So...you pop off the harmonic. What about installing?
#1468059
07/15/13 09:36 AM
07/15/13 09:36 AM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
I am going back to my buddy's place tomorrow with a deadblow hammer & 3 pulley extractors. I am gonna come back and sandblast the harmonic, prime, paint, affix the timing tape and let it cure. The engine is in the car. He has a 3 core aluminum radiator with dual fans.
I can clean up the crankshaft with emery cloth, put the key in. Should I put some anti-seize compound on the crankshaft area where it comes in contact with the balancer? I know I have wedged the flexplate on an engine stand build but I have never done it in a car. How do you guys reinstall the balancer to torque spec? Do I have to remove the radiator and run an impact on it?
Is there another industry trick that I haven't thought of?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: So...you pop off the harmonic. What about installing?
[Re: JohnRR]
#1468062
07/15/13 10:09 AM
07/15/13 10:09 AM
Pyper70
Athens, Greece
I think I have....the extractor....I think...it was a Lisle or a KB Tools... The rope is a great idea....would I be damaging anything by doing it this way? Will a valve be injured? The emery cloth...just to clean it up is all..its not a factory balancer. It was installed 350 miles ago and the paint flaked off and the timing marks went with it (I didn't recommend the balancer to him, but as usual, I am cleaning up someone else's mistake) but I can't dial his engine in without those markings and gluing it on temporarily isn't a solution for myself. I like to work on people's cars as if they were my own. Could I use a 1/2 x 20 bolt, slip on a nut, a washer, wheel bearing, and then crank it down against the harmonic? Tightening the nut to get it to go in? (I am just replicating the tool I just saw on Youtube) I wouldn't mind having the actual tool in my tool box as I like to collect the most obscure tools for jobs. Just nice to have it in case it ever comes up again This is the balancer he chose to installI just saw the address of the manufacturer of that harmonic...literally...SEVEN MINUTES from where I used to live and I have never heard of them....Makes you wonder
[Re: pushbutton]
#1468064
07/15/13 11:34 AM
07/15/13 11:34 AM
Pyper70
Athens, Greece
I found my harmonic extractor so thats good news...PowerBuilt..
I will buy some rope tomorrow morning and try that method for the prevention of the assembly rotating.
As for the installation tool....shouldn't I put a bearing between the harmonic and the tool...something needs to act like a buffer against the flange on the balancer...wouldn't the washer butting up against it have excessive friction?
[Re: Pyper70]
#1468065
07/15/13 11:42 AM
07/15/13 11:42 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
yes a bearing between the 2 would help.
This is a big block mopar if I remember right , the crank bolt is 3/4 - 16 ... fine thread .
[Re: Pyper70]
#1468066
07/15/13 12:03 PM
07/15/13 12:03 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Use some grease if you like. it wasn't a problem for me.
[Re: JohnRR]
#1468067
07/15/13 07:27 PM
07/15/13 07:27 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
They make balancer installers , but I guess that would be hard to come by where you are . To torque it you need to wedge something in the flex plate
this is what i've always done. poor man's budget shop!
[Re: Pyper70]
#1468068
07/15/13 07:35 PM
07/15/13 07:35 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
It is referred too as a balancer or a damper, not a harmonic.
You can use a longer bolt and a nut on one of the torque converter bolt holes. Use the nut to tighten the bolt down, the bolt head will stop against the block .
Anti-sieze is not a bad idea. I use it. However, I not heard of a iron/steel balanced hub freezing on the crank...Aluminum, that's another story, always use anti-sieze.
You don't need to do anything with the key, and you will be creating unnecessary work for nothing in messing with it, IMO.
You might be able to get the balancer started using a mallet and then the bolt, or use a longer bolt. I promise that this was the only way used for years by virtually every hobbyist for decades.
[Re: BSB67]
#1468069
07/15/13 07:49 PM
07/15/13 07:49 PM
Pyper70
Athens, Greece
I dunno...Always used the term balancer, damper and harmonic....semantics....
I found a rather interesting way...I am trying to avoid crawling under the car (her name is Christine) and even though I am not harming her...I would rather not be her first victim.
How about this picture below...starting the balancer on the keyway, cranking it down until the assembly begins to rotate...drop in a chain and bolt on the damper at the 10 o'clock setting....wrap the other end of the chain around the chassis or k-member and then cranking it down....the chain shouldn't move past the 1 o'clock position
[Re: JohnRR]
#1468071
07/15/13 08:04 PM
07/15/13 08:04 PM
Pyper70
Athens, Greece
I'll try the rope trick....if its by the numbers as you say it is...it shouldn't be a problem as its in the compression stroke
Every new trick is worrysome...hopefully afterwards I will wonder why I was so skeered of doing it in the first place
[Re: BSB67]
#1468072
07/15/13 10:53 PM
07/15/13 10:53 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
<snip!>..... You might be able to get the balancer started using a mallet and then the bolt, or use a longer bolt. I promise that this was the only way used for years by virtually every hobbyist for decades.
Yeah, I've done the dead-blow hammer (or wood block, etc) trick a bunch of times, too. It does work, if a bit scary (pulled threads in the crank snout are not a good thing.) Just be sure you have plenty of thread engagement before going to town.
[Re: ek3]
#1468074
07/16/13 09:06 AM
07/16/13 09:06 AM
JohnRR
why risk thread damage to the crank when advance auto will-- loan-- the tool to do it right??
The problem is the OP is in GREECE ....
[Re: JohnRR]
#1468075
07/16/13 11:29 AM
07/16/13 11:29 AM
Pyper70
Athens, Greece
I am here at the dudes house and I am looking at a spare damper from the same company...they accidentally sent two for the price of one...
the damper and the TDC and 90 degree marks do not match up with the MP timing tape I have...heck...even laying the timing tape at the TDC mark, there is a discrepancy at the 10 degree mark...There are two TDC lines...one says Street Hemi and the other one shows Race Hemi about 6 degrees after. I am obviosuly putting the timing tape on the Street Hemi mark. I have the #1 plug out and raised the piston up to where the distributor is firing. I am just un easy how the 0 and the 90 do not match up.
I am obviously going to put the tape with 0 degrees TDC on the Street Hemi TDC groove on the balancer. right??
[Re: dogdays]
#1468078
07/16/13 08:13 PM
07/16/13 08:13 PM
Pyper70
Athens, Greece
Rope trick worked like a charm...thanks for the tips on that.,...Now we are waiting on parts so I can put the Edelbrock on ride, and get her dialed in....
