Re: Offset grinding RB crank for a Lowdeck stroker
[Re: Performance Only]
#1447003
06/04/13 08:10 AM
06/04/13 08:10 AM
Posts: 10,173 Frostbitefalls MN (Rocky&Bullw...
gregsdart
How far are you willing to go on reducing crank pin size to gain stroke? At some point (2.100, 2.00, 1.889,) there is a loss of strength that is too much. My one shot at a 2.100 size to get 4.00 stroke lived quite a while at 600 hp, 2100 bob weight, 6200 rpm. That was an RB with custom aluminum rods. Without having much experience, I would assume it would be application specific.
[Re: TrWaters]
#1447005
06/04/13 09:17 AM
06/04/13 09:17 AM
gregsdart
Yep. The stock oil holes in the rod journals get out to one side a ways! What else? I suppose the internal passege may get too close to the radius, weakening it?
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#1447006
06/04/13 10:17 AM
06/04/13 10:17 AM
Posts: 3,547 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I recently saw both a SBC and a SBF circle track motor, that the jouranals were ground down to Honda size, and they broke. These are asphalt speedway deals, and only about 400HP 2 BBL motors. Whats funny is they are not allowed to do this, so when they broke, some people found out that they were cheating...double whammy,.....
RIP Monte Smith
[Re: CompWedgeEngines]
#1447007
06/04/13 10:38 AM
06/04/13 10:38 AM
Posts: 2,091 Delray beach, Florida
Performance Only
That doesn't surprise me in the least. Those cranks just don't have enough material to go that far. I bet they learned a valuable lesson. Even on a BB mopar crank, there are limits on how far I'll move the stroke. Back when I was doing the welded strokers from OEM cranks they were pretty strong and would hold up to 700 HP and 7500 rpm for many years of service. anything above that back in the day IMO really wasn't worth attempting. 3.75 to 4.15 was a real common one to do although I did do some out to 4.25. With the availability of decent and inexpensive 4340 cranks available now, why bother with that stuff.
machine shop owner and engine builder
#1447009
06/04/13 11:19 AM
06/04/13 11:19 AM
Posts: 1,653 westerly, ri. usa
440lebaron
westerly, ri. usa
just had my 4.15 mopar/scat crank done to 4.25 2.20 chev rod, what are you folks doing about .060/.070 side clearance, some people leave it alone?
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#1447010
06/04/13 11:20 AM
06/04/13 11:20 AM
Posts: 9,679 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
thats way too much clearance! I think they sell rods with a chevy journal size and mopar width
[Re: domingo]
#1447011
06/04/13 11:32 AM
06/04/13 11:32 AM
Triple Threat
Renton Washington
Side clearance isn't an issue as long as you have some. The oil hole in the crank is the restriction.
There are countless engines running around with way more than the factory specified side clearance.
[Re: Triple Threat]
#1447012
06/04/13 11:37 AM
06/04/13 11:37 AM
domingo
EL Master
EL Master
Lima, Peru
.009" to .017" is whats specified from the factory. I would tend too think 0.07" is too much....I bet you would have lots of oil flying around and getting excessive oil on the cilinder walls, leading maybe to oil control issues with the rings, specially if running low tension oil rings????....
[Re: domingo]
#1447013
06/04/13 11:51 AM
06/04/13 11:51 AM
Triple Threat
Renton Washington
Do a search, there are dozens of threads about side clearance with Chevy rods.
https://board.moparts.org/ubbthreads/show...mp;Main=5697177 https://board.moparts.org/ubbthreads/showflat.php?Number=4983215
Trying not to hijack Dan's thread here, as these are some of my favorite posts. I wish there was more of them.
[Re: domingo]
#1447014
06/04/13 11:51 AM
06/04/13 11:51 AM
Posts: 44,090 Bend,OR USA
Cab_Burge
My Duster motor had from .054 to .032 rod side clearances, it also had .0033 to .0035 rod bearing clearances. I never saw smoke, used oil or had any other issues with to much oil on the cylinder walls The rod bearing clearances dictate how much oil gets out of them, not the rod side clearances I did use a crank scraper in that motor to start with The last crankshaft in that motor started out as a six bolt flange forged import that was 4.150 stroke with Mopar rod journal sizes, I had it offset to 4.300 stroke with 2.200 (BB Chevy) rod journal sizes I have three more 4.150 stroke cranks with Mopar rod journal size throws on them that will get offset stroked like that also As far as costs of grinding and reheat treating check with your local shops first before deciding, it may be cheaper to buy the stroke you want to start with , maybe not depending on how much you pay for the cranks to start with
[Re: Cab_Burge]
#1447016
06/04/13 12:27 PM
06/04/13 12:27 PM
domingo
EL Master
EL Master
Lima, Peru
...and I was worrying because I had like 0.025" side rod clearance on one jouurnal on a stock 383 I just rebuilt... ... well, one less thing to worry about now!!!
[Re: dogdays]
#1447018
06/04/13 01:21 PM
06/04/13 01:21 PM
Performance Only
Dan, I'm pricing a 1.850 rod stroker Olds smallblock for a '65 Cutlass S that I've owned since 1977. (there aren't any olds stroker cranks that I know of). What would be a ballpark price for you to grind mains to standard undersize and offset grind 2.125" rod journals to 1.850"? Here, I'm looking at $400 or so. The guy does custom work on an italian crank machine. It sounds pretty fair to me. What to look out for? Thanks, R.
$400.00 dollars is a very fair price for quality work IMO. The most important thing is the guy doing the work, Not the machine he's doing the work with unless it's a worn out pile of scrap. It's real easy to mess up the indexing when your taking a lot off of the journals. On top of that, some cranks will relax and loose their straightness. That's an easy fix if you know what your doing and do things in the right order. In other words, it's just a little bit more involved than just grinding some metal if you want it done right.
#1447021
06/04/13 01:53 PM
06/04/13 01:53 PM
Posts: 27,196 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
I'm curious, when plunge grinding like that how much do you infeed at a time?
#1447022
06/04/13 02:28 PM
06/04/13 02:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've had only one crank re-nitrided.. with the work and the nitriding was like $400.. that was one of my billet cranks.. I havent seen any difference if it wasnt done
