Re: Chassis Help
[Re: loaderpro]
#1449630
06/12/13 01:20 AM
06/12/13 01:20 AM
Posts: 577 Arkansas
Adrielp
Arkansas
https://www.facebook.com/photo.php?v=146...e=2&theaterThe link above is a video of the first pass with the car last weekend. We learned a lot this weekend and will make adjustments to correct it. Enjoy the vid! Theres also some pics of the car on the page as well.
Adriel Paradise Substation Design Engineer III
Re: Chassis Help
[Re: loaderpro]
#1449631
06/12/13 08:51 AM
06/12/13 08:51 AM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I was not just chimeing in or trying to spend somebodies money Leon! You put a hot rod engine in that yards the tires 3-4 feet in the air it's going to take more than a handful of steel shims to correct it. Especially if there is bump steer involved...that as you well know is nothing to fool with.
Good point. It is probably time to prioritize the moves that most feel are important. IMHO they would be- 1....how good are the front end parts-does the front need a rebuild? If so, determine what type of bushings, rubber or poly 2....set front and rear chassis height and set caster where you will run it. THEN check for bump steer problems through the range the front will travel during a run. Acquire a Mopar chassis manual, and fix the bump steer if needed to get within 1/8 all the way through travel. 3.... set up your travel limmiters, both up and down for cushioned stop to travel. Raising the lower one some should help protect the pan, provided you have some shock control to assist. 4.... Determine what front shocks you want to run IMHO you need some good shock control for landing. I am not up on what is out there for budget shocks that will work for your situation, so that may require a post of its own. 5.... Strongly consider wheeliebars if you can't get it consistent and keep the wheelstand at a reasonable level. Wheeliebars are costly- but so are oil pans, bent rims, etc. The other factor is consistency. The wheeliebars will make the car more predictable for sure.
Re: Chassis Help
[Re: gregsdart]
#1449632
07/01/13 12:02 AM
07/01/13 12:02 AM
Posts: 577 Arkansas
Adrielp
Arkansas
Problem solved! Car is launching very well and we ran a personal best in the worst air the car has run in all year. Leaves straight as an arrow as well. Anyway, we have some vids up on our facebook page of the runs from this weekend. There is also a few inside car vids as well. Feel free to like our page as well. Follow the link and enjoy! https://www.facebook.com/pages/Paradise-Racing-Engineering/146044575585862Career best: 6.34 @ 108.43 in the 1/8th Conditions: 88deg, 29%, 29.76bar, DA: 2701ft
Re: Chassis Help
[Re: Adrielp]
#1449633
07/01/13 12:21 AM
07/01/13 12:21 AM
Posts: 52,972 Romeo MI
MR_P_BODY
So what did you do to correct it
Re: Chassis Help
[Re: Adrielp]
#1449635
07/01/13 12:34 PM
07/01/13 12:34 PM
Posts: 345 Arkansas
JoWeTu_6
Arkansas
Nice runs, I hope to make it to the track soon my self (couple of weeks) Maybe I'll see you all their. Good racing John T.
