Re: Little blown 410 sb mopar... [Re: DakFink] #1460126
06/30/13 12:56 PM
06/30/13 12:56 PM
Az
Crizila Offline
Crizila  Offline
Az
I've always been a FAN of Centr. Blowers.
BUT belt slip is a BIG issue when pushing for much over 12psi.
Unfortunately hardly anyone makes a pulley setup for a fully optioned (A/C, PS, etc) street Mopar application that will hold anything passed 10-12psi.
There are a few Cog Drive systems out there that will hold some serious boost but built only for LA based small blocks and limited accessories
Yes, belt slippage is an issue. Ya gotta runem TIGHT!! Per Procharger, with very little or no belt tensioner free play.
Fastest 300
Re: Little blown 410 sb mopar... [Re: Crizila] #1460127
06/30/13 01:17 PM
06/30/13 01:17 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Would a cog belt system be the answer or is there a reason why I don't see it being commonly used?
In all the pics I see of these setups it appears the blower hangs a long ways away from the motor- like out to the fender aprons- is there a reason why it's out there so far?
Re: Little blown 410 sb mopar... [Re: Crizila] #1460128
06/30/13 01:17 PM
06/30/13 01:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you can buy a kit for a BBC and make it work for about 1/2 what a mopar kit would run. AMHIK.
Re: Little blown 410 sb mopar... [Re: Brian Hafliger] #1460129
06/30/13 02:01 PM
06/30/13 02:01 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Pretty cool.
That was interesting to watch for a bit. Looks like you got stuff sorted out! When I left it was making 5-6psi and 500+tq at 3K.
Gonna be a wild ride.
BIG BIG thank you to Rob for bailing me out once again. Our fuel pressure guage in the dyno room broke and I needed it to reference our dyno digital guage so Rob ran home and found me one and brought it back so we could continue.
Much much appreciation Rob...thank you!
No problem. Any time.
It was cool to see it running.
Re: Little blown 410 sb mopar... [Re: Mr.Yuck] #1460130
06/30/13 02:01 PM
06/30/13 02:01 PM
Az
Crizila Offline
Crizila  Offline
Az
If you stay under 20 psi, the rib belts system will work - if you keep it tight. With a 4" pulley, I can make 15 lbs of boost @ 5K and over. 3.7" blower pulley can get you over 20 lbs, but belt tension and slippage becomes an issue. I run a much bigger carb than the OP. Simply because my 950 Prosystems carb was on my NA motor and when I went blown, I just sent it back to them for blow through Mods. Came back with very large annular boosters, so I'm sure it doesn't flow 950 CFM anymore.
Fastest 300
Re: Little blown 410 sb mopar... [Re: 72demon416] #1460131
06/30/13 08:36 PM
06/30/13 08:36 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Biggest 2 problems is clearance in front of the engine and COST of the pulleys and Belt.
I've been working on a Cog drive for mine (off & on) and a 55mm pulley adds 2.5-3 inches to the front of the engine at the crank and everywhere else you need a pulley. As well as the S/C itself.
The Belts are pricey if you don't know where to go. Usually $150+ each through the usual suppliers. I got mine for $80 through a local Industrial Supply house. Took Vortech's Base P/N and cross referenced it through Gate's own belt finder and got the Length I needed which was a Little longer than what Vortech had to offer.
Reason you see many of them hanging out the side is most Bracket kits were made for an application that accommodated full accessories. and May not have even been for that particular motor. Or even the route I thought I was going to have to go and move the S/C out to accommodate the length of the available belts.
Re: Little blown 410 sb mopar... [Re: Mr.Yuck] #1460132
06/30/13 08:37 PM
06/30/13 08:37 PM
DakFink Offline
DakFink  Offline
Good to know!!
Re: Little blown 410 sb mopar... [Re: Crizila] #1460133
06/30/13 08:41 PM
06/30/13 08:41 PM
DakFink Offline
DakFink  Offline
They going to supply new Main Bearings and a S/C rebuild with that advice?
I have seen more than a FEW with pre-mature main bearing and S/C pulley shaft wear from tightening all the play out of the belt and pulleys.
The side load on the crank and the S/C itself become an Issue.
On a Race Car I say go for it!!!! You will have it apart and freshened at the end of the year anyways. Probably not going to hurt anything.
BUT a street rod????
