Re: UPDATE- 2nd outing with 408, mph still way low
[Re: Just-a-dart]
#1464572
07/13/13 01:33 AM
07/13/13 01:33 AM
Posts: 3,433 Toronto
mshred
Toronto
My Take the time to work out the bump steer. You will be happy you did.
Find a old Direct connection chassis manual there is alot of good info in there with examples.
I suggest you buy a caster/camber gauge and do it yourself on your garage floor and are not tying up someones rack that is in a hurry.
I am going to try and do it myself just as I did the other times. I do it at my buddy's shop on saturdays when he is not open that way I am doing just that, not tying up his wrack.
I am not too fond of heating up and bending steering knuckles though as outlined in the manual. I spoke with Chuck Lofgren who makes a kit to relocate the tie rod ABOVE the knuckle to reduce toe in and bumpsteer, but getting under my car it looks like tie rods above the knuckle will give me some serious header clearance issues
So now im not sure where to go with this...And im worried that when I add more positive caster im going to increase even more the toe in effect if I am understanding the suspensions travel correctly.
[Re: dvw]
#1464573
07/13/13 01:36 AM
07/13/13 01:36 AM
mshred
Toronto
By the looks of it your outer tie rods are too high. If you can add more positive caster it will help. My bet is there isn't any more adjustment left. When I get back from vacation I'll take some pics of my fix. Mine had .750" toe-in through 5.50" of travel. Now it has less than I can measure. It didn't help my ET at all. I still think your converter is the culprit. Doug
So your saying that my outers need to be closer to the ground? The way I have understood this is that in order to reduce bumpsteer you want the tie rods to be as level or straight as possible. So increasing positive castor will drop the outer tie rod end down, which seems like it would only create worse issues with bumpsteer, not better.
If you could post pics about what you mean that would be great. As I said in the post above, my headers are pretty close to the tie rods if I wanted to relocate them above the knuckle.
Im almost wondering if I should just set the toe at 1.5"-2" of front end rise with me in the car, and not worry about what it is at rest or any other level or rise/rest?
[Re: moparniac]
#1464574
07/13/13 01:39 AM
07/13/13 01:39 AM
mshred
Toronto
mshred here is a chart below some say to go by... I'm still sorting my car out also. Like you I had many issues going on.. as far as suspension I worked a lot of overtime and just wanted new stuff is all.. modified stock K with dillinger tubular goods and going coil overs with afco DA's. uppers have 5* positive caster built in also and my lowers have adjustability also(can see spacers in pic). I can adjust bumpsteer also. peopel say the factory stuff is good but I was tired of messing with old greasy stuff... front tires are cheap and I want the ET :P
Thanks for that chart sledge! I currently have about 2-2.5 degrees positive castor, but have been told to add more, although it seems it would throw my tie rod angles even more outta wack.
Your front end is looking really nice and shiny man! I like it! I do want to ask you though, how are you achieving ideal bumpsteer with the tie rod under the knuckle? and what is that threaded piece stick out from the bottom of the outer tie rods?
[Re: mshred]
#1464575
07/13/13 01:49 AM
07/13/13 01:49 AM
dartman366
Mt. Vernon, Ohio
Here ia where my tierods ended up after setting the bumpsteer my self,,took it to a local chassis builder and he made the final adjustments and the spacer's ended up just a hair shorter and he also added a safty washer under the tierod end in case of failure and told me that I actually had it pretty close, but not close enough for his standard's.
[Re: mshred]
#1464576
07/13/13 06:54 AM
07/13/13 06:54 AM
Posts: 419 NY
F1Scamp
NY
Don't overthink it. Set the toe to where you want it at the approx. height and weight it goes down the track. I set mine with the front end up around 3", I also have around 6 degrees of positive caster with the stock stuff.
So as long as the toe is good at the ride height you are at going down track, you should be fine?
With that much positive caster, you didn't find it hard to achieve the toe setting you needed? Do you know what your toe is like at rest with it set up for 3" of front end travel?
My car is a street car, so I don't want to have issues with toe while cruising around...killing tires wont be fun
It will be a ton better than you have it now for sure. I bent the lower control arm and the balljoint some to get mine to stay as straight as possible, but that was mostly because I was chasing a caster number. When it lifts through the suspension range I have less than a half degree camber change and very minimal toe. It took a full day on the alignment rack. You are chasing an issue, and if it were me, I would set the toe a couple inches up to ensure that's not taking any mph away. Take the time when you get the rest figured out to go through it properly. Oh and my on that issue is you have a lot more motor than me, get that converter out of the car, it is laying on it way too much.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
[Re: dartman366]
#1464577
07/13/13 07:49 AM
07/13/13 07:49 AM
Posts: 9,982 MI, usa
dvw
MI, usa
Mine looks similar to this but my spacers are way shorter. Yes you can set the toe in the raised position, but. Remember at the big end when you hit the brakes and the nose dives it's going to toe out. When I did mine spacing the tie rods too far made it worse than when I started. Think of the tie rod and the lower control arm arcs. They should form a parallelogram. Same length and pivot angles. It can be a time consuming process. Mine drove fine at 145mph before correction. It drives fine now also. I didn't see a huge increase in performance. Before correction it had .75" of toe in at 5.5" upward travel. Not saying don't fix it, but it's not the reason your going slow. Doug
[Re: 408Dust]
#1464579
07/13/13 11:39 AM
07/13/13 11:39 AM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
You guys have him chasing the wrong rabbit, bump steer is not the reason why the car leaves like a rock.Make the car 60ft first then fix the other issues.
