Rubber window down stops #1471909
07/21/13 11:19 PM
07/21/13 11:19 PM
Arizona
68CoronetRT Offline OP
Arizona
I am trying to locate a source for the rubber quarter window stops that fit into a slot in the rocker panel area.
Also, the upper stop is missing the rubber band that stops the rattling.
Anyone know if these are being reproduced or available anywhere?
Re: Rubber window down stops [Re: 68CoronetRT] #1471910
07/22/13 03:23 PM
07/22/13 03:23 PM
New Berlin,Wi
Firepowerflyer Offline
New Berlin,Wi
As far as the rubber band anti rattle I used a piece of 5/8 heater hose about 1/4 wide and stretched it over the bracket.It works really well.
Re: Rubber window down stops [Re: Firepowerflyer] #1471911
07/22/13 08:05 PM
07/22/13 08:05 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
You could also use a stack of rubber O rings.It's easy and works.
Re: Rubber window down stops [Re: 5carguy] #1471912
07/22/13 11:49 PM
07/22/13 11:49 PM
Arizona
Arizona
Thanks for the suggestions.
I found my old rubber stops which have cracked in two and am trying to glue them back together. Super glue doesn't seem to be making it happen though.
