Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459783
06/29/13 08:54 AM
06/29/13 08:54 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
yes I packed the bearings. Then i tightened the adjustment nut to 90lbs, and backed off just a little.. the rotor is difficult to turn, doesnt feel right
90ft/lb has to be a typo , not the first time , that is way to tight for a bearing to begin with , I can see 90 inch lbs.
I have never torqued front wheel bearings, always did it by feel. I have to change that , I did torque them once , when working on the mustang that belonged to a friend with a PhD in Physics ...
Re: Walk me through my wheel and caliper installation [Re: JohnRR] #1459784
06/29/13 12:03 PM
06/29/13 12:03 PM
Central TX
roe Offline
roe  Offline
Central TX
I don't remember the number (I'll check when I get home) but mine had me torque to specified # of inch lbs, then loosen and retighten hand tight and secure with cotter pin.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459785
06/29/13 12:30 PM
06/29/13 12:30 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Don't forget to bend the locating tabs on the outer pads, so that they are snugly clamped into caliper, because if they slide around in the caliper when you lay them in there, they will surely rattle when you drive it.
Re: Walk me through my wheel and caliper installation [Re: buildanother] #1459786
07/01/13 10:32 PM
07/01/13 10:32 PM
Tacoma, Washington USA
Adam71Charger Offline OP
Got everything put together right. Went on my maiden voyage last night, and didnt get too far, horrible noise. Turns out I put in 1 brake pad backwards, chewed up the backside of the rotor , but thats what i get for being impatient. Got that turned around and the alignment done today. Drives decent, but there is definitely a vibration, I think its the tranny mount.
