Re: Transmission cooler line question
[Re: Twostick]
#1464713
07/09/13 04:12 PM
07/09/13 04:12 PM
Posts: 205 Chicago,Illinois
nosboy
Chicago,Illinois
ANd I DID go to trans school !!!
Be that as it may, if you had paid attention in high school you would know that heat does not rise. Common misconception because hot air rises and most people's exposure to heat involves a furnace and a cold house.
Ever notice where they install industrial radiant gas heaters? Mostly on the ceiling pointed down. If your theory was true they wouldn't work very well.
Kevin
So you know.. FORD,, GM and MOPAR that use tanks on the SIDE of the radiator use the theory that the TOP of the radiator the HOT WATER / HOT TRANS FLUID ENTERS and at the bottom,,,, the cooled down water/coled down trans fluid exits... On a top and bottom tanked radiator,, the trans cooler is at the bottom and goes across the COOLER part of the radiator... THEORY all you want,, that's how the " BIG THREE'S" engineers figured it out.. You think your idea's smarter???? I THINK NOT !!!
[Re: Twostick]
#1464716
07/09/13 05:49 PM
07/09/13 05:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Heat rises... PERIOD.... look at a hot air balloon
The operative words being "hot air". Hot air rises. Heat goes where it's pointed. Heat is energy, it isn't a "thing".
http://www.pa.msu.edu/sciencet/ask_st/042496.html
Kevin
Exactly... heat rises... thats why a gravity furnaces were in the BASEMENT (heat)
[Re: Twostick]
#1464717
07/09/13 09:17 PM
07/09/13 09:17 PM
nosboy
Chicago,Illinois
Dude,,, the whole world runs trans fluid IN the top of the radiator and OUT of the bottom of the radiator... MOPAR and some Ford uses the COOLER side of the radiator ( bottom tank).. I don't really CARE what or where HEAT is DIRECTED,, the PROPER WAY is to PUT IT IN THE TOP and TAKE IT OUT OF THE BOTTOM.... Whatever way DETROIT ENGINEERING has a theory,,, the IN AT THE TOP and OUT at the BOTTOM is correct on MILLIONS OF AUTOMOBILES !!!! If you think they're wrong and YOUR IDEA IS RIGHT,, you're SADLY MISTAKEN ....
[Re: nosboy]
#1464718
07/09/13 10:04 PM
07/09/13 10:04 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
In my eyes it comes out of the bottom of the radiator because it acts as a sump..can't pump water from the top of the radiator, if there is any air in there......and a cooler should be pushed from the bottom so the entire cooler will be used instead of dropping the fluid into the cooler from the top.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: nosboy]
#1464720
07/09/13 11:46 PM
07/09/13 11:46 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
the cooled fluid goes into the pan....
well not exactly, on a TF the cooled fluid first goes to the rear support, output shaft, the rear drum, planets and sun gear before returning to the pan. But that is if you want to be technical. LOL
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1464721
07/09/13 11:52 PM
07/09/13 11:52 PM
dusturbd340W5
Kissimmee Fl.
on a side note I spent almost 30 years in the transmission industry, I have run every kind of cooler and line set up you could imagine, had temp gauges on all kinds of vehicles and cant say I seen any real difference in temps 1 way or the other based on line position. That's just my
[Re: rickraw]
#1464723
07/10/13 08:26 AM
07/10/13 08:26 AM
Posts: 2,375 west palm beach, florida
modelmakerinc
Wow, this thread became a bit bumpy, I am surprised by the topic, that it got a little heated (lol) The fluid slows down at the entry and through the cooler because of line size, the 5/8" tube takes twice the amount of fluid volume for any given distance as the 5/16 line. Think of it like squeezing a garden hose, with x amount of pressure water flows smooth, make the outlet smaller makes more pressure less volume. when you squeeze more volume into a smaller line the pressure increases. In my opinion the differences in temp from top/bottom -in/out are negligible. If you are adding a cooler to a stock system, it is important to run the front line into the radiator first then to the auxiliary cooler and back into the rear line. If you are using only an auxiliary cooler, in and out doesn't matter as much as size and cooling fan capabilities. my Street/Strip Coronet front line into the lower cooler inlet.
[Re: Sweigart1022]
#1464727
07/10/13 06:17 PM
07/10/13 06:17 PM
MR_P_BODY
So yea before this got out of hand as to whose house is heated better. You run the front line out of the transmission to the bottom of the cooler?
Thats the way I do it
[Re: nosboy]
#1464729
07/11/13 05:37 PM
07/11/13 05:37 PM
dusturbd340W5
Kissimmee Fl.
and we all know that engineers are perfect and there way is the only way it will work.
[Re: rickraw]
#1464731
07/11/13 07:48 PM
07/11/13 07:48 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I just gotta get in to this little debate. Not only does hot air rise but heat rises. Those overhead LP gas heater reflect the heat. Little different and not good for an example.
An old tractor or truly antique car. No water pump. How does it work. The hot water rises in the block. The hot water cools in the radiator and flows right out the bottom back into the block. No pump just heat or loss of heat making the water flow.
Leon
