Page 2 of 3 1 2 3
Re: Clutch fan VS electric fan [Re: 360view] #1468588
07/17/13 08:17 AM
07/17/13 08:17 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
It is worth remembering that
the lower horsepower consumed by an electric fan at full throttle
can not last more than a minute or so,
beause the engine will overheat.
Explain this please. If your car is at full throttle most likely it's moving quite quickly, then the radiator is doing most of the cooling and not the fan as it's not needed to get airflow.
A clutch fan would be slipping at higher RPM's anyways..so how's this different than an electric fan?
I can see if you were going up a steep mountain with a large load in first gear moving slowly at high rev's where the additional air flow potential of a mechanical fan would be useful. How many here are towing large loads up mountains in Death Valley with their classic Mopars here? Even so, if that were a concern, you can install bigger electric fans to deal with these extreme circumstances.
I'm not advocating one is better than the other here...I see pros and cons to each. I just object to people who spread misinformation like "you won't be able to effectively cool your engine with electric fans...just go clutch".
IDK...maybe I'm just the one lucky SOB here who has an engine that cools just fine with electric fans?
Re: Clutch fan VS electric fan [Re: cjskotni] #1468589
07/17/13 11:18 AM
07/17/13 11:18 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
At highway speeds you should be able to remove the fan completely and the engine will still stay cool. I have run many cars/trucks with the mechanical fan completely removed (no fan at all) and the only time they would get hot was in slow moving/stopped traffic. My 68 cuda when it had the 402 stroked 318, my 2000 ram, 2000 dakota, 86 5th ave... and none of them got hot pulling trailers up mountain passes in 100+ heat. You can feel a big difference in power when you ditch them.
I have not found any aftermarket fans that would keep the big motors cool at idle, got to get a good OEM unit.
Re: Clutch fan VS electric fan [Re: HotRodDave] #1468590
07/17/13 12:31 PM
07/17/13 12:31 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
I switched out my flex fan for a Mercedes OEM fan with a shroud. The fan needs a seperate controlling unit available through a moparts member.
The electric fan is definately more complex than a clutch or fixed fan but it's not that bad to install it.
So far the fan does a great job at cooling down my somehow modified 440 - even in slow traffic on a 95 degree day.
I could also swear that there was a slight increase in power - at least it feels so.
The fan draws quite some current (400W item) but only when at full speed (which it rarely does - controlling unit regulates fan speed).
Another cool feature is that I can set the water temperature indepently of the thermostat (have 180 stat and temperature the fan has to maintain is 190 degrees).
Re: Clutch fan VS electric fan [Re: DGS] #1468591
07/17/13 01:05 PM
07/17/13 01:05 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
why is this such a "heated" debate?
I kill me
Re: Clutch fan VS electric fan [Re: RangerDan440] #1468592
07/17/13 01:27 PM
07/17/13 01:27 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I kill me
Perhaps we need to cool it down a bit...
Re: Clutch fan VS electric fan [Re: cjskotni] #1468593
07/17/13 01:42 PM
07/17/13 01:42 PM
I kill me
that blows
Re: Clutch fan VS electric fan [Re: RangerDan440] #1468594
07/17/13 02:59 PM
07/17/13 02:59 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Incredible...
Nobody has mentioned the HP drop when the alternator kicks in to drive those (2) electric fans..
Electric fans can draw up to 35 Amps, while many OE Mopar alternators were only rated < 50 Amps...
Just my $0.02...
Re: Clutch fan VS electric fan [Re: Sinitro] #1468595
07/17/13 03:10 PM
07/17/13 03:10 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Incredible...
Just my $0.02...
HP drop was measured and factored into the dyno tests. HP drop is much less than that of a mechanical fan but yes, there is an additional load placed on the alternator from the electric fan. After all, nothing is free.
That being said an electric fan can cut off entirely when it's not needed (ZERO loss) unlike a mechanical fan.
As I already mentioned, adding electric fans will most likely necessitate upgrades to the charging circuit or you will create more problems. As for my car, I went to a 100 amp alternator and I don't have discharge unless I am idling in gear/lights on/AC on/hi blower/fans on @ the same time. This all goes back to the "well-planned" part I talked about.
Re: Clutch fan VS electric fan [Re: cjskotni] #1468596
07/17/13 07:52 PM
07/17/13 07:52 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Incredible...
Just my $0.02...
Shun him SHUN HIM before he makes enough sense to convert you.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Clutch fan VS electric fan [Re: tee-john] #1468597
07/17/13 08:40 PM
07/17/13 08:40 PM
United States
tee-john Offline OP
tee-john  Offline OP
United States
Thanks guys, that gives me enough info to stay with a clutch type fan. Now all I need is a shroud that will fit.
I am having terrible clearance issues between my water pump nose and the electric fan center hub. I don't want to cut up my car to shim the radiator forward. My car did run at my thermostat range in south LA in summer time even without a shroud. It is a champion 4 core which I am satisfied with. I had to do some engine work and other things so that's why I am trying to change up a bit. But , I did go through 4 water pumps in less than 2000 miles. Some guys say it may be my clutch fan out of wack or belt to tight. IDK. My water pumps were all milodon. This is the Grim Reaper Barracuda from Florida. Yea it's killin me. I am a Cajun and I do have a double barrel 12 gauge in the shop but I just can't shoot the car yet. Lol. Jk to the sensitive ones.
Re: Clutch fan VS electric fan [Re: Sinitro] #1468598
07/17/13 09:12 PM
07/17/13 09:12 PM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
Incredible...
