Page 4 of 4 1 2 3 4
Re: truck 5 speeds? [Re: scratchnfotraction] #1447173
06/18/13 06:07 PM
06/18/13 06:07 PM
dogdays Offline
dogdays  Offline
You doggone right it's a good deal. Not as good as a free Edelbrock Quadrajet, but it's getting right up there!
If I ever get some $ put together, I'll spring for shipping for bigblock mounts for Sweptline, I still have most of the parts for my "longterm stroker" lying around.
Found a guy in Tempe who does custom cranks, anyone here use Kadrie?
Anyone got a set of porting templates? Looks like either 213s or 906s if I do bigblock.
Gotta get the '64Dog on the road with smallblock power first, though!
R.
Re: truck 5 speeds? [Re: scratchnfotraction] #1447174
06/18/13 07:44 PM
06/18/13 07:44 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
it seems it decoded as a NVG 4500 92-93 D body
v-8 hydro bell/clutchfork/trans/shifter/yoke for 400$ 90day warranty. good deal??
sure better than the 800$ pink elephant with a gold nugget shifter a535 5 speed
going back for a rust free 91 d-100 cab to replace the daily driver 85 rust bucket.
So you ended up with a NV4500 trans? If so killer deal........I wouldn't mind having one for my RC.
Moparlee
Re: truck 5 speeds? [Re: scratchnfotraction] #1447175
06/19/13 09:34 AM
06/19/13 09:34 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
$400? that's a steal....
it's not really a performance transmission, if that was what you're looking for...first will still be next to useless, and they're not the fastest shifting beasts...
2017 Grand Cherokee Overland
Re: truck 5 speeds? [Re: patrick] #1447176
06/19/13 10:46 AM
06/19/13 10:46 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
if the junk yard drained that tranny it is going to take a special synthetic fluid made by GM and mopar---it costs $20 a quart---if you use any other fluid your carbonfiber syncros will fall apart and it will cost about $120 for new syncros plus the labor--then you will have to put in $100 of fluid again--the nv4500 is about as strong a tranny as you will find--the only criticism being the harmonics of a cummins diesel coupled with guys that lug big loads (cummins) in 5th gear--then whine about it falling apart---GM has had great success using this trans behind gas motors...bob
Re: truck 5 speeds? [Re: savoy64] #1447177
06/19/13 11:05 AM
06/19/13 11:05 AM
scratchnfotraction Offline OP
I was reading about the fluid needed but 20$ a quart? 1004 to refill!
well gone to far now to skimp on the fluid it needs.
from what I can tell this is the early one with the syncronized 1st & revs gears.
light duty with a 19 spline input shaft/727 out put shaft/yoke.
may have a 1st gear thats not as low as the standerd duty/heavy duty 4500..from what I have read anyways.
I suppose I can count the turns of the input to turns of the output to see what the 1st gear ratio is?...correct?
wish I knew what gear was behind it for a correct speedo tooth count. it had 37 tooth short pinion/speed sensor housing that i swaped to the 36 tooth gear/727 housing that I would use with 727-3.91-325/50/15
but need to figure in the OD 5 th gear???
anyone do the math??
Re: truck 5 speeds? [Re: scratchnfotraction] #1447178
06/19/13 12:26 PM
06/19/13 12:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The speedo drive gear on the output shaft is after any OD gearing so the pinion calculations will be the same as a 1-1 top gear trans.
Look in the hole where the adapter fits and mark one drive gear tooth with a grease pencil, then turn the output shaft and count the number of drive gear teeth.
Re: truck 5 speeds? [Re: John_Kunkel] #1447179
06/19/13 02:10 PM
06/19/13 02:10 PM
dogdays Offline
dogdays  Offline
It's no car transmission, but it shifts a heck of a lot better than an SM 465 or my NP420 or the NP435 behind the 400 in my $500 ford truck.
It's a brute of a transmission. don't drop it on your foot!
The links I sent you have the three recommended transmission fluids, possibly they can be mail ordered?
