Page 1 of 3 1 2 3
Offset grinding RB crank for a Lowdeck stroker #1446983
06/03/13 05:27 PM
06/03/13 05:27 PM
Delray beach, Florida
P
Performance Only Offline OP
P
I do quite a bit of this. The crank I started with was brand new and a relatively inexpensive Import. This is just the roughing in process of the rod and main journals. I already ground the counterweights down to 7.240 diameter. I'll try to get some pictures of the finished journals tomorrow.
By the way, the stroke on the crank as delivered varied by more than .004"
When it's finished the stroke will be within .001" and the index will be corrected.
machine shop owner and engine builder
Re: Offset griding RB crank for a Lowdeck stroker [Re: Performance Only] #1446984
06/03/13 05:28 PM
06/03/13 05:28 PM
P
P
2nd look
Re: Offset griding RB crank for a Lowdeck stroker [Re: Performance Only] #1446985
06/03/13 05:29 PM
06/03/13 05:29 PM
A gulag near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
A gulag near you.
What company makes a stepped bearing to fit that journal ?
Re: Offset grinding RB crank for a Lowdeck stroker [Re: Performance Only] #1446986
06/03/13 05:30 PM
06/03/13 05:30 PM
P
P
3rd look
Re: Offset grinding RB crank for a Lowdeck stroker [Re: Performance Only] #1446987
06/03/13 06:05 PM
06/03/13 06:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats a lot of material to take off... didnt want to
off grind it for more stroke
Re: Offset grinding RB crank for a Lowdeck stroker [Re: MR_P_BODY] #1446988
06/03/13 07:32 PM
06/03/13 07:32 PM
P
P
If you look a little bit closer at the 2nd picture you'll see that most of the material is coming off of the bottom side of the journal. In other words, yes, the stroke is also being changed. here's another view.
Re: Offset grinding RB crank for a Lowdeck stroker [Re: Performance Only] #1446989
06/03/13 07:37 PM
06/03/13 07:37 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
How many hours does this take?
Sheldon
Re: Offset grinding RB crank for a Lowdeck stroker [Re: Performance Only] #1446990
06/03/13 08:11 PM
06/03/13 08:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Got ya.. I didnt see that
Re: Offset grinding RB crank for a Lowdeck stroker [Re: Performance Only] #1446991
06/03/13 08:11 PM
06/03/13 08:11 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Thinking about offset grinding a fresh 413 crank for a 400 block.
Is it a similar process?
What's a rough cost to get the counterweights cut & the journals offset?
Re: Offset grinding RB crank for a Lowdeck stroker [Re: Performance Only] #1446992
06/03/13 08:14 PM
06/03/13 08:14 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Ive always wanted to do that with an OEM 440 forged crank I have to fit it in my 400 block....
Does it take any special equipment to do that? Or can it be done in the same machine used to machine cranks to undersize journals, which is standard operation in any machine shop?
Re: Offset grinding RB crank for a Lowdeck stroker [Re: 80fbody] #1446993
06/03/13 08:29 PM
06/03/13 08:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Pettis found my 3.900 stroke 413 crank here locally and it was only about $250-$300 iirc not sure on labor though to have it done..........
Re: Offset grinding RB crank for a Lowdeck stroker [Re: MR_P_BODY] #1446994
06/03/13 08:51 PM
06/03/13 08:51 PM
You got a little red paint on your glasses Mike???
Re: Offset grinding RB crank for a Lowdeck stroker [Re: domingo] #1446995
06/03/13 08:56 PM
06/03/13 08:56 PM
P
P
Special equipment? I guess that depends on how you look at it. Considering what crankshaft grinders cost I consider mine kind of special.
Some people like to turn down the counterweights in a lathe. Either way you do it it's a time consuming process to do the whole job.
I highly recommend if your going to do this with a factory crank, make sure to have it magnafluxed first.
Re: Offset grinding RB crank for a Lowdeck stroker [Re: Performance Only] #1446996
06/03/13 08:59 PM
06/03/13 08:59 PM
Can't wait to see mine done.
Re: Offset grinding RB crank for a Lowdeck stroker [Re: ] #1446997
06/03/13 09:01 PM
06/03/13 09:01 PM
P
P
You want me to grind it like this one?
Re: Offset grinding RB crank for a Lowdeck stroker [Re: Performance Only] #1446998
06/03/13 09:06 PM
06/03/13 09:06 PM
4.625 man...........4.625.......
Re: Offset grinding RB crank for a Lowdeck stroker [Re: ] #1446999
06/03/13 11:38 PM
06/03/13 11:38 PM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
thats my billet crank from moldex
Re: Offset grinding RB crank for a Lowdeck stroker [Re: Performance Only] #1447000
06/03/13 11:58 PM
06/03/13 11:58 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
for sure,
When you do this on an OEM crank, how do you end up finishing the fillets? Do they end up having radiused fillets??
Re: Offset grinding RB crank for a Lowdeck stroker [Re: domingo] #1447001
06/04/13 12:27 AM
06/04/13 12:27 AM
P
P
for sure,
Since OEM cranks have an undercut radius there isn't usually much of a radius when they're done. I've done a couple of them where I welded the radius first to narrow the rod throws and then did the grind to reduce the side clearance for GM width rods. I can't say if it helped with strength or longevity but they're still out there running.
Re: Offset grinding RB crank for a Lowdeck stroker [Re: Performance Only] #1447002
06/04/13 08:00 AM
06/04/13 08:00 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Nice work Dan A crank sure grinder is a special piece of equipment..... the operator is also "special"
In all seriousness though geometry, sizes, surface finish, balance and I'm sure many other things have to be taken into account before the first stone touches the crank.
When I had my stocker crank index ground here locally. The crank was so far off on index it removed all of the rolled radius in one area of a rod throw
It's been surviving though
Page 1 of 3 1 2 3
