Re: Roller rockers for the long term investment
[Re: MoparforLife]
#1449701
06/10/13 02:49 PM
06/10/13 02:49 PM
Posts: 8,923 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Trouble with the needle bearing whether on the tip or the felcrum is that the load is only on one side and they rock back and forth.
Oh, and a bushing is different because it rotates ?!?!? NOT !!!
Bushings or bearings on the fulcrum could be debated for years with no solid evidence that one is better than the other on a rocker of equal quality. However, a roller tip will absolutely have less friction and wear that a non-roller tip. In this case, Isky got it right with hardened inserts but I have seen many Cranes where the valve stem has worn a groove into the tip.
[Re: dogdays]
#1449703
06/10/13 03:45 PM
06/10/13 03:45 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Those of us who have been reading you for years know of your dislike of roller rockers and 2.02 intake valves in smallblocks. All well and good, but if the bearing was PROPERLY SPECIFIED, it will last for a long long time.
R.
What does properly specified mean?
[Re: ahy]
#1449705
06/10/13 05:27 PM
06/10/13 05:27 PM
Adam71Charger
Comp pro magnum are plain bearing rockers. No roller bearings on the shaft but roller tip. Geometry "over the tip" on my BB was excellent. there are no fatigue concerns with extended use as with aluminum rockers . The only drawback is a tendency to gall the shafts with high lifts and spring pressures. With lift under .6" shouldn't be a problem.
I just figured that out about the bearings being in the tip side of the rocker, not the shaft. I talked to comp cams, they say the rockers are bushed with a 'bronze like' materiel and can handle up to 650lbs open pressure. I really like the fact that they are steel.. and I thought the issue with galling was taken care of by having bushings in the rocker?
[Re: Adam71Charger]
#1449706
06/10/13 05:50 PM
06/10/13 05:50 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
The have lots of area for oil flow too.
[Re: dogdays]
#1449708
06/10/13 06:34 PM
06/10/13 06:34 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
R.
Go to hughes sight if you don't believe me. http://www.hughesengines.com/TechArticles/3rockerarms282007.php Here is an excerpt:The rockers only rock in a small arc of approximately 25 or 30. If the rocker or the shaft actually rotated the needles would live longer. Here again is a conundrum. The smaller needles spread the load over more needles, but they are more fragile you just cant win! Some of the roller rockers even have needle rollers in the roller at the tip of the rocker. The unit loading is very high with needle bearings. All these extra parts are just more points of potential failure. It isn't fun and games looking for needles in an engine when one comes apart. Seen it happen more than once. As for the 2.02 valves I have nothing against them in the right application. Personally 1.88's have fit me better and given me better ET's. Also friends have gone from 2.02's back to 1.88's for more torque out of the turns on thier dirt tracker. To each there own.
[Re: Adam71Charger]
#1449710
06/10/13 09:37 PM
06/10/13 09:37 PM
Posts: 7,664 IN
ahy
IN
Yep. Sounds like they made it better with the bushing. Great rocker.
[Re: Stanton]
#1449712
06/10/13 11:02 PM
06/10/13 11:02 PM
Adam71Charger
I bought my Harland Sharps in 1993. They haven't changed a thing since. If there were problems with them don't you thick they'd have addressed the issue by now ?!?!?!
Thats impressive.. is this a street motor?
[Re: Adam71Charger]
#1449716
06/28/13 04:52 PM
06/28/13 04:52 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
The Comps are nice little rockers for street duty. Make sure the clearance is right bewteen shaft and bushings. My understanding was Comp was nitriding the shafts, hence the color. I had got some of their shafts when they first started, and I wouldnt call them the beefiest shaft out there, but absolutley fine for their intended useage. That little bit of flaking is nothing to worry about. Making sure they are sized or clearance well is whats important. The Comps are nice too because of the reverse cup style adjuster, which makes pushrod selection way way easier. As far as the roller vs solid vs bushing debate, well, it all makes great topic of conversation, but in the end, real world results trump all. I have used and repaired every brand imaginable for Mopars especially, and they have all had success when used in the right application.I will say that again, the RIGHT application. Many times rockers are chosen by price point rather than reason. That will almost always result in unsatisfactory results. If a rocker is run dry, it will fail, If a roller is run dry, it will fail. If a spring pressure is too great, it will fail. If shafts are put on wrong, it will fail. It shafts are of the wrong hardness for the corresponding rocker material, it will fail. You get the idea. I have run Harland Sharp rockers ( same sets) for over 20 years in race cars without failure. I have ran Crane Golds for over 15 years without failures ( other than screws being soft). I have ran Comp Pro Magnums on street engines with great results. I have just started trying the Hughes rockers on Stock Eliminator cars,and I am pleased with them . I think they are a good value, and geometry was good. My opinion is there is some mis information in this post, and in the end, you need to determine what is important in your own build, and take action accordingly. My feeling, based on almost 30 years of this, is rockers are NOT a good place to take short cuts, and offshore rockers are not a wise investment. My ![](/ubbthreads/images/graemlins/Twocents.gif)
RIP Monte Smith
