Re: PCV valve
[Re: 6PAX]
#145701
11/04/08 10:42 PM
11/04/08 10:42 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
How important or necessary is it to have a PCV valve on a street car? My 340 Dart has a breather on each valve cover but I was told today that I should have a PCV valve in place of one of the breathers. Is this true?
It's true. No reason not to run one on a street car. It won't hurt your performance in any way, AND it will help to keep you from pushing the gaskets out with excessive crankcase pressure.
Re: PCV valve
[Re: stumpy]
#145703
11/05/08 12:50 AM
11/05/08 12:50 AM
Posts: 893 Tustin, CA
pishta
Tustin, CA
Youll never get excessive crankcase pressure running no PCV if you run breathers. The PCV, running to a fitting under your carb always seemed to me to screw up your A/F ratio when it opened (When exactly does it open, at what vacuum level?) almost like a controlled vacuum leak. Seems it would lean out when it finally opens with little manifold vacuum. I gut mine (pull the spring and ball) and run it to a port above the butterflys, or even into the air cleaner housing. I dont put many miles on mine, but my '57 Ford 312 had only a breather pipe that went straight down, used the forward motion of the car to produce a vacuum across the tip to vent the crankcase. That car idled like my Lexus, smoooth. You could even run a header evac system from one side and a dual breather on the other.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
Re: PCV valve
[Re: pishta]
#145704
11/05/08 01:00 AM
11/05/08 01:00 AM
dave571
"Youll never get excessive crankcase pressure running no PCV if you run breathers" is simply untrue. Seen it lots of times. Yes road draft tubes work, and so do header evac systems. Both much better than nothing at all. Years of use on all kinds of carbed applications have proved a pcv doesn't screw up the air fuel ratios, keeps the oil cleaner, and reduces crankcase pressure. To each thier own ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: PCV valve
[Re: pishta]
#145707
11/05/08 07:52 AM
11/05/08 07:52 AM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
Enlighten me on how a 2 breather vented crankcase can build enough pressure to blow out a rail gasket. I cant picture it on a healthy ringed motor.
I use 2 breathers on my stroker and never blew out a gasket... ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: PCV valve
[Re: pishta]
#145708
11/05/08 09:02 AM
11/05/08 09:02 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
In my opinion, there is nothing to actually evacuate the gasses out of the crankcase. Regardless of the healthy rings, a cold startup and probably a few hard throttle runs will still leave you with enough crankcase gasses down there to cause some issues. Possibly not to blow out any seals, but it will surely shorten the life of your oil. Also will probably find a nice fine oil mist under the hood...atleast things won't rust! ![](/ubbthreads/images/graemlins/shock.gif)
Again, just my ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: PCV valve
[Re: GoodysGotaCuda]
#145709
11/05/08 10:39 AM
11/05/08 10:39 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
My kid runs 2 breathers on his 62 300.That 413 has never been apart runs 13s thru the 1/4 and gets tons of street miles .Its been run like that for at least 10 years.I run 2 also on my built 440 and no problems.The built 360 in the truck runs the same thing.No leaks and no excessive pressure.Rocky
Chrysler Firepower
Re: PCV valve
[Re: 6PAX]
#145710
11/05/08 10:56 AM
11/05/08 10:56 AM
RapidRobert
I believe in them but I've wanted to run a exhaust evac on one side a closed breather on the other & eliminate the controlled vac leak(PCV) into the eng to "improve" the A/F ratio but they've been in use for decades with no A/F ratio problems so maybe I should leave well enough alone.
Re: PCV valve
[Re: Dart 340]
#145713
11/05/08 08:26 PM
11/05/08 08:26 PM
STROKIE
Montreal Quebec
I could not get my car to idle lean enough when I bought it. It had 2 breathers in it. Put in a PCV valve and bingo, much better now.
25 years ago my 'Cuda 340 didn't have a PCV in it and every now and then I'd find the dipstick tube pushed up. Put a valve in it and that problem went away. Go figure.
To each his own, but I will always run one now.
I use 2 breathers and my idle is very good I don't understand when you put a PCV you have a better idle... You inject oil fume in your air fuel mixture... I think is't not the best octane booster.. ![](/ubbthreads/images/graemlins/confused.gif)
Re: PCV valve
[Re: STROKIE]
#145716
11/06/08 12:17 AM
11/06/08 12:17 AM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
Why does your car speed up when you open a plugged vacuum port on your carb? Same reason. It's still air mixing with it.
I have a very high lift cam and low vacuum at idle.
