Re: Forged, stroker piston "rattle" [Re: 1969RR] #1453228
06/15/13 11:26 PM
06/15/13 11:26 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
My 440 Source Stroker kit does the same thing. Piston slap when cold but quite when warmed up. Engine runs great and I'm not concerned about it.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Forged, stroker piston "rattle" [Re: 68LAR] #1453229
06/16/13 12:37 AM
06/16/13 12:37 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
If the piston skirt is hitting the bore wall, it obviously isn't a good thing
GM had massive issues from 99-2003( at least) because they cheaped out and started assembling engines( 4.8/5.3/6.0) in batch mode. They got all engines bored the same, used all same pistons, and just assumed every engine would end up with identical clearances, instead of checking/ building on a case by case, each engine is unique format, like they had previously.
Piston slap greatly effects the resale value of a vehicle that has this issue.
Given owners who have sued GM over this issue have either forced GM to buy back the unit, or offer a cash settlement.
GM didn't do this because the engines were " right"
I suspect people that have this issue have to like it, because the alternative is to tear the engine down and fix it so it's right
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Forged, stroker piston "rattle" [Re: B3422W5] #1453230
06/16/13 04:40 AM
06/16/13 04:40 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
You say you have a .040 over block. Are you sure you have .040 over pistons, and not the more common .030? How did you measure the PTW clearance? I have never had any problems with piston slap hot engine with correct clearances. My
Re: Forged, stroker piston "rattle" [Re: Oyvind Mopar] #1453231
06/16/13 12:21 PM
06/16/13 12:21 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
I thought the same thing, but I double checked the pistons with a mic and the cylinders with a bore gauge. I actually had to order 1 piston. One was damaged when I took it out of the box, so I have an extra to play with! I ordered the same part # so I'm sure they are 0.040 pistons. That is also what I spec'd to Indy Cyl when I ordered the block from them. I'm positive about the clearance there. To me, the noise doesn't change at all cold or hot. But, it doesn't seem to hurt either, engine runs good. I just hate the noise. It sounds like something is coming apart! I'm going to try and upload a vid to U-Tube later. Thanks, Jeff
Re: Forged, stroker piston "rattle" [Re: 1969RR] #1453232
06/16/13 01:37 PM
06/16/13 01:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
COULD THE PISTONS BE HITTING the heads ?? quench to close ?
i had a bbc that sounded like piston slap & it ended up they were hitting the heads.
Re: Forged, stroker piston "rattle" [Re: CSK] #1453233
06/16/13 01:59 PM
06/16/13 01:59 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Double check your converter bolts
DAMHIK
Re: Forged, stroker piston "rattle" [Re: Thumperdart] #1453234
06/16/13 02:10 PM
06/16/13 02:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
If you've got a 160°F thermostat, you should change it for a 180°F one.
It would reduce noice.
Hello, It is actually a 195 stat. Temps normally run about 195 - 200 depending on the ambient. I've unhooked my electric fans and let it get to about 230, same noise. Jeff
I can`t consider piston slap "normal" w/modern stuff within spec. Sounds like a problem to me..........
same here Dom. I wouldn't run a motor with piston slap it's not normal or good.
Re: Forged, stroker piston "rattle" [Re: roadhazard] #1453235
06/16/13 02:11 PM
06/16/13 02:11 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Oooh, Roadhazard may be onto something but vert bolts are Loud like you Know something's bad off like a rocker came loose...I've seen that too.
WIZE
In Car:
Re: Forged, stroker piston "rattle" [Re: Quicktree] #1453236
06/16/13 03:13 PM
06/16/13 03:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactly, and on my last freshen up my pistons(JE)are a bit looser than recommended and there`s no slap that I can hear anyways...........
Re: Forged, stroker piston "rattle" [Re: Thumperdart] #1453237
06/16/13 03:27 PM
06/16/13 03:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being he checked the piston to bore and knows what
that was I'm thinking he is looking in the wrong area...
could it be the pins.. I dont think so.. maybe the
conv bolts are just long(the head) and touching the
block
Re: Forged, stroker piston "rattle" [Re: MR_P_BODY] #1453238
06/16/13 03:34 PM
06/16/13 03:34 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What lifters are you using? If they are Comp 822-16s, they will be noisy hot or cold no matter what you do or change. You say Crower cam but those lifters, if Crower labeled, could be anything from good to bad. Ive always wanted to try Johnson Hy-lifts but my next combo is gonna be a roller.
Mopar to the bone!!!
Re: Forged, stroker piston "rattle" [Re: roadhazard] #1453239
06/16/13 09:24 PM
06/16/13 09:24 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
DAMHIK
Sorry, 4 speed! I forgot to say originally
