Re: World VS INDY alum blocks
[Re: Bubba]
#146644
11/07/08 11:10 AM
11/07/08 11:10 AM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Oh there are some used ones out there...I sold one not to long ago myself.
[Re: B G Racing]
#146646
11/07/08 12:03 PM
11/07/08 12:03 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I agree Bob. I have used the Indy Maxx blocks and have had no issues with any of them. I personally like them. They are a good piece when used for their intended applications.
As far as KB goes, they made an excellent piece. BTW, I recieved a call the other day from a source that says KB may have been/ or going to be bought and moved to Iowa. Lets hope that is the case.
RIP Monte Smith
[Re: B G Racing]
#146648
11/07/08 12:34 PM
11/07/08 12:34 PM
Posts: 1,770 Pa
Wv68charger
Pa
[Re: Bubba]
#146651
11/07/08 12:40 PM
11/07/08 12:40 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Unfortunetly most of the ones I've came across are already 4.50" I was hoping more would show up before I buy a new Iron World Block.
That's what sleeves are for.And for WV Charger,BGR guys will be forming a line for you and Pap.
[Re: Bubba]
#146652
11/07/08 12:42 PM
11/07/08 12:42 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
BG, How do you find the finish machine work from Indy? (Not as delivered by you to customer, but right off the pallet?) I know the finish work ont eh KBs was always very good, or made very good by them at no cost to the buyer(on two occasions that I know of). I've seen indy heads first han. Are the blocks on par with them, or can they be run hard as delivered?
[Re: kens avenger]
#146654
11/07/08 12:45 PM
11/07/08 12:45 PM
B G Racing
Eighty Four, PA
Please.... No pissing matchs .. Just thoughts and what you've seen
No pissing match here.Indy has a great bunch of dealers and WDs right here on the site.
[Re: moper]
#146655
11/07/08 12:52 PM
11/07/08 12:52 PM
Posts: 659 Tampa Fl
kens avenger
mopar addict
mopar addict
Tampa Fl
Moper Mine came with a tag .. wash and assemble...we checked it.. some of it was off and I was mad at them to start .. so I didn't call back .. I was mad at them over a oil pan deal.. I have talked to Russ since then ..but what was off was the line bore and some of the finish hone.. would they have made it right like i said I didn't call back at the time
Remember in here some don't think you should have a Opinion.. sad fact..
[Re: kens avenger]
#146656
11/07/08 01:02 PM
11/07/08 01:02 PM
moper
Columbia, CT
Thanks Ken, That's what I'm curious about and the last Indy block I saw was when they had one of the prototypes on display...lol. A while ago...
[Re: kens avenger]
#146657
11/07/08 03:16 PM
11/07/08 03:16 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Please.... No pissing matches .. Just thoughts and what you've seen
Here is a thought at what I see. The indy lifter bore area looks superior to the world but when you look underneath how the skirt area is so much larger than the world block, is all that material needed to keep the block from moving around? All that material is in the valley area for a reason. . If the lifter bore valley was a true problem than world would have made it beefier.
[Re: B G Racing]
#146659
11/07/08 04:35 PM
11/07/08 04:35 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
The tight skirt area is a concern with stock and after market blocks.This is an area that traps oil around the rotateing assembly and cause a lot of oil to be thrown on the cylinder walls and cam.This area is the cause of some of the loss of oil pressure at the big end.The Indy wide pan blocks allows the oil to migrate further away from the rotateing assembly and returning to the sump quicker.
Thanks BG, I learn something new everyday
[Re: cudabunch]
#146660
11/07/08 06:47 PM
11/07/08 06:47 PM
B G Racing
Eighty Four, PA
We a constantly learning also,and are glad to pass on what we learn.As far as the blocks we get from Indy,they are quality and any changes we make are our decisions for our or our customers specific needs.As a end user or representative to the end user we are responsible for the products final state.We some times supply unfinished blocks to other builders.With that being said,since we don't live in a perfect world and crap is known to happen,we stand behind our work and Indy stands behind us on their product.What few and minor issues we have had in our almost ten year relationship has always been resolved satisfactorly and professionally.I don't see the issues of customer service that most complain of.From Carrie,Jim,Sam,Ken and Russ at Indy I can only say that they are friendly,curtious,helpful and professional in our busniess relationship.They meet our criteria of a great manufacture and supplier of products and BGR meets their criteria for a good customer,we use their products and pay our bills.I don't get any better than that.
[Re: cudabunch]
#146661
11/07/08 06:47 PM
11/07/08 06:47 PM
[Re: B G Racing]
#146662
11/07/08 08:12 PM
11/07/08 08:12 PM
Posts: 1,403 Columbus Ohio
Moore & Moore
Columbus Ohio
I agree. Most people think it is for stroke clearance. It will show about 15-20 horse on the dyno. Jack
