Re: Oil adapter to 90 degree Help!
[Re: RapidRobert]
#1446484
06/09/13 01:46 PM
06/09/13 01:46 PM
Posts: 15,487 Florida
scratchnfotraction
Me too. I suffer from ADD (all day drama) & IDGAF (I dont give a fxxx). Slip the thin one on the bolt & lodge it under the bolt head. Then insert the bolt (with the thin washer on it) into the adapter. Then on the other side add the thick cork washer to the threaded end of the bolt that protrudes from the concave face on the inside. Make sure the block circular recess is cleaned of all gasket material. Torque on the big bolt is 50 lbs (cleaned/lightly oiled threads) EDIT The thin one goes next to the bolt head (outside). The other thin one (thick cork) goes on the bolt on the (inside) AFTER you insert the bolt/thin washer into the adapter. Then the large circular gasket as you know goes in the block circular recess.
thin gasket,cork gasket,block gasket
[Re: scratchnfotraction]
#1446486
06/09/13 02:02 PM
06/09/13 02:02 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
no man, thats what they call a 16 yr old virgin. LOL ^
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
