Re: Overheating? 'Tis the season. Read before posting. [Re: RapidRobert] #1463516
05/27/14 04:52 PM
05/27/14 04:52 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Old video but a good refresher on a cooling system. Maybe a good basic training tool for newbies...
http://www.youtube.com/watch?v=uPGUtBCcQeA
Re: Overheating? 'Tis the season. Read before posting. [Re: WyleECoyote] #1463517
05/27/14 05:25 PM
05/27/14 05:25 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
For checking coolant condition and system corrosion resistance, perform a simple electrolysis test.
ground negative side of voltmeter and dangle postive side in the coolant. Should be no more than .3 volts or 300 mV.
76.8 mV is the reading here:
Re: Overheating? 'Tis the season. Read before posting. [Re: autoxcuda] #1463518
05/27/14 05:35 PM
05/27/14 05:35 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Anti Freeze mix itself only raises the boiling point 13 degrees at a 50/50 mix. And only 8 degrees at 30% mix.
Your radiator pressure cap that raises the boiling point 48 degrees with a 16 lbs radiator cap.
Check your radiator cap performance and system for pressure leaks! Much more important in regards to overheating than anti freeze.
Re: Overheating? 'Tis the season. Read before posting. [Re: autoxcuda] #1463519
05/27/14 05:50 PM
05/27/14 05:50 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The heat capacity is basically how much heat energy the coolant can carry out of the engine and to the radiator.
As far as carrying heat goes, water does a really good job. It’s actually one of the most effective coolants that could possibly be used.
The specific heat capacity of ethylene glycol is only about 65% of water at the temperatures seen in a cooling system.
Re: Overheating? 'Tis the season. Read before posting. [Re: autoxcuda] #1463520
05/27/14 06:51 PM
05/27/14 06:51 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
If you choose to run staight water to get a little extra help in cooling. Use water without the minerals. Like Reverse Osmosis or Distilled.
Then run a cooling system addtive that reduces electrolysis, anti corrosion, reduces surface tension, neutualizes pH.
All additive will reduce the boiling point some too as they car chemical solutes in the waters (8th grade chemistry)
Here's a very throrough performance test of cooling system additives:
http://www.turbomagazine.com/features/0703_turp_cooling_system_additives/viewall.html
Table of results:
Re: Overheating? 'Tis the season. Read before posting. [Re: autoxcuda] #1463521
05/27/14 07:13 PM
05/27/14 07:13 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
You were the one who had something going with the Justice Brothers, weren't you?
- Stu Harmon
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1463522
05/27/14 07:30 PM
05/27/14 07:30 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes, for the last 10 years I've worked for them www.justicebrothers.com . And that and my Engineering degree is where much of the technical training on this subject comes from. Please don't hold it against me if the product I sell works. That magazine did the test.
The basic principles here apply to any cooling system no matter what the performance of the product you choose to put in it.
You can see boiling point is most all dictated by the radiator cap.
IMHO, typically the next important thing is air flow (fan shroud) IF already the radiator is big enough and system has good flow.
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1797235
04/07/15 11:50 AM
04/07/15 11:50 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Bumping this to the top again for the 2015 overheating season.
- Stu Harmon
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #2679070
07/19/19 12:15 PM
07/19/19 12:15 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
People are still overheating in 2019.
- Stu Harmon
Re: Overheating? 'Tis the season. Read before posting. [Re: 70Cuda383] #2679146
07/19/19 04:12 PM
07/19/19 04:12 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Originally Posted by 70Cuda383
My 69 VW Bug keeps overheating, should I flush my radiator?
<img src="/ubbthreads/images/graemlins/hammer.gif" alt="" />
great post kevin.
I used a pump from a Super Beetle it has a Large S on the front and RED CAPE
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
