Re: Rusty rocker arms, pushrods, rocker shafts...
[Re: magnum440d100]
#1467169
07/14/13 12:32 AM
07/14/13 12:32 AM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: Challenger 1]
#1467172
07/15/13 12:38 AM
07/15/13 12:38 AM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
So after starting on the heads, we noticed one casting was thicker. One side ended up being a 915(?) casting and the other was a 596 casting.
So we pulled my smogger 596 heads off the shelf and tore those down.
Besides needing stem seals, they looked 1000x better than those other ones. So valve stem seals on order, and they should be going together. Did some bowl work, cleaning up some boogers sticking into the ports. Just going to do a quick lap job, clean em up a bit. Hopefully they don't smoke.
Pics to come soon I hope. It takes a while to resize them on my phone. I miss my computer haha
Edit. How do I plug those ports? I'm thinking 1/4" drill, and a 1/4" 20 tap, with set screws. Anything else easier? Or CHEAPER lol do I need a special bit?
[Re: magnum440d100]
#1467173
07/17/13 02:12 AM
07/17/13 02:12 AM
magnum440d100
woodcrest, CA
Update. Reassembled the smogger heads. I wanted to post pics of the work, but my buddy is an old racer. Said he did some things not everyone knows about. We cleaned the ports and bowls up So here's the driver side when we started reassembly. New aprons/valve stem seals.
