Page 2 of 4 1 2 3 4
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: Copper Dart] #1455067
06/19/13 01:43 PM
06/19/13 01:43 PM
dogdays Offline
dogdays  Offline
Edelbrock has their own foundry right here in the USA. Look at their literature, they say it again and again.
R.
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: '72CudaRacer] #1455068
06/19/13 01:58 PM
06/19/13 01:58 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Where did the Stealth head crack and is it not repairable?
I don't bother following the Stealth-related posts often; is this a common problem with them?
I don't recall the Edelbrocks having cracking issues, etc., although I've seen first-hand how IMO they still need to have the guide clearances & valve jobs checked & corrected OOB.
Performance-wise there shouldn't be any significant difference with the same level of prep work, considering Brandon's R&D for port & chamber design was simply sending an Edelbrock Performer RPM to China along w/ an OEM iron head and giving the foundry the following instructions:
1. Make new head rook rike Ederbrock on inside
2. Make new head rook rike Chrysrer iron head on outside
(My apology to all Asian and Asian-American readers who take offense to my accent parody. )
EDIT: Just re-read the orginal post and saw where the OP stated "One of them cracked where the early castings were prone to crack (end exhaust port into the spark plug hole, not really cost effective to repair)."
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: BradH] #1455069
06/19/13 02:01 PM
06/19/13 02:01 PM
DTW
drmopar Offline
drmopar  Offline
DTW
I bought a set of CNC'd stealth heads for my 451 I had in my last road runner vert and they still needed to be clearanced for pushrods. Just sayin.
If it were a racecar, Edelbrock heads. If it was a show car (FAST looks) then Stealth all the way.
RM27H9G 4 speed F8/tan guts
RS27L9G auto B5/black guts
WM23H9G auto F5/green guts
2021 Challenger 392 Indigo/black guts
2019 Charger Daytona R/T F8 on black
2018 Ram Sport Hemi 4x4
Re: Eldebrock RPM's vs. 440 Source Stealth heads *DELETED* [Re: BradH] #1455070
06/19/13 02:30 PM
06/19/13 02:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Post deleted by JohnRR
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: ] #1455071
06/19/13 02:31 PM
06/19/13 02:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don't understand the question here???...
Not to tough to figure out.....
Edelbrock heads=$1750, plus need to be checked for guide clearance and valve job
Stealth heads=$1000, plus need to be checked for guide clearance, valve job, and pushrod clearance
CNC Stealth=$2000, Ready to go, checked by Modern Cyl. Head
CNC Stealth is a no-brainer [/quote
You still end up with $2,000 worth of japanese crap..........
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: Thumperdart] #1455072
06/19/13 02:35 PM
06/19/13 02:35 PM
Renton Washington
Triple Threat Offline
Renton Washington
Unlikely they're made in Japan. Not all countries are the same, and there are chinese foundries that produce extremely high quality products, they're just not cheap so people don't use them.
If it was my Money RPM heads or the EZ head.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: Thumperdart] #1455073
06/19/13 02:36 PM
06/19/13 02:36 PM
JohnRR Offline
JohnRR  Offline
They wouldn't be crap if they were made in Japan ...
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: JohnRR] #1455074
06/19/13 02:51 PM
06/19/13 02:51 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Guess I'll go with bare Edelbrock heads... just noticed the aluminum "452" heads (good flow out of the box) but I think I'd rather screw around with angle plugs anyway
casting problems are scary, and hard to see
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: JohnRR] #1455075
06/19/13 02:56 PM
06/19/13 02:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
How`s that, did you see the above post? Ever see another head made here do that? Japanese, Chinese not sure of the differences I guess.
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: JohnRR] #1455076
06/19/13 03:34 PM
06/19/13 03:34 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
\ Hope I don't get banned for this ....
Really John, that's just trolling there. That engine was hydraulic locked or the head bolts weren't torqued properly.
Thumper- they are Chinese heads....
