our latest project car. 2008 chally!
#144470
11/01/08 10:10 PM
11/01/08 10:10 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
car has about 900 miles on her. love the color and man the interior is about as nice as anything i have been in. car is in for some mods that include a new long block in the 426 inch area. based off the stock 6.1 block. heads are almost done. moving about 400 cfm peak at this point with a 2.100 intake and 1.59 exhaust. will have a converter/exhaust/intake also. she is fully coated with polydyn coatings. so i am expecting some decent numbers from this one. last one made 610/645 and was uncoated. here is some eye candy http://digitalremix.net/upload/uploads/3/FRI%20Grand%20Opening/FRI%20Stuff/20081027-DSC_0961.jpg
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: our latest project car. 2008 chally!
[Re: gremlinsteve]
#144471
11/01/08 10:11 PM
11/01/08 10:11 PM
gremlinsteve
houston texas
hope to hit the track soon with this one.
steve
[Re: 340RICK]
#144477
11/03/08 11:46 PM
11/03/08 11:46 PM
gremlinsteve
houston texas
me too. this should be one hell of a build.
steve
[Re: AlexP]
#144478
11/04/08 01:12 AM
11/04/08 01:12 AM
Posts: 12,013 Finally a HUSKER again
Moparnut426
We pulled the engine out last night and it's off with our builder as of noon today.
Some body has better funding than Ill EVER have!!
![](/ubbthreads/images/graemlins/drool5.gif)
[Re: Moparnut426]
#144479
11/17/08 02:26 PM
11/17/08 02:26 PM
gremlinsteve
houston texas
motor is back in. heads are finished. most parts will be back in/on in a day or so.
steve
[Re: bigsbigelow]
#144481
11/17/08 03:19 PM
11/17/08 03:19 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Pictures?
Am I seeing that right? the converter is held on with 3 bolts?
[Re: DJVCuda]
#144482
11/17/08 03:28 PM
11/17/08 03:28 PM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
Now that is a true Mopar racer/motorhead! Get a new car , pull the motor out and start modifying it, Cool!
[Re: DJVCuda]
#144484
11/17/08 04:19 PM
11/17/08 04:19 PM
Posts: 1,091 Col. Ohio
The Avg. Valiant
Col. Ohio
Pictures?
Appears to be 6, 2 2 2 pretty close together though if you ask me.
Post deleted by Defbob
[Re: Quicksilver440]
#144486
11/17/08 06:57 PM
11/17/08 06:57 PM
[Re: AlexP]
#144489
11/18/08 05:33 PM
11/18/08 05:33 PM
gremlinsteve
houston texas
last one made 620 on a mild 218/224 cam... im only looking for 550 or so at the wheel on this one. drivetrain eats up about 18 percent. so that would or should be around 650 or so. cam is still mild...this is a computer friendly design. 223/227 .577 lift 114 lsa
heads move air. those numbers where on our bench. you know how that can change. stock they where in the 330 range.
i also agree...needs a good turbo kit.
converter uses pairs of two bolts. total of 6.
converter used is a reworked stock case. case is an unuasual shape and ois about 9.5 inches in diameter...stock. internals are differant. about 2800 stall.
converter is alot deeper than a normal converter you might be used to seeing.
steve
steve
