Re: road runner charging issue
[Re: barryv]
#1453320
06/15/13 04:23 PM
06/15/13 04:23 PM
Posts: 10,239 Someplace you aren't
SomeCarGuy
Search around on here. plenty of info on this topic. Start with cleaning the bulkhead connector.
I want my fair share
[Re: barryv]
#1453327
06/15/13 10:15 PM
06/15/13 10:15 PM
RapidRobert
I'm thinking the reg even tho you changed it out. (Mechanical or electronic reg?). Might full field the alt for 3 seconds & see if it's (the alt) is OK. (have lights/acc OFF). IF the alt & reg are OK & the batt is charged then that only leaves the supporting Wiring: alt/reg field wiring on the positive side, grounds on the neg side, poor connection that just developed cuz it was OK for years & as said the bulkhead is a frequent offender. Holler how it goes.
[Re: barryv]
#1453338
06/17/13 10:32 AM
06/17/13 10:32 AM
Challenger 1
Cincinnati, Ohio
Been driving my challenger since 2005 with a #10 wire from the alt to the starter relay, so my amp gauge don't work. Car seemed to run fine and always started. Then a couple weeks ago I put my headlites and AC clutch on relays. Noticed the lights were still dimming at idle with the AC cranked on high. So I picked up this cheap DVM that plugs in my cig lighter. I had less than 12 volts at idle and maybe 13 volts with it revved up. Yes I have a DVM but's it's hard to watch while hooked to my battery and me driving the car. Took my powermaster alt off my other car and put it on. Now I had over 14 volts at idle. So I ordered another powermaster alt and put it on for good, now I have 15 volts and my car runs much better and idles smoother. I know I should have put in a volt gauge when hooking up the #10 wire but didn't. At least now I know what my alt is putting out. So my old 15 year old alt was still working, just not putting out like my old girlfriend used to. So consider replacing your alternator. That's Daytona beach sand on the floor mat. ![](http://i21.photobucket.com/albums/b260/challenger19711/After%202-22-2013/IMG_08871.jpg)
