Re: How important are the engine to transmission struts?
[Re: cudabitten]
#1456629
06/22/13 07:16 PM
06/22/13 07:16 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm sure the majority of responders will tell you they've been running for XX years without them and "never had a problem".
The unsupported portion of the small block bellhousing hangs below the block more than the big block does and needs the support...decide for yourself.
[Re: 70Cuda383]
#1456636
06/23/13 09:57 AM
06/23/13 09:57 AM
Posts: 15,487 Florida
scratchnfotraction
That's an intriguing question. On one side is the fact that Chrysler [ or any other manufacturer for that matter ] never spent the money to put a part on a car if they didn't think it was necessary. At the same time they didn't put them on manual trasmission cars which were subjected to higher shock loads. All I can say is that lots of people with headers do without one or both braces and they don't appear to have any problems that can be attributed to the lack of a brace[s]. FWIW when I had my old Duster with a 727 and TTI headers I modified the factory brace to fit. Pretty sure it was the right side brace that I altered.
I was going to say the same thing.
even on the 97-04 Dakotas, the automatic trucks had block to lower bell braces. Manual trucks did not get these braces.
so...why are they there on some trucks but not on others? what exactly are they supporting?
looking at the thickness of the auto bell and the manual bell, the manual bell is thicker and more ridgid.
I have broke a auto bell before by running over cyprees knees/stumps in the swamps,cant say I have done that with the manual trans.
same reason the xfer comes with a ridged brace. I busted more than 1 alum xfer without them inplace ![](/ubbthreads/images/graemlins/tsk.gif)
IMHO, you can run without them but you need to be ready to fix it at any giving time. ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: 5spdcuda]
#1456637
06/23/13 10:19 AM
06/23/13 10:19 AM
Posts: 30,541 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
VERY true .... and the one item that comes to mind is the drain-plug on the 727 trans some years back ..... Mopar eliminated that plug because it saved (so I heard) FIVE CENTS per pan ......
...but there was another second MINOR reason. ANYone else know that ?
[Re: AARCONV]
#1456646
06/20/14 06:54 PM
06/20/14 06:54 PM
Posts: 2,540 God's Country Maryland
GODSCOUNTRY340
I know for a fact if you don't use them and your trans to engine bolts work loose, you will be replacing your broken flex plate before long. For added insurance use the supports.
