Re: Upper Control Arm
[Re: dawgfather]
#1461409
07/01/13 08:56 PM
07/01/13 08:56 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
They unthread.Its easier if it bolted to the car.A special socket is needed to remove them.Year and make would help.Rocky
Chrysler Firepower
[Re: therocks]
#1461410
07/01/13 11:26 PM
07/01/13 11:26 PM
RapidRobert
What Rock said, with everything undone unscrew the upper ball joint while the UCA is still installed in the frame, same thing when you install the new ball joint, do it with the UCA installed in the frame with the cam bolts/nuts. Need the special socket & a breaker bar. Might be able to get by with large pliers but for a first time deal you'd be ahead to get the socket
[Re: RapidRobert]
#1461411
07/02/13 10:35 AM
07/02/13 10:35 AM
therocks
Niles , Ohio
Lots of penetrating spray also.That and when installing the new BJ make sure it goes in straight and tightens.I use a good impact to break mine loose.If you arent sure about it any good machine shop can do them.Its usually about 15 to 20 bucks a side.Rocky
Chrysler Firepower
[Re: therocks]
#1461412
07/02/13 10:42 AM
07/02/13 10:42 AM
Posts: 295 Spanaway, Washington State
patosmith
I did mine off the car and had a heck of a time. I used the special socket and an air impact driver to get them off. Then do like he says above.
[Re: Stanton]
#1461416
07/02/13 09:51 PM
07/02/13 09:51 PM
therocks
Niles , Ohio
A good impact will take them out.Ive done a bunch in the last 40 years.they also cut threads when reinstalled.Rocky
Chrysler Firepower
[Re: 340SHORTY]
#1461418
07/03/13 02:06 AM
07/03/13 02:06 AM
Posts: 42 san francisco
dawgfather
san francisco
ok here is the picture as promised and I am pointing at the part that I think you guys are saying to put the wrench to and unscrew. let me know if I am pointing at the wrong place
[Re: dawgfather]
#1461419
07/03/13 08:34 AM
07/03/13 08:34 AM
Posts: 13 MN
ebodykid
MN
yup, you need a tool similar to this balljoint removal tool.. Unless you have a lot of time to spare, i'd order it from somewhere else... I had ordered it from PST, and it took a while to get to me..
[Re: dawgfather]
#1461420
07/03/13 08:38 AM
07/03/13 08:38 AM
therocks
Niles , Ohio
You are correct.That is the upper ball joint.As said you need the special socket.Some stores have the tool to loan.You will need a breaker bar and probally a pipe to get it out.Might be cheaper and easier to have a shop do them.Especially if you dont have some quality tools.The socket sell for around 30 bucks.I suggest you buy a factory service manual also.They are well worth the cost.I have them for all the cars we have.Rocky
Chrysler Firepower
[Re: AAR#2]
#1461422
07/03/13 10:33 AM
07/03/13 10:33 AM
therocks
Niles , Ohio
Those dont look too bad.Some of the worst I did was my 66 Imperial and the kids Express truck.Rocky
Chrysler Firepower
