Re: Big block hydraulic roller cams OK to 7000 RPM? [Re: Streetwize] #1464792
07/11/13 02:07 AM
07/11/13 02:07 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Hey I'm not choosing sides but the technology gap is shriking quite a bit. LS motors in what the low 8's with juicers and turbo's
Here's one without juice or boost.
http://www.youtube.com/watch?v=ltYLS_KZQV8
Car was running in the 9's when I was at the school.
Re: Big block hydraulic roller cams OK to 7000 RPM? [Re: PorkyPig] #1464793
07/12/13 04:03 AM
07/12/13 04:03 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I was thing a hydraulic roller would be quieter too, but it seems to be just about as loud as a solid roller, or maybe I'm just hearing the roller rocker arms, rollerized timing gear, and roller thrust bushing?
I think a rev-kit where the springs press on the top of the lifter body would help if you want to run high RPM with a hydraulic cam?
Re: Big block hydraulic roller cams OK to 7000 RPM? [Re: 451Mopar] #1464794
07/12/13 10:24 AM
07/12/13 10:24 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I can't swear to anything in a big block but my Drag Pak Challenger has a hydraulic roller and you shift it at 7000. It also has very light springs. Big block valves would be heavier.
2011 Drag Pak Challenger
Re: Big block hydraulic roller cams OK to 7000 RPM? [Re: rickseeman] #1464795
07/12/13 10:40 AM
07/12/13 10:40 AM
gregsdart Offline
gregsdart  Offline
Time for a dyno test!! There is an article on a BBC motor, about 560 cubes? making 1,000 hp, and running hydraulic lifters. If those guys can do that, the Mope should be able to run 7,000 with the right parts. I would think a high ratio rocker would help significantly too.
