Re: So...you pop off the harmonic. What about installing?
[Re: Pyper70]
#1468079
07/16/13 10:07 PM
07/16/13 10:07 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I know you already have it installed but a harmonic balancer puller/installer from Pro-Form is one of my favorite tools. I don't use it often but it does work great.
68 Barracuda Formula S 340
[Re: JohnRR]
#1468080
07/16/13 11:13 PM
07/16/13 11:13 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
why risk thread damage to the crank when advance auto will-- loan-- the tool to do it right??
The problem is the OP is in GREECE ....
oh no ... this guy is a magician ,he is in 2 places at once and one of them will have the tool or he can just poof one from thin air with his special powers......... ![](/ubbthreads/images/graemlins/OzBBQed.gif)
[Re: ek3]
#1468081
07/17/13 09:09 AM
07/17/13 09:09 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
I've read more than enough of his posts , he may have 2 locations listed , why ??? , but he is in GREECE, I'm sure he had has a hard enough time finding SAE hardware ...
[Re: pushbutton]
#1468082
07/17/13 09:35 AM
07/17/13 09:35 AM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Go to your nut& bolt store and buy a longer bolt the same size as your balancer bolt buy a nut and flat washer for same. Screw in longer bolt and use nut with flat washer to push balancer on. Worked for me>
I'll definitely be going the longer bolt route next time.
The way I did it last time was to hammer (with wood) the balancer to the point where the threads somewhat engaged, then just keep torquing it in. It was a major PITA to hammer it that far on since I had no room.
As far as keeping the engine from turning, I just wedged a plastic-covered handle from a pair of pliers on the torque converter ring gear. I've always done it that way.
I do use anti seize in the balancer hub, and some on the area where the washer presses.
[Re: Exit1965]
#1468083
07/17/13 09:39 AM
07/17/13 09:39 AM
JohnRR
I don't like it on , it was how I used to do it , also using the bolt to pull it on and messed up the threads on a 340 crank.
I pulled the balalncer off a 440 that belonged to a friend years back and the hub was split down the keyway , didn't realize it till I went to pull off the pulley , crank bolt was off , and the pulley and balancer paint being stuck to each other with the pulley bolts removed was enough for the balancer to come off the crank .
I use the right tools now even though 100's of millions of people have done it millions of billions of times before the universe was created from the big bang ...