Just my $0.02...
...and it is uNcredible that you did not mention how little the electrics have to stay on during normal driving ...
Re: Clutch fan VS electric fan [Re: cjskotni] #1468599
07/17/13 09:43 PM
07/17/13 09:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Incredible...
Just my $0.02...
I wouldn't call that "well planned" if your car discharges at idle with everything on. That's not any good.
I recently installed a 99 amp powermaster alt in my ride. Made a huge improvement and it put's out good down low. I also put my lights and AC on relays and my lights stay bright at idle now, 13.9-14.1 volts bright at idle with the new alt.
I can't stand when a car discharges at night and the headlites dim. I always kept my foot on the gas some to keep the Rs up so my headlites stayed on. No more.
I think this powermaster could handle a 30 amp fan at idle?? Don't know it might be a problem?
Re: Clutch fan VS electric fan [Re: Challenger 1] #1468600
07/18/13 07:18 AM
07/18/13 07:18 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Incredible...
Just my $0.02...
Seriously? The OEM setup on my car 60 amp alternator would be discharging at idle if you turned on the lights and nothing else. So yeah, I'd say that only having a minor discharge with everything on at 700-750 rpm idle is absolutely acceptable considering a 20 amp draw from the fans which may or may not be on.
100 amp alternator is the biggest you can get for any reasonable amount of money that drops in and appears factory. My unit has the same specs as yours so I bet with yours...you'd be in the same boat.
Ask Powermaster what they define as 'idle'. I bet its 2400 alternator RPMs which would equate to 800 engine RPMs which I'm not running that high in gear. Since the output of an alternator is profoundly NOT linear in the lower ranges, this means you see significantly less than the stated idle output...that is unless you up your idle so your running 800 rpm in gear.
Sure enough, if I put the car in park/neutral, the RPM's rise closer to 800 and the discharge is gone.
But back to my original point, my charging circuit isn't perfect as it still can discharge in a few cases but it is 500% better than the factory performance. It looks factory without having some huge GM alternator on my engine. So yeah, I can accept a slight (<10 amps) discharge when I have ALL my accessories on at idle in gear and yes, I consider that well-planned.
Re: Clutch fan VS electric fan [Re: cjskotni] #1468601
07/18/13 09:28 AM
07/18/13 09:28 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, that explains it.
Dummy down "well planned" till it fits your situation then call it good enough. Why don't you turn up your idle speed or get a smaller alternator pulley and fix your "well planned" setup.
Don't be the exception.
Re: Clutch fan VS electric fan [Re: Supercuda] #1468602
07/18/13 10:25 AM
07/18/13 10:25 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Wow tough crowd here.
So everything is a compromise, right? I don't want a giant honken obviously aftermarket alternator on my car. It would be wonderful to have a factory appearing alternator that put out 120 amps at idle but such a thing doesn't exist to my knowledge.
The discharge doesn't endanger my wiring or affect my drivability so I am satisfied with how it works for me. It is way better than factory which many people here deal with all the time.
So it's not 'dumbing down', it's your opinion that my setup isn't 'good enough' to be 'well-planned' apparently.
Also good luck finding a smaller double-groove pulley for the alternator.
Re: Clutch fan VS electric fan [Re: cjskotni] #1468603
07/18/13 01:25 PM
07/18/13 01:25 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Incredible...
Just my $0.02...
OK lets do a little caculation..
The mechanical fan draws 10 HP, and the alternator driving electric fans draws 8 HP so one loses 2HP..
Isn't that the advantage of a clutch fan, no draw when cruisin down the road..
If one needs 100 Amps than definitely an well-planned upgrade is required..
Just my $0.02...
Re: Clutch fan VS electric fan [Re: cjskotni] #1468604
07/18/13 05:09 PM
07/18/13 05:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There are are a multitude of modern alternators that are not big honking things out there. Your concern about stock appearing seems at odds with an electric fan setup but whatever.
It is not my opinion regarding a well laid out setup, it is a fact. You are still dealing with a discharge at idle. Something my 65 Cuda with it's STOCK charging system does NOT have, and yes I have AC too. If you cannot find a smaller alternator pulley, run a bigger crank pulley or bump up the idle speed a hair, well laid out can take many routes but one goal, no issues when you are done and you still have issues.
Re: Clutch fan VS electric fan [Re: HotRodDave] #1468605
07/18/13 05:45 PM
07/18/13 05:45 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I get chastised on this forum every time I disagree with that claim but there are cars that will overheat at road speed without a fan.
So you're saying those vehicles can never slow down or stop? Sounds like a replay of the movie Speed.
Re: Clutch fan VS electric fan [Re: cjskotni] #1468606
07/18/13 06:47 PM
07/18/13 06:47 PM
Cincinnati, Ohio
Cincinnati, Ohio
Incredible...
Just my $0.02...
I bet your right, that's why I run a mechanical clutch fan that has been bullet proof for me.
FWIW back in the 80s I had a 340 challenger that overheated. It was a black 72 without AC. That car was cursed and all my friends hated it because I also had starter issues and they had to push start me all the time and the car was black and hot.
After about a year of that non sense I figured out that the clutch was bad on my fan. After I replaced it my overheating went completely away.
Re: Clutch fan VS electric fan [Re: RangerDan440] #1468607
07/18/13 10:27 PM
07/18/13 10:27 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I kill me
Because there's to many clutch fan fans vs the electric fan fans...
Page 2 of 3 1 2 3