Re: Little blown 410 sb mopar... [Re: Brian Hafliger] #1460134
06/30/13 08:46 PM
06/30/13 08:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
As usual you built a beast................
Re: Little blown 410 sb mopar... [Re: DakFink] #1460135
06/30/13 10:57 PM
06/30/13 10:57 PM
Az
Crizila Offline
Crizila  Offline
Az
Good points, but that holds true with any belt driven blower. One of the down sides for street driven stuff. Then again, you are probably not going to want to run 15 lbs of boost on the street. I have a run on film with the belt tension set in the muddle of the tensioner travel. Jumps right up to 12 lbs and by the time I hit the lights the boost was down to about 5 lbs. Run the tensioner up to the end of its travel and boost jumped right up to 15 lbs and stayed there for the entire run. Procharger makes 5 different pulley sizes for their D1-SC. The 4" pulley is the middle size. A larger pulley might be in order for the street. When I ordered my blower kit, I told them that my HP goal was 700. My kit came with a 4" pulley. Pretty much what the OP dyno'ed. My application is race only.
Fastest 300
Re: Little blown 410 sb mopar... [Re: 72demon416] #1460136
07/01/13 01:02 AM
07/01/13 01:02 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I wish there was more of these centrifugal blown small block posts- there's hardly any out there to reference. I keep staring at my solid roller 439 W5 on the stand thinking it might be better off as a hydraulic roller with a F1-r or F2. More power/easier on parts/less maintenance/etc...
Other than the money it seems like a no-brainer
T3 twin turbos Rick, twin turbos.
Great info in this thread from everyone. My big 318 turbo plan is on the backburner 'til a turbo comes available (draw-through system).
Mo' Farts
Moderated by "tbagger".
Re: Little blown 410 sb mopar... [Re: Brian Hafliger] #1460137
07/01/13 01:17 AM
07/01/13 01:17 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Pump gasser, flat tappet 410 with a d-1sc procharger/water injection.
Made 720HP@ 5400rpm and 743TQ at 4900rpm! Here's a quick pick.
Still on the dyno, we changed to a larger pulley to slow it down (made 15+psi with the belt slipping) and ended up with 685HP@ 6900rpm and 680TQ with only 13psi.
Doing another similar 318 stroker with same blower setup in 3 weeks and another identical 318 stroker blown build after that. Blowers are fun fun!
Good stuff Brian Do you have an xtra large A/C system in there, the temps have been brutal down your way.
Re: Little blown 410 sb mopar... [Re: Grizzly] #1460138
07/01/13 01:34 AM
07/01/13 01:34 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
I hear ya' Griz, if it wasn't for all the plumbing on the turbo setups and the fact I can't seem to own a car that the engine stays together for more than 1 season I would do exactly that.
My supercharged Cobra is a blast to drive with it's roots style blower so I definitely have been bitten by the blower bug.
Re: Little blown 410 sb mopar... [Re: 72demon416] #1460139
07/02/13 12:32 AM
07/02/13 12:32 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Nice numbers Brian! My buddy has an 01' stang with a two valve 4.6 and a F1C on it, thing makes INSANE numbers in the 800+ range to the tire...Those prochargers sure work good
Re: Little blown 410 sb mopar... [Re: Mr.Yuck] #1460140
07/02/13 12:33 AM
07/02/13 12:33 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Can you elaborate on that a little? I have seen you mention it before, but am curious to know what parts would cross over and what has to be changed/modified?
Re: Little blown 410 sb mopar... [Re: mshred] #1460141
07/02/13 09:32 AM
07/02/13 09:32 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The crank pulley has to be drilled out for a Mopar crank, of course since it's not symmetrical (bolt holes) it cost a tad more. The main mounting bracket has short tabs on it, if you cut and add metal they can easily be mounted to the PS pads. (my main bracet was steel not aluminum) however you can always make a template w/ ply wood and have whatever you want cut and drilled at a local machine shop for WAY less than a "kit" I took the crank pulley to a machine shop and my template to my dads, where he cut and welded it. A quick grind and paine and it looked factory. The machine shope drilled the crank pulley and madea aluminum spacer so it would fit well in the 2 grove pulley. Then it's just a matter of lining everything up. For the back support I added a 1/4 piece of steel, I cut it, heated it and bent it to fit. I did have the discharge tube cut/welded at a shop. I had about $2200 in my set-up including new fuel system, carb prep, gauges and bungs.
