8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn #1448487
06/06/13 03:48 PM
06/06/13 03:48 PM
Ontario, Canada
W
Wedge7070 Offline OP
W
Ontario, Canada
What is the best choice for street strip.......
1970 Duster 431 stroker roughly 550 horse, auto, 4:10 gear.
1970 Challenger 1970 Road Runner 1970 Duster 1968 Charger 1969 Charger 2005 Ram Quad 1500
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: Wedge7070] #1448488
06/06/13 04:14 PM
06/06/13 04:14 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
Running a spool isn't the best idea if the car is going to be street driven at all. I'd go with Detroit Locker/Truetrac (I believe that they're the same company now). That's what I have in my '68 Plymouth and it's good for both street and strip. If you aren't planning on building the rear end yourself, you might consider Dr. Diff.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: 1968RR] #1448489
06/06/13 04:26 PM
06/06/13 04:26 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Call Cass (Dr.Diff).
He will explain the differences, the Locker is the toughest but is also noiser.
I have basically the same car and combo (71 Duster 426 SB, manual trans) as you and decided to get the nodular iron 489 case with forged steel caps, billet adjusters, 3.91 gears, Eaton True-Trac, crush sleeve eliminator and forged steel 7290 U-bolt yoke. I doubt I'll ever hurt it.
My buddy bought his slightly Stronger Detroit Locker setup, he has a (Demon) with a 500+HP stroker SB and a 4 speed. This is the strongest 8.75" differential available (by a small margin), but not everyone likes how it drives, as there in 1/8" internal lash in the ratchet mechanism. About $50.00 more overall compared to the Auburn setup I bought.
All of the parts from Dr.Diff have been top notch!
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: ScottSmith_Harms] #1448490
06/06/13 04:58 PM
06/06/13 04:58 PM
Ontario, Canada
W
W
Ontario, Canada
A friend of mine used Dr Diff stuff in his 68 bigblock Dart....said he was great!
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: Wedge7070] #1448491
06/06/13 05:39 PM
06/06/13 05:39 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Another vote for Detroit Locker
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: Wedge7070] #1448492
06/06/13 05:53 PM
06/06/13 05:53 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I used Dr diff to order my Dana 60. He recommended the true trac for my 650 hp four speed street car.
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: HEMIDOG 70] #1448493
06/06/13 06:55 PM
06/06/13 06:55 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Locker here too, I like it but it did take some getting used to. Not the noise though. As loud as my car is, if you can hear the noise from the rear end in my car something bad's about to happen....
It's that play in them that feels weird, the car will wiggle a bit if you coast then get in it again , even going normal speeds.
I thought my Cal Tracs were causing this at first. It takes a little getting used to but it's fine for me.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: Sledge_57] #1448494
06/06/13 08:00 PM
06/06/13 08:00 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
Another vote for Dr Diff and a Detroit Locker.
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: Wedge7070] #1448495
06/06/13 08:54 PM
06/06/13 08:54 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
I find it hard to believe so many suggest the locker, I can see it some cases, but its awfully annoying in many street applications especially when exiting corners in a hurry. I suggest OP make sure he gets some seat time in a friends car with a locker before putting down any money.
I forbid my content here from being learned and used by artificial intelligence systems.
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: jcc] #1448496
06/06/13 10:09 PM
06/06/13 10:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Right Jcc, driving my buddies Demon (and our Duster race car) with the Locker made going with the Tru Trac an easy choice, especially since we are not talking about a big difference in strength.
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: ScottSmith_Harms] #1448497
06/06/13 10:33 PM
06/06/13 10:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also run a Detroit Locker in my 63. Ron
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: 383man] #1448498
06/06/13 10:49 PM
06/06/13 10:49 PM
1968RR Offline
1968RR  Offline
What I meant to say in my previous post was that they're both made by Eaton now. I have the Truetrac in my car, not the Locker, and it does just fine on the street.
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: HEMIDOG 70] #1448499
06/07/13 12:44 AM
06/07/13 12:44 AM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
I used Dr diff to order my Dana 60. He recommended the true trac for my 850 hp auto street car.
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: MAVERICKSHEMI] #1448500
06/07/13 06:31 AM
06/07/13 06:31 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Absolutely love my Truetrac! Works like an open diff when not needed and performs great as a Sure-grip when needed. No noise, no need for LS additive, does not wear out. Great piece!
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: Wedge7070] #1448501
06/07/13 08:41 AM
06/07/13 08:41 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Whatever you decide on AVOID any type of CONE TYPE differential , they are absolute garbage .
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: JohnRR] #1448502
06/07/13 08:58 AM
06/07/13 08:58 AM
Ontario, Canada
W
W
Ontario, Canada
Thinking of going with True Trac....alot of good things said......thank you. Everyone here is always a great help. Take care all!
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: Wedge7070] #1448503
06/07/13 09:04 AM
06/07/13 09:04 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Interesting design , looks like a stout unit .
http://www.youtube.com/watch?v=lZmsY2YvVsc
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: JohnRR] #1448504
06/07/13 09:39 AM
06/07/13 09:39 AM
NY usa
540challenger Offline
NY usa
I have the True Trac 5000 miles behind my 408 small block I love it no problems at all on the street.
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: 540challenger] #1448505
06/07/13 10:31 AM
06/07/13 10:31 AM
None
71rm23 Offline
71rm23  Offline
None
True track here
Re: 8 3/4 Diff. Spool, Detroit Locker, True trac, Auburn [Re: 71rm23] #1448506
06/07/13 11:14 AM
06/07/13 11:14 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is the one I got from Dr. Diff, first class piece all the way.
