Re: What a piece of #%^&^%^&& Hurst Pro Matic [Re: scratchnfotraction] #1444567
05/31/13 11:11 PM
05/31/13 11:11 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
mine came with a shorter arm that could fit on but it does not have the D-slot to aline it on the VB shaft.
maybe that could be clamped tight after the shifter cable is installed and both shifter and trans in N detent.
like I siad,i get to the point you are at. i can get it to either up shift correct and not down shift. or down shift correct but not up shift correctly.
if you seem to think a short arm moveing the cable end in closer to the trans case will work maybe I will swap the arm out on mine and try 1 more time.
Mike, it is quite frustrating to say the least; it should be a fool proof setup to perform as advertised, but not the case in our cases. I'll drive it tomorrow and see what happens; I am not looking for it to be OK on both ends.
Re: What a piece of #%^&^%^&& Hurst Pro Matic [Re: Hemi_Ram] #1444568
06/01/13 12:02 AM
06/01/13 12:02 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The shorter arm fits a Ford trans
Like Larry said on the adjustment is what I do on them & have for over 35 years now.
I have found this to be the only way to do an aftermarket shifter on anything.
Try flipping the lever over & adjusting this way sometimes the chinese hole is offset a little
Turbo Action is always perfect as is TCI
I've used in some of my rides Hurst Quarter Stick,B&M Pro-Ratchet & of course the Hurst stick like used in the SS A-Bodies
Re: What a piece of #%^&^%^&& Hurst Pro Matic [Re: BulletBob] #1444569
06/01/13 12:29 AM
06/01/13 12:29 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Promatics Mopar lever has the D shape. If the one you used doesn't then it's not the correct lever.
Re: What a piece of #%^&^%^&& Hurst Pro Matic [Re: stumpy] #1444570
06/01/13 01:48 PM
06/01/13 01:48 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
stumpy, I have the "D" shaped hole lever and it is the supplied #27 dogleg lever. Here's a pix
Re: What a piece of #%^&^%^&& Hurst Pro Matic [Re: Hemi_Ram] #1444571
06/01/13 01:49 PM
06/01/13 01:49 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
another view
Re: What a piece of #%^&^%^&& Hurst Pro Matic [Re: Hemi_Ram] #1444572
06/01/13 06:29 PM
06/01/13 06:29 PM
Grand Prairie,Texas
Grand Prairie,Texas
I was refering to Scratchns post. Sorrry for the confusion. But as I said earlier I always adjust mine for neutral.
Re: What a piece of #%^&^%^&& Hurst Pro Matic [Re: Hemi_Ram] #1444573
06/01/13 10:59 PM
06/01/13 10:59 PM
scratchnfotraction Offline
another view
I have mine droping down into the lever from the top,I see you have it sticking up thru the lever. but we both are getting the same results.
I am using the D-hole lever also,I mentioned the round hole lever thinking it could be clocked a little either way to make up for the slack.
it dod not work for me today,I put the D-hole lever back on and adjusted mine out in N again..same results
i can get it to shift one way but not the other, even slapping it rather hard against the shift gate/ratchet system.
yep,i am going back to mech linkage/colum shift. i have adjusted this crap shifter for the last time as of today. another hour I dont get back.
Re: What a piece of #%^&^%^&& Hurst Pro Matic [Re: scratchnfotraction] #1444574
06/02/13 12:42 AM
06/02/13 12:42 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Mike, I'll let you know how the final adjustment works; I am not very positive on the results. Have a card with the shifter to the tech line and I am going to give them a call if this does not work.
Re: What a piece of #%^&^%^&& Hurst Pro Matic [Re: Hemi_Ram] #1444575
06/04/13 12:25 AM
06/04/13 12:25 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Well, I went to get a bung welded in for a AFR probe today; the shifting is a bit better, but you have to bang shift it to ensure positive engagement. Not a positive feeling but I will live with it for a while until I find a better shifter or solution. On a positive note I visited my favorite muffler shop and Craig welded in a bung for my AFR probe and he mentioned that my 512 Stroker would be better suited for an A or B body car; I told him that the wow factor is a lot better when an old man like me is driving a POS truck and a Mustang is going to pass me and I get on the throttle and shut him down to the point he turns off and the next intersection. He agreed.
