Page 2 of 3 1 2 3
Re: Transmission cooler line question [Re: Twostick] #1464713
07/09/13 04:12 PM
07/09/13 04:12 PM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
ANd I DID go to trans school !!!
Be that as it may, if you had paid attention in high school you would know that heat does not rise. Common misconception because hot air rises and most people's exposure to heat involves a furnace and a cold house.
Ever notice where they install industrial radiant gas heaters? Mostly on the ceiling pointed down. If your theory was true they wouldn't work very well.
Kevin
So you know.. FORD,, GM and MOPAR that use tanks on the SIDE of the radiator use the theory that the TOP of the radiator the HOT WATER / HOT TRANS FLUID ENTERS and at the bottom,,,, the cooled down water/coled down trans fluid exits... On a top and bottom tanked radiator,, the trans cooler is at the bottom and goes across the COOLER part of the radiator... THEORY all you want,, that's how the " BIG THREE'S" engineers figured it out.. You think your idea's smarter???? I THINK NOT !!!
Re: Transmission cooler line question [Re: nosboy] #1464714
07/09/13 05:09 PM
07/09/13 05:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Heat rises... PERIOD.... look at a hot air balloon
Re: Transmission cooler line question [Re: MR_P_BODY] #1464715
07/09/13 05:30 PM
07/09/13 05:30 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The operative words being "hot air". Hot air rises. Heat goes where it's pointed. Heat is energy, it isn't a "thing".
http://www.pa.msu.edu/sciencet/ask_st/042496.html
Kevin
Re: Transmission cooler line question [Re: Twostick] #1464716
07/09/13 05:49 PM
07/09/13 05:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Kevin
Exactly... heat rises... thats why a gravity
furnaces were in the BASEMENT (heat)
Re: Transmission cooler line question [Re: Twostick] #1464717
07/09/13 09:17 PM
07/09/13 09:17 PM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
Dude,,, the whole world runs trans fluid IN the top of the radiator and OUT of the bottom of the radiator... MOPAR and some Ford uses the COOLER side of the radiator ( bottom tank).. I don't really CARE what or where HEAT is DIRECTED,, the PROPER WAY is to PUT IT IN THE TOP and TAKE IT OUT OF THE BOTTOM.... Whatever way DETROIT ENGINEERING has a theory,,, the IN AT THE TOP and OUT at the BOTTOM is correct on MILLIONS OF AUTOMOBILES !!!! If you think they're wrong and YOUR IDEA IS RIGHT,, you're SADLY MISTAKEN ....
Re: Transmission cooler line question [Re: nosboy] #1464718
07/09/13 10:04 PM
07/09/13 10:04 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
In my eyes it comes out of the bottom of the radiator because it acts as a sump..can't pump water from the top of the radiator, if there is any air in there......and a cooler should be pushed from the bottom so the entire cooler will be used instead of dropping the fluid into the cooler from the top.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Transmission cooler line question [Re: instigator] #1464719
07/09/13 11:32 PM
07/09/13 11:32 PM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
you're not dropping the fluid into the cooler.. the cooler actually has to SLOW DOWN the fluid and has to keep a pressure at the TOP OF THE COOLER because it takes some time for the heat to be removed from the fluid. the SLOWER the fluid goes through the cooler,, the BETTER !!! The HOT fluid comes from the pump/ convertor and the cooled fluid goes into the pan....
Re: Transmission cooler line question [Re: nosboy] #1464720
07/09/13 11:46 PM
07/09/13 11:46 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
well not exactly, on a TF the cooled fluid first goes to the rear support, output shaft, the rear drum, planets and sun gear before returning to the pan.
But that is if you want to be technical. LOL
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Transmission cooler line question [Re: dusturbd340W5] #1464721
07/09/13 11:52 PM
07/09/13 11:52 PM
Kissimmee Fl.
Kissimmee Fl.
on a side note I spent almost 30 years in the transmission industry, I have run every kind of cooler and line set up you could imagine, had temp gauges on all kinds of vehicles and cant say I seen any real difference in temps 1 way or the other based on line position.
That's just my
Re: Transmission cooler line question [Re: dusturbd340W5] #1464722
07/09/13 11:53 PM
07/09/13 11:53 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
That is correct. I'd like to know how the cooler slowes the fluid down. My cooler has, i beleive, has 5/8" tubes, no orfice in the lines. Wonder how that happens?