Yep......
I still say the convertor isn't right, and no way I would run a heavy N/A small lock like this one is without the cam advanced 4 degrees( or maybe more) from the straight up way it's installed. I definately think it's suspect, and or the cam is flat wrong. I remember a few years back running a 107 LSA cam installed at 104 in my car. A certain cam " guru" who used to post on here told me a 112 LSA cam would pick my car up. Long story short it never got closer than 12 hundreds to my original cam, and get doggy and " numb" coming out of the gate Both the convertor and cam/ cam install point are off in the OP's car, and the video shows it.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: B3422W5]
#1464580
07/13/13 12:29 PM
07/13/13 12:29 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Yep......
[Re: VernMotor]
#1464581
07/13/13 12:38 PM
07/13/13 12:38 PM
Quicktree
Yep......
[Re: Quicktree]
#1464583
07/13/13 02:20 PM
07/13/13 02:20 PM
Posts: 11,702 W. Kentucky
justinp61
W. Kentucky
Yep......
The first thing I'd do is advance the cam at least 4*. It would be interesting to see a log of the rpms during a run.
My car is a little lighter 3260# and my heads flow just a little more, 293 on Curtis Boggs bench. Biggs 950hp, Victor intake 10.9-1 compression, 4.10 Dana on 28" tires, 727 with a $450 9.5" 5000 converter. The cam I have is a flat solid 260/264, .628/.633 in at 102*, it's ground on 106*. In great air on radials it's been 1.38 several times and low 1.40s in decent air and track conditions. In the heat on slicks 1.47 with a lean pop at the leave. In in good air it's been 104 in the 1/8 and 100 in the heat.
[Re: sshemi]
#1464584
07/13/13 02:53 PM
07/13/13 02:53 PM
B3422W5
Portage,michigan
I dont think adv the cam will gain about 4 mph witch i think its whats missing. All it will do is make the power curve lower.
You wont know until you get everything about the combination correct, or way closer to correct. Convertor and cam are just two of the pieces to this puzzle which definitely need immediate attention.
I agree, the basic combination has a chance to go 121-122. The cam being 251@ 50 is REALLY small for a 4 inch stroker motor. I ran one that was 260@ 50 on an eddie 416 with only a little more compression and even that weezed at the big end. 251@ 50 is more suited to a stock stroke motor with these heads and this compression.4 inch motors chew up a ton of duration. Hensley initially specced a 248/258 crane flat tappet on my first 416 with eddies they screwed together for me, and I couldn't get it to run any better than 114 mph. After cam( to the 260/266) and convertor swaps and a few more tweaks I got it to run almost 124mph ultimately with the same gear, heads, tranny, intake, etc. I think a correct convertor will help the car 60 foot better and a correctly specced cam will help in both 60 foot and mph...right now the combo doesn't have either going for it and thus runs where it currently does, not terrible, but certainly not where those heads should be able to push it to.
[Re: B3422W5]
#1464585
07/13/13 03:07 PM
07/13/13 03:07 PM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
You think it needs 260@ .050 with 10:1? In a heavy car? The car leaves soft already, even if he advanced the cam it won't cure the soft leave OR mph...
He'll get it worked out...I don't have much problem spec'ing cams and this one is no different. I have several other 408's with this cam running 121-122mph with same heads and compression. It ain't the camshaft or cam timing. Brian
Brian Hafliger
[Re: Brian Hafliger]
#1464586
07/13/13 03:18 PM
07/13/13 03:18 PM
Posts: 2,128 sweden
sshemi
sweden
Thats what i ment. I dont think its the cam.
#1464587
07/13/13 03:20 PM
07/13/13 03:20 PM
Quicktree
Brian what do you think is holding it back?
[Re: 408Dust]
#1464590
07/13/13 09:29 PM
07/13/13 09:29 PM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
At this point Quick, I'm not really sure. I've dyno'd his exact build with the exception of an RPM airgap intake, 950HP carb and less porting that made 521HP and 527TQ. I've got a couple of guys running A body street cars with 4.10 gears and 904/727 with a 9.5" converter running 10.90's at 121-122mph with 1.5x 60ft's. So I'm stumped too, cause they're all running same basic combo, same cam, etc... Those guys are also running TTI headers, vs. Matt's Hookers...but none of them are running transbrakes and 2 steps. I know my car picked up 1.5 mph by sealing the scoop to the carb, and that got my car into the 121mph range with a 360 that made right at 500HP and 450TQ. To me it seems the engine is down on power but not sure why. There really seems to be 2 things wrong...mph and the launch. They could be connected, say if the converter was bad, but that would be the first time I've seen a brand new A1 vert go bad! I agree the car leaves way too soft, I'm just not sure if the low mph is connected to that or a separate deal. If Matt's converter really slips 6%, to me that sucks. Mine slips 3%. Don't get me wrong, there is a lot of great advice been given in this thread, but some is down right incorrect. I agree a dyno session could be worth a lot and I recommend it to anyone that is serious about finding power and learning to tune their engine. Thing to remember is Matt's young and has a learning curve with the whole car, not just the engine so try to remember that as you give him advice. Brian
Brian Hafliger
#1464591
07/13/13 11:15 PM
07/13/13 11:15 PM
Posts: 3,547 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I agree as well. Dyno the engine. THEN you also have MUCH BETTER information to make a comverter decision. Its time to stop chasing your tail.
RIP Monte Smith
