Re: Slap Stick - Worth it? [Re: rabid scott] #145837
11/07/08 12:13 AM
11/07/08 12:13 AM
KCMO
K
kcmopar Offline
kcmopar  Offline
K
KCMO
I'm doing it to my 73 SE over the winter but does anyone know where to get a diagram showing bracket placement?
Re: Slap Stick - Worth it? [Re: cudabitten] #145838
11/07/08 12:34 AM
11/07/08 12:34 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Hi I asked this question before but did not get any definite answer. My barracuda has a 904 auto console on the floor but does not say "slapstik". Whats the difference? Can I make it a slapstik?
What year Barracuda? All E-body console automatics are Slap Stik, whether 904 or 727.
A-bodies never came with the Slap-Stik.
Re: Slap Stick - Worth it? [Re: kcmopar] #145839
11/07/08 01:44 AM
11/07/08 01:44 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
There's a pic in this thread there:
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Trans tunnel is dimpled so you don't need any measurements really.
Re: Slap Stick - Worth it? [Re: 318 Stroker] #145840
11/07/08 08:40 AM
11/07/08 08:40 AM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Are you sure? mine is a 74.
Re: Slap Stick - Worth it? [Re: cudabitten] #145841
11/07/08 09:27 AM
11/07/08 09:27 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
It should be a slapstick , if it's not it will be easy to make it one .
As far as it being worth it , it is if you feel the need to manaully shift it alot , like drag racing , just don't down shift to 1st while moving over 5mph , if you don't it it hardly worth the effort .
Re: Slap Stick - Worth it? [Re: DaytonaTurbo] #145842
11/07/08 10:47 AM
11/07/08 10:47 AM
KCMO
K
kcmopar Offline
kcmopar  Offline
K
KCMO
thanks
Re: Slap Stick - Worth it? [Re: cudabitten] #145843
11/07/08 10:59 AM
11/07/08 10:59 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Yep, I'm sure. Maybe it doesn't say Slap Stik, but if it's the original shifter for the car, it is one.
Now if someone monkeyed with it over the years, that could be a different story.
Re: Slap Stick - Worth it? [Re: 318 Stroker] #145844
11/07/08 12:36 PM
11/07/08 12:36 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Mine is a '74 and it also does not SAY slap stik But, if you put it into 1st and push forward, does it lock into second until you let off pressure? Then, when you push forward does it lock into drive? If you answered "yes" then its a slap stik
