Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: Michael Ecks] #1466872
07/14/13 08:17 AM
07/14/13 08:17 AM
Conway, SC
T2R9 Online confused
T2R9  Online Confused
Conway, SC
Nice work!
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466873
07/14/13 09:51 AM
07/14/13 09:51 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Like JohnRR said, it looks like I need to lengthen the flat bar with the slot as well.
Nice work , almost there.
the back of that slot needs to be against that post with the arm and linkage from the trans pulled all the way forward , that's what the spring that you don't have installed yet does .
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: JohnRR] #1466874
07/14/13 05:51 PM
07/14/13 05:51 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the kind words guys. I would feel a little better about it if it hadn't had taken me 3 hours to do it!!!
I have another problem/question. The lever arm on the transmission requires 1 3/4" of travel at the slotted bar to move it from it full forward position to the full rearward position but the carb only has 1 1/8" of throw.
Do you start by pushing the arm all the way forward or just letting it go back to its "home". When I measured the distance needed to move the lever from its "home" to the full reward position it's 1 1/8" (same as the carb).
Here is the lever after it's pushed all the way forward.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466875
07/14/13 05:52 PM
07/14/13 05:52 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Here it is at it's "home" (pushed rearward under tension then released).
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466876
07/14/13 05:54 PM
07/14/13 05:54 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
And all the way rearward.
Does the lever need to travel the entire distance (fully forward to full rearward)?
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466877
07/15/13 03:50 PM
07/15/13 03:50 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466878
07/15/13 04:04 PM
07/15/13 04:04 PM
JohnRR Offline
JohnRR  Offline
It doesn't need to go all the way rearward , within an 1/8" would be ok , 1/16" would be better. The back of the slotted rod must be against the stud when the throttle is at rest with the lever on the trans at it's full forward position , idle position , and begin moving as soon as the throttle starts moving all the way to full throttle.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: JohnRR] #1466879
07/15/13 04:21 PM
07/15/13 04:21 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
That's what I thought but I believe I have a lot more than 1/8" of travel left after I get the carb to full throttle. I didn't think to measure it but I'm guessing 1/4" or so...
I'll measure that tonight and post the results.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466880
07/15/13 07:57 PM
07/15/13 07:57 PM
JohnRR Offline
JohnRR  Offline
Can you adjust it any or is it at full adjustment ?
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: JohnRR] #1466881
07/16/13 01:49 AM
07/16/13 01:49 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
It was at full adjustment and I still needed ~3/4" movement in the lever but I bent the one piece rod to "shorten" it which moved the pivot point at the throttle bracket. After I did that I was able to get the full throw that I need (push lever forward, back of slot touching carb stud, push carb stud to full throttle and lever at trans moves to full rearward position).
Thanks JohnRR and all others that helped.
