Re: How to ID where a crate Hemi was MFG
[Re: JohnRR]
#1470091
07/19/13 09:45 AM
07/19/13 09:45 AM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
Thats the area where the guy said the Cummins tag was on two of the crates he had,there is nothing on this one unless it fell off and is in the crate,I will have to stop by his house and look in it. Quote:
Send Zippy a PM with that pad info and he should be able to tell you about it.
Does have a sticker on the bellhousing flange telling you how big it can be safely bored ?
who is that guy?
[Re: Brian_wo]
#1470093
07/19/13 06:41 PM
07/19/13 06:41 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
He still has the crate ? If it was done by RECON there will be a "made in canada" sticker on it also a date on the crate , what's the date ?
Easiest way to tell if it was made by RECON is to first pull the intake , if it's prior to '05 there is a good chance it will be full of metal chips , after the beginning of '05 you can check up near the top big water holes inside the valley , if you see RED RTV it was done by Cummins ... ![](/ubbthreads/images/graemlins/eyes.gif)
[Re: AndyF]
#1470095
07/19/13 11:48 PM
07/19/13 11:48 PM
Brian_wo
Omaha Nebraska
Thats why I am afraid to even run it,will probably just drop it at my machinest to have it looked over and corrected.
who is that guy?
[Re: AndyF]
#1470097
07/20/13 02:05 AM
07/20/13 02:05 AM
Posts: 2,431 USA
SSAAHemiFan
USA
Arrow built the first versions. The buildups were covered in one of the mopar mags and it specifically said arrow numbered and kept records of all the engines. By the tag it seems your block was #45 ?? Any date codes or foundry markings on the side of the block ? There was also a foundry change or 2 on the early style block's If it's a Arrow motor.. you definately scored call them and ask... http://www.arrowracingengines.com/
[Re: billohio]
#1470099
07/20/13 09:43 PM
07/20/13 09:43 PM
Brian_wo
Omaha Nebraska
I emailed Arrow,if I dont hear back from them by Wednesday I will call them,thx
who is that guy?
[Re: Brian_wo]
#1470100
07/23/13 05:26 PM
07/23/13 05:26 PM
Brian_wo
Omaha Nebraska
Well that was a kick to the nads,Arrow did not build it.
who is that guy?
[Re: Brian_wo]
#1470101
07/24/13 01:09 AM
07/24/13 01:09 AM
JohnRR
I'll look at the ID pad on my hemi tomorrow , right now there is a half dozen pissed off wasps in my garage so I'm not going out there ... ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Brian_wo]
#1470104
07/24/13 01:14 PM
07/24/13 01:14 PM
Posts: 15,527 Omaha Ne
TJP
Omaha Ne
Mine is a cummins built around late 2001, its pad is stamped similar to yours H2355 242 426 (stamped with the numbers 180 out from the above) like yours, hope that makes sense ![](/ubbthreads/images/graemlins/beer.gif)
