Re: How does front tire size affect reaction time
[Re: moparguy7074]
#1454709
06/18/13 09:16 AM
06/18/13 09:16 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
If you shallow stage the taller tire takes longer to roll out of the 2nd beam (starting line), but you are limited by what fits.
Do you have a adjustable slow switch for your T-brake?
"Just a Bracket car dressed up like a streetcar"
[Re: moparguy7074]
#1454710
06/18/13 09:36 AM
06/18/13 09:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
A taller tire spends more time in the lights... if you lower the air pressure it can help fine tune your RT... lowering your RPM will help also.. but if your RT is all over the place then you need to practice on a tree
[Re: MR_P_BODY]
#1454714
06/18/13 01:12 PM
06/18/13 01:12 PM
Posts: 290 Norwalk Ohio
cudasteve68
Norwalk Ohio
That is why alot of Super Stock & Stockers run big tall azz front tires. Gives them more roll out, or a running head start before tripping the timers. Some of the fast ones even run offset front tires for the same result. All Profession heads up clsses run offset front tires. Some Super Stock & Stockers run up 1.0" of stagger
[Re: moparguy7074]
#1454715
06/18/13 05:36 PM
06/18/13 05:36 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
Just like the subject says, how is reaction time affected by a change in front tire size? I have 25's on my car now, how would 26's change it? What about 27's? I'm running a trans brake btw, launching at 3400, and I always have to wait when I see the bottom yellow or else I go red.
Any help would be appreciated, cause my lights have been all over the place.
Have someone carefully video the front tires when you launch to see if the car lifts the tires out of the beams or rolls them through the beams If it is rolling them through then the 2 inch taller tire may slow the reaction time down a tiny bit while slowing the measured 60 ft times down also I used a set of 22 inch tall 135x15 Sr on my old Duster when I ran it in S/ST back in the early 1990s when NHRA division 7 used the 4/10 Pro tree in S/ST, I had a 727 with a early slow reacting transbrake Those tires help maybe .02 or .03 on the reation time, not enough to help when your cutting .06 or slower with them on I would work on making you and the car consistent first on the reaction times and then look at making any mechanical changes to make the car slower or faster on the reaction times, like changing the front tire size, front tire pressues, the starting line stall RPM and so on Back in the day I had a set of the Stahl 31 inch tall tires on my 1963 M.W. Belevdere, they got old and weather cracked so I switch to a set of the Moroso 29 inch tall tires, I did redlight a lot less with the taller tires I would cut .003 to .015 in time trails and now and then cut a .498 or .499 in eliminations, espcially the first or last round After switching to the 29 inch tires I cut a lot more .498 and worst lights BTW, I carry 24, 26 and 27 3/4 inch tall tires in the trailer now to use as needed
[Re: cudasteve68]
#1454717
06/18/13 06:29 PM
06/18/13 06:29 PM
MR_P_BODY
I run 3/4" stagger to the front of my car to help make a longer roll out... but my tires are short
[Re: bigdad]
#1454720
06/19/13 08:20 AM
06/19/13 08:20 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Think in terms of what you have to do to tune the car to YOU. The mind wants to do what it wants, and that is to leave exactly when that yellow you are looking at comes on. Tune to it. Delayed release button, stagger, bigger tires, less launch rpm, they all help. The problem is, the transbrake made your VEHICLE reaction time much better, which is what you have to change. If the class you race in allows the slow release button, I would start there.