I bought the Eddie heads- the Stealths weren't on the market yet- and would recommend them, just because they are made in the USA. The Eddie heads are known to need setup work, no different than ANY aftermarket head- some of the MP stuff needs Major work. I'm having Brian @ IMM do a full setup and porting appropriate to my build. He's given me a very reasonable price and I like supporting a local shop.
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: JohnRR] #1455077
06/19/13 03:43 PM
06/19/13 03:43 PM
an8sec70cuda Offline
Holy crap! What's the story on that head?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: VincentVega] #1455078
06/19/13 04:04 PM
06/19/13 04:04 PM
NY usa
540challenger Offline
NY usa
IF i remember right the MP 452 head is cast by edelbrock and it is basiclly a RPM head with straight plugs
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: an8sec70cuda] #1455079
06/19/13 04:08 PM
06/19/13 04:08 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Casting problems occurred in the second run on these heads. In-proper heat treating but has long been taken care of. A Friend of mine was the owner of said set but they sat on a shelf for a couple of years before he used them. He then did some at home porting and installed them on his car. Not sure of the time period but one did develop some cracks. I told him to talk to Brandon and after a few conversations they were both replaced with a NEW set of heads long after the purchase. Check recent history with these heads and other than the same issues found on MOST after-market heads (tight valve guide, not the best valve job) their track record is pretty good.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: '72CudaRacer] #1455080
06/19/13 04:17 PM
06/19/13 04:17 PM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
The rpms have angled plugs and the hooker 2 inch work on mine. The rpms like any other head will need a multi-angle valve job and springs for your cam. I have the rpms and to me they had very little foundry shift in the castings. I know nothing about the other heads only what I have read. You will need to have the intake port ported to really see any rear benefit, because the exhaust has good flow and may need very little work. With the .590 cam I think you would benefit more from the rpms than the big victors.
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: oldtimer5151] #1455081
06/19/13 05:30 PM
06/19/13 05:30 PM
USA
hudsonhornet7x Offline
USA
on a side note about rpm heads, does anyone know how fast these heads could push a b-body?
Also, if the heads were fully ported what is the ideal cubic inch for these heads? In other words what works well, and what is too big?
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: hudsonhornet7x] #1455082
06/19/13 05:46 PM
06/19/13 05:46 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Been 10.07 @132 in a 68 GTX weighing 3600# race weight. Easy nines in a lighter car for sure. Cam could have been optimized as well, but this guy is a hardcore bracket racer, and didnt also want to deal with safety equipment running in the nines. He was running a 493 combo. They will work great from 440-512 C.I. All standard off the shelf stuff, not even ported intake etc...very user friendly.
RIP Monte Smith
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: hudsonhornet7x] #1455083
06/19/13 05:47 PM
06/19/13 05:47 PM
Aubrey, Texas
O
O
Aubrey, Texas
The rpms were engineered to flow their best at .600 and maybe a little more. The victors are for bigger inch, big roller, intake, and exhaust system.
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: hudsonhornet7x] #1455084
06/19/13 05:50 PM
06/19/13 05:50 PM
PA.
"Little"John
"Little"John
PA.
Not a B body but a Friends duster has gone 8.80's-8.90's with Edelbrock heads, solid lifter cam, and a tunnle-ram. App 500 ci.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: an8sec70cuda] #1455085
06/19/13 05:52 PM
06/19/13 05:52 PM
JohnRR Offline
JohnRR  Offline
I don't remember but when I saw it I right clicked SAVE ... the person that posted it up had more than one that was broken like that. I doubt they were hydro locked, this was a known issue with the early stealths, I hope for the sword swallowers sake that they don't have that issue anymore.
Dom, there is a huge difference between stuff made in Japan and the stuff made in China , Japanese stuff was on par with current china back in the 70's , much better today .
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: JohnRR] #1455086
06/19/13 05:59 PM
06/19/13 05:59 PM
How fortunate for us that we have a world traveler that has his finger on the pulse of worldwide manufacturing quality Perhaps he can take a break from traveling someday, to actually finish one of the 3 engines he has been "building" for the last 10 years.... ...maybe then he can offer some first hand, REAL experiences...
Page 2 of 4 1 2 3 4