Re: Transmission cooler line question [Re: rickraw] #1464723
07/10/13 08:26 AM
07/10/13 08:26 AM
west palm beach, florida
modelmakerinc Offline
Wow, this thread became a bit bumpy, I am surprised by the topic, that it got a little heated (lol)
The fluid slows down at the entry and through the cooler because of line size, the 5/8" tube takes twice the amount of fluid volume for any given distance as the 5/16 line.
Think of it like squeezing a garden hose, with x amount of pressure water flows smooth, make the outlet smaller makes more pressure less volume.
when you squeeze more volume into a smaller line the pressure increases.
In my opinion the differences in temp from top/bottom -in/out are negligible.
If you are adding a cooler to a stock system, it is important to run the front line into the radiator first then to the auxiliary cooler and back into the rear line. If you are using only an auxiliary cooler, in and out doesn't matter as much as size and cooling fan capabilities.
my Street/Strip Coronet front line into the lower cooler inlet.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Transmission cooler line question [Re: modelmakerinc] #1464724
07/10/13 01:27 PM
07/10/13 01:27 PM
Lancaster, Pennsylvania
Sweigart1022 Offline OP
So yea before this got out of hand as to whose house is heated better. You run the front line out of the transmission to the bottom of the cooler?
Re: Transmission cooler line question [Re: Sweigart1022] #1464725
07/10/13 02:17 PM
07/10/13 02:17 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
That will work just fine, just make sure you can get air flow across it.
Re: Transmission cooler line question [Re: dartman366] #1464726
07/10/13 04:29 PM
07/10/13 04:29 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Any more we mount the cooler under the car so that air flows all around it.On coolers with fans we have mounted them to the rear of the car also.Some of the best coolers like for street driving(street rods)are mounted on the frame rails.
Re: Transmission cooler line question [Re: Sweigart1022] #1464727
07/10/13 06:17 PM
07/10/13 06:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the way I do it
Re: Transmission cooler line question [Re: Sweigart1022] #1464728
07/11/13 09:46 AM
07/11/13 09:46 AM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
The BIG 3 ( Ford, GM and Chrysler) ALL plumb the FRONT ( fluid output) side to the TOP of the radiator trans cooler and the BOTTOM ( return) goes back to the transmission REAR inlet.. THEY ALL DO IT THAT WAY !!! Theory all you want,,, that's how the DETROIT engineering people FIGURED IT OUT !!!.
Re: Transmission cooler line question [Re: nosboy] #1464729
07/11/13 05:37 PM
07/11/13 05:37 PM
Kissimmee Fl.
Kissimmee Fl.
and we all know that engineers are perfect and there way is the only way it will work.
Re: Transmission cooler line question [Re: dusturbd340W5] #1464730
07/11/13 05:45 PM
07/11/13 05:45 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
The op never mentioned if he was going to use the rad cooler or not. That would make a difference.
Re: Transmission cooler line question [Re: rickraw] #1464731
07/11/13 07:48 PM
07/11/13 07:48 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I just gotta get in to this little debate. Not only does hot air rise but heat rises. Those overhead LP gas heater reflect the heat. Little different and not good for an example.
An old tractor or truly antique car. No water pump. How does it work. The hot water rises in the block. The hot water cools in the radiator and flows right out the bottom back into the block. No pump just heat or loss of heat making the water flow.
Leon
Re: Transmission cooler line question [Re: Leon441] #1464732
07/11/13 08:18 PM
07/11/13 08:18 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
You guys are confusing issues here...
First of all heat DOES NOT RISE. There is nothing special in "heat" that makes it defy gravity.
The reason a hot air baloon rises is because when the air is heated, it expands and becomes less dense. The lower density air "floats" on the high density air. So the hot air goes "up".
Same thing happens in fluids. The hot fluid expands and is less dense, and therefore rises.
Heat through a solid body does not cause any change in density. Solid fins on a trans cooler do not change position. Nothing is "flowing" like happens in air or fluid.
The reason that radiators flow trans fluid from bottom is because of a principal called counter current heat exchange. This is because the hottest water can cool the very hot trans fluid effectively. The trans fluid can only be as cool as the last point of coolant temperature that it exits. It's more effective if it exits at the lower point where it's coldest.
The question at hand about trans fluid through a normal (non-coolant heater exhange like a radiator) does not apply to "heat rises" or "the OEM did it like this."
The direction on a finned fluid to air cooler does not matter at all.
Page 2 of 3 1 2 3
