: Question on Cam/lifter failure [Re: Dixie] #1472102
07/23/13 10:16 AM
07/23/13 10:16 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Ok, here comes the inevitable question... What oil did you use? Any additives?
Re: Question on Cam/lifter failure [Re: BigBlockMopar] #1472103
07/23/13 02:33 PM
07/23/13 02:33 PM
Dixie Offline OP
Dixie  Offline OP
Oh yeah, I used good oil with zinc additives. Valvoline VR-1 Racing at first, then the cam supplier told me 20/50 was not good and to switch to 10/30. LOL. I did it, just to appease him and the problem still occurred. The 10/30 was Royal Purple (on sale cheap at Amazon at the time with free shipping and on tax) with yet more zinc additives.
I pulled the cam this AM and it has pits at the top of most of the cam lobes. I'll post some pics later.
Re: Question on Cam/lifter failure [Re: Dixie] #1472104
07/23/13 02:42 PM
07/23/13 02:42 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
That doesn't really make sense, if the cam had a preference regarding oil viscosity I would think it would prefer a thicker weight oil for the additional film strength.
Re: Question on Cam/lifter failure [Re: Dixie] #1472105
07/23/13 03:29 PM
07/23/13 03:29 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I am sorry about your misfortune. I am just curious, was this a solid or hydraulic cam and what were the spring pressures like?
Re: Question on Cam/lifter failure [Re: 5spdcuda] #1472106
07/23/13 05:08 PM
07/23/13 05:08 PM
Dixie Offline OP
Dixie  Offline OP
130 @ 1.875 and 325 @ 1.300
Re: Question on Cam/lifter failure [Re: Dixie] #1472107
07/23/13 05:14 PM
07/23/13 05:14 PM
Dixie Offline OP
Dixie  Offline OP
Some cam lobe pics.
Re: Question on Cam/lifter failure [Re: Dixie] #1472108
07/23/13 05:15 PM
07/23/13 05:15 PM
Dixie Offline OP
Dixie  Offline OP
'nutter
Re: Question on Cam/lifter failure [Re: Dixie] #1472109
07/23/13 05:21 PM
07/23/13 05:21 PM
Dixie Offline OP
Dixie  Offline OP
I called Engle direct since the guy I got the cam from claims there is no issue with the cam. Engle said there is no warranty and they won't do anything. Engle said they don't make lifters, they buy from another source. Supposedly, high quality Made in the USA ones.
So, the guy I got the cam from says, the cam is fine and he'd run it. Would you guys run this?
The lobe pics are representative of most of the lobes on the cam.
Re: Question on Cam/lifter failure *DELETED* [Re: Dixie] #1472110
07/23/13 05:30 PM
07/23/13 05:30 PM
Dixie Offline OP
Dixie  Offline OP
Post deleted by Dixie
Re: Question on Cam/lifter failure [Re: Dixie] #1472111
07/23/13 05:42 PM
07/23/13 05:42 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Dont know the cause, but its definetly junk. Looks like electrolysis
Re: Question on Cam/lifter failure [Re: Dixie] #1472112
07/23/13 05:43 PM
07/23/13 05:43 PM
Kirkland, Washington
Pacnorthcuda Offline
That cam and lifters are garbage. dont even THINK about running them.
To me it looks more like poor metalurgy than a lubrication issue. I also think you probably got lucky with no other damage--inspect the pan, oil pump, piston skirts etc.
Re: Question on Cam/lifter failure [Re: Pacnorthcuda] #1472113
07/23/13 05:54 PM
07/23/13 05:54 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Offer to install that into the engine of the guy you bought it from. He said he'd have no problem running it. It looks like a metallurgy problem to me as well.
Sheldon
Re: Question on Cam/lifter failure [Re: RUNCHARGER] #1472114
07/23/13 07:16 PM
07/23/13 07:16 PM
dogdays Offline
dogdays  Offline
IT IS NOT A METALLURGY PROBLEM!
It is a lubrication failure. It happens when the pressure between cam and lifter (or gear teeth) exceeds the oil's film strength. The oil film ruptures, microwelding occurs, then tears apart, leaving those pits.
Similar pictures are found in every textbook on lubrication and assessing failures.
No, I wouldn't run the cam, it is shot.
Unfortunately for engine builders, lifter acceleration is generally increasing while lubricant antiwear/EP properties are decreasing. Thus, the plethora of camshaft failures. This is made even worse by the necessity of using higher valvespring pressures with the more extreme lifter acceleration values.
Welcome to the world of high performance. No cam manufacturer will warranty such a failure, except Hughes says they will IF you follow their directions exactly.
The faster you want to go the more you will discover there are costs for every advancement. Ain't pretty, but it's true.
R.
