Re: Best carb and intake for my 440?
[Re: 82ramIndy493]
#1466004
07/11/13 05:35 PM
07/11/13 05:35 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I agree with the RPM or the Holley Street Dominator. The RPM is a very good street/strip intake. The Holley SD is a very good single Plane intake as it has good low end like a dual plane with good top end. I ran a SD on my old 440 and it worked very good. I now use the Indy dual plane which looks like the Performer RPM but with larger ports. Either the RPM or SD would work good as will the Indy dual plane intake. As for a carb I agree the 950 is a good carb. That said I use a standard Holley 850 DP which works good on my 63's 440/493. It would most likey go a bit faster with the 950 but this 850 works and drives great. Ron
