Re: Could this be a growing trend?
[Re: MRMOPAR622]
#1472044
07/23/13 12:40 PM
07/23/13 12:40 PM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
Has anyone thought about running at a different track where they don't have or enforce all the BS rules?*?I can put a few more gallons of fuel in the truck and "Keep On Trucking" right passed tracks like that on my way to another! If Racers won't race at those kind of tracks,they have only 2 choices back of some of the BS rules or close the track either one works for me. "THINK ABOUT IT"
This is what I do. The only reason I ever got my cage cert'd and got my comp license was for the pump gas drags in Memphis. None of the tracks in the state of SC go by the rules. I think the only track in NC that goes by the rulebook is ZMax, but noone runs there anymore. ZMax is the only NHRA track around here. Everything else is either IHRA on not sanctioned.
To run mid 9s in my car, all I need is a helmet and single layer jacket. The jacket isn't required at my local track until you run faster than 6.50 in the 1/8. Most other tracks I run at don't care as long as you have a helmet...honestly, some of these little 1/8 mile tracks don't care if you have a helmet.
I let my cage cert expire, but I still have my comp license. It was a PITA to get, so I figure I'll keep it current.
[Re: tboomer]
#1472046
07/23/13 01:00 PM
07/23/13 01:00 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
I do have a senario question though. Sportsman class, 12.0 cut off. What if, in eliminations, i dial my 12.60 opponent dials 12.01 I break out going 12.55 -.05, but opponent breaks out with an 11.98 -.03 ? I break out greater, but opponent breaks out of the class cut off. Who advances? Does breaking class cut off cause an instant DQ in eliminations? Just asking.
Great question,Chris! I would think you would get the win.... Unless your opponet was one of the track managers "favorites"
Depends on the track. Back in the day, my 11.40 Dart would often be (nut and bolt) throttle stopped to 12.0X to be at the top of the Sportsman class. My local track changed that rule FOUR times in 2 seasons depending on who was complaining.
[Re: cudadoug]
#1472047
07/23/13 01:21 PM
07/23/13 01:21 PM
Posts: 19,395 Las Vegas
Al_Alguire
Las Vegas
To each his own...
In my opinion you should run your car at a place you are comfortable and can AFFORD!! It is sad to me to see people out there running stuff they cannot afford, or seemingly cannot afford just to try and keep up with the jones'. So find a place that is comfortable financially and you want to race and then deal with the rules.
[Re: 73swinger]
#1472048
07/23/13 01:34 PM
07/23/13 01:34 PM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
RT 66 used to throw you out if you broke out of class, but they don't anymore. Now it's only if you cross one of the safety equipment lines without said safety equipment on. (i.e. 9.99 on a 10.0 dial w/o jackets/pants/etc.)
I still think Sportsman should be for DOT street tires and mufflers only. Way too many Pro cars have parked in Sportsman to duck hunt. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: racealittle]
#1472049
07/23/13 02:23 PM
07/23/13 02:23 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Cab you are better than that. Nothing has changed in the rule books with respect to a given ET and MPH. If you exceed one, the other, or both; you have to accept the fact that you are too fast for "their defined rules and circumstances".
Once you can't accept the rules, it is time to move on to where the rules are different, or get a new hobby. I have moved on to enjoying the car more with less and still have the necessary combinations of parts to get me in trouble with the rules in sanctioned racing. There is always No-ET racing if you can find it.
I had not seen or heard of the 135 MPH rule before being told about it on Saturday My fault because it has been at the very front of the rule book in the ET rules and regulations for a long time evidentily That is the only place it is mentioned or listed in the NHRA rule book ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) It(that limitation) is not in the general section or in any other location that I can find so the Stock and S/S/ racers can run in excess of 135 MPH with none of the safety equiptment that the ET racer is required to have once we go above 135.00 MPH ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I traded my Duster off for this car due to E bodys selling easier than the A bodys do, my fault Hopefully one of the several guys that express interest in this car at that race will buy it so I can move on to other endeavors ![](/ubbthreads/images/graemlins/luck.gif)
[Re: Dragula]
#1472050
07/23/13 03:19 PM
07/23/13 03:19 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I went from running low 9s with a full fire suit in my Dart last year to running Mid 11s in a T shirt this year.
