Re: Amp guage burnt out!
[Re: newportrider]
#1452523
06/13/13 08:45 PM
06/13/13 08:45 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Eliminate it.You can do the Madd conversion in the archives or for quick I just use a screw and nut and put the 2 wires together and tape them up.Its common for the amp gauge to go bad.Mines been bypassed for probally 20 years.I run a volt meter.Problem solved.Rocky
Chrysler Firepower
[Re: therocks]
#1452525
06/13/13 09:50 PM
06/13/13 09:50 PM
RapidRobert
What Rock said: pull a batt cable then put both of the large ammeter wires on one of the two ammeter studs. (Dont matter which one). If there's more than 2 wires put all of em on the same stud
[Re: terzmo]
#1452530
06/15/13 08:20 AM
06/15/13 08:20 AM
therocks
Niles , Ohio
Just hope that after market amp gauge dosen go up in smoke.Dont ask how I know.Install a volt gauge.Simple easy and no danger like amp gauges.Just remember old Mopars draw a ton of current thru that amp gauge.Rocky
Chrysler Firepower
