Re: thinking about building a supercharged 440
[Re: Challenger 1]
#1468244
07/15/13 04:17 PM
07/15/13 04:17 PM
Posts: 27,588 So Cal
autoxcuda
So Cal
... and stroker cranks just add to the oil control problems strokers and blowers create. Boost slows oil draining to the pan. ...
I'm not familiar with blowers. Could you elaborate on oil control problems with strokers and blowers?
How does boost slow oil draining to the pan?
[Re: bigblockbryan]
#1468245
07/15/13 04:21 PM
07/15/13 04:21 PM
autoxcuda
So Cal
okay im thinking about building supercharged 440 for the 69 super bee clone my goal is 6-700 horse streetable with a manual trans also would it be a good idea to use a 500 inch stroker kit. From 440 source low compression forged internals this is a idea i wont be building a motor tell spring im going to get the body done first.
Are the 440 source parts designed to take 600-700 horsepower?
[Re: Challenger 1]
#1468248
07/15/13 05:04 PM
07/15/13 05:04 PM
autoxcuda
So Cal
It does just what I said, lot's of crankcase pressure with a blower. Ask 572dart if you don't believe me.
I was just asking. I know nothing about blower motors. I'm not much of a motor guy at all.
But I'm curious why the additional stroke would make things worse? Does it relate to the extra air volume under the piston inside the block displaced and/or additional piston speed?
[Re: dogdays]
#1468250
07/15/13 06:14 PM
07/15/13 06:14 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
600 - 700 hp can be had with a big NA motor without the weight or complexity of a blower.
600 - 700 hp is going to be all the stock block can take. It, not the 440Source kit, is going to be your limiting factor.
I don't believe the oil problem is as dire as has been painted. If you're going to put a blower on top of a stroker motor, better start with an aftermarket block. Then invest in some bigtime chassis stiffening or your Bee is going to twist the first time it hooks up well.
R.
600-700 N/A? not w/o a craaaaaap load of work and high $$$ parts, not to mention the crazy gear and convert you'd have to run to make it work. while a 600hp boosted motor would be calm as a kitten and you wouldn't need all the crazy internals of a high dollar race motor.
[Re: Mr.Yuck]
#1468251
07/15/13 06:54 PM
07/15/13 06:54 PM
Posts: 637 West Central Wi.
1969 HEMI R-T
West Central Wi.
I like the roots set ups. do it how you like. my cousin is building a 440 8-71 street car right now. it should make all of 600 Hp and will be a torque monster. should be done late this summer go for it!! love the 69 coronets!!
HEMI,S ARE FOREVER!!!
[Re: dogdays]
#1468256
07/16/13 03:36 PM
07/16/13 03:36 PM
Mr.Yuck
Brookeville, Md
http://www.popularhotrodding.com/tech/1007phr_big_block_mopar_engines/viewall.html
Doesn't seem like a crapload of parts to me and won't need an 8" converter. Make the engine bigger, like a 542, stick on a set of Indy heads and you're there. R.
making a 542ci wedge is a lot of work, it's not like that assembly will just drop in. You will also need a 630+ lift cam...not street friendy. The heads will have to be worked, and Indy heads aren't cheap to start with. Not to mention that motor was 12.5:1. Good luck running that on pump gas. Can it be done, sure but a boosted engine will be much easier to deal with. And cheaper in the long run.