The index racing I do not care for. Ran it once, and to say it didn't work out, is an understatement. Maybe if I had a car more suited to that, but I do not like slowing it down.
As for avoiding the 9.99 thing, I completely agree. I am working on getting our car legal for 9.99 or quicker, which I think all I need now is a -5 jacket and my license, but I plan on slowing it down for next season. Got into enough trouble without some of the gear, and I just can't see wearing a warmer jacket and such just to go a few tenths quicker...There are a number of rules for that ET that really do add up in cost...
We had a bad accident at our track a few weeks ago, and since then, they have annouced full enforcement of all the rules will be in place for the next race. We were lucky and just had $1k worth of upgrades and are almost totally legal. I think the solid throttle cable and gas pedal toe hook are the only two items left for us which I was not aware of...And apherently is what went wrong during the accident that got the driver impailed with a fence post at our track.
What track and who wrecked??
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#1472051
07/23/13 03:33 PM
07/23/13 03:33 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
Put a 2 barrel Carb on it, that will slow it down. I have friend that runs 11.50's just so he does not have to put a roll bar in his car and he runs with a Mechanical throttle stop, a bracket with a nut and bolt. Less of pain and more fun running in the 10's
Switched to the dark side...
[Re: 493_DART]
#1472056
07/23/13 09:13 PM
07/23/13 09:13 PM
Posts: 1,628 anywhere@ anytime
actionange
anywhere@ anytime
my car went 6.40 and then showed 60/330 times that were even quicker .
As soon as the track says something, I will back it down. We already have the COMPLETE B.S 2 year belt rule and now the new INSANE locking dipstick deal...
Im not paying $$$$$$ just to go 6.39.
I used to support the NHRA ,but now that Ive gotten into racing a faster car over the years....I am starting to despise them due to the fact they are raping the small racers with silly un necessary rules so they can make kickback money.
new nhra rule for 2014 = SFI helmet revision 32.1 = you must have an sfi approved , brand new helmet EVERY year .
And let's not forget header collector retention cables... I did have one fall off last year but now have bolt together tabs on each and every tube but its still not gonna be legal. If you weld them on you'll not need the cables. They're available from Lokar a new NHRA sponsor... ![](/ubbthreads/images/graemlins/eyes.gif)
[Re: Dragula]
#1472057
07/24/13 10:06 AM
07/24/13 10:06 AM
Posts: 4,213 New York
polyspheric
New York
Eventually, a smart lawyer is going to eat them for lunch. It begins with "On what engineering tests are the rules based?" (vapor lock).
Boffin Emeritus
[Re: actionange]
#1472058
07/24/13 10:28 AM
07/24/13 10:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I really have to laugh at the locking trans dip stick.. I NEVER seen oil come out of it and you have a vent down much lower than the top of the trans tube ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Eric]
#1472059
07/24/13 10:47 AM
07/24/13 10:47 AM
Posts: 12,421 Taxes & Virus's R-US, NY
Dragula
It was Empire, and Skip Reap....I posted it on here, and almost nobody replied.
https://board.moparts.org/ubbthreads/showflat.php?Number=7756641
My work computer will not allow me to go to the gasser site, but its on there as well at: Gasserracingseries.com
[Re: cudasteve68]
#1472061
07/24/13 01:35 PM
07/24/13 01:35 PM
slantzilla
Park Forest, IL
When RT 66 first opened Marlon Carter ran S/Pro and Pro footbraking the same car. He qualified for the Bracket Finals in both classes.
[Re: slantzilla]
#1472062
07/24/13 01:54 PM
07/24/13 01:54 PM
Triple Threat
Renton Washington
A few of me and my buddies who normally run pro will enter super pro when its allowed. This weekend i'm taking part in a Door Car vs dragster shootout, and I'm doing it without a Box.