I looked at the gear splits and for my purposes an NP445 or NP4530 would work better. Running 3.23s and a 32" rear tire I do not need overdrive, but it would be useful to be able to drop a gear and not have the engine screaming along at 4500rpm.
R.
Re: truck 5 speeds? [Re: dogdays] #1447180
06/19/13 11:58 PM
06/19/13 11:58 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
if you google---- jeep dodge speedo gears---there is a site with the speedo gear calculations for most axle ratios....bob
Re: truck 5 speeds? [Re: savoy64] #1447181
06/20/13 12:27 AM
06/20/13 12:27 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
check fifthgearrepair.com for the simplest/cheapest way to fix the fifth gear---it is a simple process that an average mechanic can do in less than one hour---the only failures i have heard about are cummins powered units where the tranny is lugged under load in fifth gear--chev 454 and dodge V10 ones dont have the 5th gear issue so i wouldnt suspect your motor will take it down...bob
Re: truck 5 speeds? [Re: savoy64] #1447182
06/20/13 09:08 AM
06/20/13 09:08 AM
I agree, i have read the same thing on the 4500HD lugging/diesel/v-10/4x4 5th gear loss.
I read the 5thgearrepair link and it seems to be for the 4500HD 4x4 10/31 input/output spline only.
I am hoping the 4500LD = light duty with a 19 spline input and a 29 or 30 spline output.(I need to count output,I counted the input )
it decodes to a 3.9/5.2/5.9 gas engine so it may be good to go with no problems, it is low milage under 100,000.
Re: truck 5 speeds? [Re: scratchnfotraction] #1447183
06/20/13 11:14 AM
06/20/13 11:14 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
2 guys garage had a show on how to fix the cummins 5th gear nut and they had plenty of time for 20 minutes of commercials....bob
Re: truck 5 speeds? [Re: savoy64] #1447184
06/21/13 01:21 AM
06/21/13 01:21 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
My truck has an nv4500, mine shifts very smooth. It's not a short throw like a car, but other than some newer 6 speed trucks I drove... it's the smooth shifting trans I ever shifted.
On the fluid, I'd stick with the factory stuff. Amsoil I believe makes a substitute, but to save 4-5 bucks a quart, think I'd pass. Some places offer the factory style stuff in gallons for much cheaper... but never seem to have any on stock.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: truck 5 speeds? [Re: Silver70] #1447185
07/09/13 10:35 PM
07/09/13 10:35 PM
got pics of the shifter end for a a535 trans. whoo hooo!
member shortbed88 has a complete D-100 hydro clutch a535 set up, he was nice enuff to pull the shifter and get me pics.
this is a gold nugget shifter if anyone finds one.
the flats on the side of the ball with no plastic cup sets it apart, it has a thin middle rail 3-4 gear 1-2 ans r-5 gears are the bigger lugs on either side of 3-4 rail.
pics are worth a 1000 words when it come to this sort of thing. not many have heard of the a535 much less seen or worked on one.
Re: truck 5 speeds? [Re: scratchnfotraction] #1447186
07/09/13 10:40 PM
07/09/13 10:40 PM
2x
Re: truck 5 speeds? [Re: scratchnfotraction] #1447187
07/09/13 10:41 PM
07/09/13 10:41 PM
x3
Re: truck 5 speeds? [Re: scratchnfotraction] #1447188
07/09/13 10:41 PM
07/09/13 10:41 PM
x4
Re: truck 5 speeds? [Re: scratchnfotraction] #1447189
07/09/13 11:28 PM
07/09/13 11:28 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i'm working on it. maybe i'll pull the right one, this time.
Re: truck 5 speeds? [Re: Golden-Arm] #1447190
07/09/13 11:35 PM
07/09/13 11:35 PM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
I scored a 4500 back as well. Was put behind a V6 in an '88 I had. Are there any other non-hydro bells it will bolt up to? I got the hydro bell and slave set but my '78 Club Shortbox I got back will need the mech. linkage.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Page 4 of 4 1 2 3 4
