Re: LET`S TALK AERODYNAMICS....................
[Re: 3ddart]
#1446820
06/04/13 10:12 AM
06/04/13 10:12 AM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
off topic, but yer lookin fer speed, right? I would look into a taller sixpack style scoop, if you are willing to consider it. I don't know exactly how much it is worth, but there are scoops built two inches higher to get above the boundry air layer better.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#1446821
06/04/13 10:25 AM
06/04/13 10:25 AM
Posts: 52,972 Romeo MI
MR_P_BODY
To find out if he needs more air he can tape some cardboard to the front of the scoop to bring the inlet to the front of the hood... with the top edge of the inlet a bit longer on the top to hang out just a bit.. seal it to the hood... that will pick up more air ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1446822
06/04/13 10:48 AM
06/04/13 10:48 AM
Posts: 452 nc
cold85
nc
lower block off between valance and add a chin spoiler mine is off a 68 camaro
![](http://i44.photobucket.com/albums/f30/cold85/031.jpg)
[Re: cold85]
#1446823
06/04/13 11:11 AM
06/04/13 11:11 AM
Posts: 1,532 off the grid
340B5
off the grid
I keep looking under mine thinking....'what catches air".... Ever see those little wings in front of the rear fuel dragster tires?
And then there are those air deflectors you see on the side of a few semi trailers nowadays.
Yeah, it's got a smallblock.
[Re: gregsdart]
#1446826
06/04/13 01:05 PM
06/04/13 01:05 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Make a belly pan to go under the car, from the core support to as close to the firewall as you can, put a flat panel in front of the grill and headlights, you can do that with clear plex, and you will still see both the headlights and grill. Cover the area under the bumper to the volance, let the radiator get it's air from in front of the core support.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Thumperdart]
#1446828
06/04/13 01:40 PM
06/04/13 01:40 PM
Posts: 4,594 Motor City
6PKRTSE
Motor City
My buddies 68 Drag Radial Chevelle runs 7:60's at 165+ in the quarter & we had a starting line incident one time when the car didn't start. The other guy waited patiently for us to get started. Once the track official gave him the go & we finally got it started we did not have enough time to get the removeable deck lid & wing installed & made a pass anyway without them. We won the race & went 2 MPH faster than it ever has. Made me a believer that all of these big wings on the back make no difference. The car is not at speed long enough to notice.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1446829
06/04/13 01:43 PM
06/04/13 01:43 PM
Thumperdart
State of confusion
This is interesting............ ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Makes me almost want to do NOTHING to my heap...............
[Re: Thumperdart]
#1446830
06/04/13 01:54 PM
06/04/13 01:54 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Same as cold85 here.
69 camaro spoiler...~$30 from summit, and made some tubing braces for it. No ET change, but made it feel a whole lot better over 100mph
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Duner]
#1446833
06/04/13 02:23 PM
06/04/13 02:23 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Even if aero doesn't come into play until after 100 mph - that's still the second half of the track for most everybody that's interested in it.
At 38.5 square feet of frontal area I can tell you I can definately see and feel a difference even at 60mph.Dave ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Duner]
#1446834
06/04/13 02:44 PM
06/04/13 02:44 PM
Posts: 43,367 Bend,OR USA
Cab_Burge
I use to go out to the SCTA (Bonniville top speed racers) races at El Mirage dry lake and talk to some of those racers, there thoughts that aerodynamics didn't come into play under 125 MPH on thier course, one mile running start and timed for a short distance after that At the Salt Flats the course was a lot longer and a lot of the racers would say that anybody can run 125 MPH, some can run 150 MPH and after that(150+ MPH) it is way better to reduce drag than to hop up the motor, they even siad that it took twice the HP to from 150 MPH to 175 MPH I know some formula one airplane racers that basically say the same thing, work on smoothing and reducing the aerodynamic drag to go faster above 150 MPH ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Cab_Burge]
#1446835
06/04/13 03:48 PM
06/04/13 03:48 PM
MR_P_BODY
I have watched a lot of wind tunnel testing at work and seen my problem when I hit 130 mph. at that point the rear of my car started lifting off the ground.. the rear spoiler/wing made a BIG difference... it made the car stable and picked up 3 mph with just the wing.. I was spinning on top end but didnt know it till I lost control with a 15 mph head wind(which just adds to what your car thinks its going)... but my car is a hatch back with a short trunk area... it was sucking the car upward... non of these cars were tested above about 120 mph... thats the reason all of the prostocks and other QUICK cars test in the tunnel ![](/ubbthreads/images/graemlins/wave.gif)
