Page 2 of 3 1 2 3
Re: Will a PCV help condensation in Alum. Blk.? [Re: Hemi Allstate] #1444237
05/30/13 06:35 PM
05/30/13 06:35 PM
Az
Crizila Offline
Crizila  Offline
Az
Installing a PCV system will definitely help with the moisture problem. I would run one on the street for sure.
Fastest 300
Re: Will a PCV help condensation in Alum. Blk.? [Re: Crizila] #1444238
05/30/13 08:06 PM
05/30/13 08:06 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Plenty of fresh engines I've run on the dyno seem to have condensation issues for the first 30 minutes or so of run time. They always seem to clear up after a few pulls though as does the visible blowby past the breathers as the rings seat to the cylinders. Maybe you just haven't driven it enough?
Re: Will a PCV help condensation in Alum. Blk.? [Re: an8sec70cuda] #1444239
08/08/13 10:46 AM
08/08/13 10:46 AM
Mt. Eden Ky.
Hemi Allstate Offline OP
Mt. Eden Ky.
Well here is a pic of the condensation on the inside of the valve cover and the "K/B Stack.
What PCV valve would be a good choice? As in what application would I buy one for?
I ran the car at the track for TNT, and hot lapped it. Got too hot on the last pass. I sure didn't expect to see this mess inside!
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Will a PCV help condensation in Alum. Blk.? [Re: Hemi Allstate] #1444240
08/08/13 10:47 AM
08/08/13 10:47 AM
Mt. Eden Ky.
Mt. Eden Ky.
#2
1996 Ram 1500 Sport
1968 road runner
Re: Will a PCV help condensation in Alum. Blk.? [Re: Hemi Allstate] #1444241
08/08/13 10:48 AM
08/08/13 10:48 AM
Mt. Eden Ky.
Mt. Eden Ky.
#3
1996 Ram 1500 Sport
1968 road runner
Re: Will a PCV help condensation in Alum. Blk.? [Re: Hemi Allstate] #1444242
08/08/13 10:49 AM
08/08/13 10:49 AM
Mt. Eden Ky.
Mt. Eden Ky.
#4
1996 Ram 1500 Sport
1968 road runner
Re: Will a PCV help condensation in Alum. Blk.? [Re: Hemi Allstate] #1444243
08/08/13 11:23 AM
08/08/13 11:23 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Looks like 'leak down' and 'pressure test' of cooling system time to me. That's alot of moisture. You are running gas right..??..not alky.
If you like drag racing, support your local track.
Re: Will a PCV help condensation in Alum. Blk.? [Re: CHAPPER] #1444244
08/08/13 11:31 AM
08/08/13 11:31 AM
Mt. Eden Ky.
Mt. Eden Ky.
Yes it is gas. I can pressure test the system no problem. But I have had antifreeze in it and the moisture appears clear?
1996 Ram 1500 Sport
1968 road runner
Re: Will a PCV help condensation in Alum. Blk.? [Re: Hemi Allstate] #1444245
08/08/13 11:41 AM
08/08/13 11:41 AM
an8sec70cuda Offline
Looks like a lot of moisture to me. Isn't that a KB block? Did you get the head gaskets from KB?
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Will a PCV help condensation in Alum. Blk.? [Re: an8sec70cuda] #1444246
08/08/13 11:54 AM
08/08/13 11:54 AM
Mt. Eden Ky.
Mt. Eden Ky.
No Chip, it's a World block . I am using Cometic gaskets.
Cooling System is holding 15 lbs.
Re: Will a PCV help condensation in Alum. Blk.? [Re: Hemi Allstate] #1444247
08/08/13 01:13 PM
08/08/13 01:13 PM
OK, I couldn't remember. Have you drained/checked the oil to see how much water, if any, is in the pan? No bubbles in the radiator?
I hope it's just condensation, it could be, but it sure looks like a lot to me.
If it isn't putting water in the pan, I'd go drive the snot out of it and then look again.
CHIP
Re: Will a PCV help condensation in Alum. Blk.? [Re: an8sec70cuda] #1444248
08/08/13 01:53 PM
08/08/13 01:53 PM
Mt. Eden Ky.
Mt. Eden Ky.
Chip
The last time I drained the pan, the oil was milky, but no water sepperated to the bottom. I am going to drain it again and see what I have now.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Will a PCV help condensation in Alum. Blk.? [Re: Hemi Allstate] #1444249
08/08/13 02:01 PM
08/08/13 02:01 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Cometic gaskets.. Is the motor HOT when you are checking??
Re: Will a PCV help condensation in Alum. Blk.? [Re: CHAPPER] #1444250
08/08/13 02:03 PM
08/08/13 02:03 PM
Mt. Eden Ky.
Mt. Eden Ky.
No, right now it is dead cold.
1996 Ram 1500 Sport
1968 road runner
Re: Will a PCV help condensation in Alum. Blk.? [Re: Hemi Allstate] #1444251
08/08/13 04:47 PM
08/08/13 04:47 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I had a all aluminum hemi yrs ago, my breathers never looked like that. I did run a pcv valve though. I'd hook 1 up, chg oil & see if that helps.
Re: Will a PCV help condensation in Alum. Blk.? [Re: rickraw] #1444252
08/08/13 05:27 PM
08/08/13 05:27 PM
Mt. Eden Ky.
Mt. Eden Ky.
I have changed oil 3 times in less than 20 miles and three 1/8th mile test passes.
I am concerned that if it is antifreeze, my bearings will be toast.
I cannot confirm it, but I think the rad. level may be down some. No oil in radiator.
Radiator Pressure tester drops from 18 psi to 15 psi in about 1/2 hr.
Oil is cloudy and brown.
What should I test next? Is there a "test strip" for the oil to test for antifreeze?
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Will a PCV help condensation in Alum. Blk.? [Re: Hemi Allstate] #1444253
08/08/13 08:08 PM
08/08/13 08:08 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Try a leak down test. We test trans fluid where i work with a glycol test kit. Works with motor oil to. Do a google search, might be able to have 1 shipped to u.
Re: Will a PCV help condensation in Alum. Blk.? [Re: rickraw] #1444254
08/08/13 09:21 PM
08/08/13 09:21 PM
Mt. Eden Ky.
Mt. Eden Ky.
Thanks for the info on the test kit.
It seems to me if it was just water in the oil pan, it would have sepparated and the water would be on the bottom of the pan. Not so.
I have used a leak down to check ring seal, but not to find a coolant leak? Is this just for head gasket to cylinder leakage?
1996 Ram 1500 Sport
1968 road runner
Re: Will a PCV help condensation in Alum. Blk.? [Re: Hemi Allstate] #1444255
08/09/13 12:16 PM
08/09/13 12:16 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
A leakdown test will also show any leakage in the cooling system. Do it with a hot engine. Check each clyinder on tdc. If ur low on coolant, it has to be going somewhere. If ur using antifreeze, the glycol test won't lie.
Re: Will a PCV help condensation in Alum. Blk.? [Re: rickraw] #1444256
08/09/13 01:05 PM
08/09/13 01:05 PM
Mt. Eden Ky.
Mt. Eden Ky.
Well,
It is antifreeze for sure.
Now to look at the bearings and see what damage is done, and try to find the leak
Thanks,
MARK
1996 Ram 1500 Sport
1968 road runner
Page 2 of 3 1 2 3
