Re: Will a PCV help condensation in Alum. Blk.?
[Re: Hemi Allstate]
#1444237
05/30/13 07:35 PM
05/30/13 07:35 PM
Posts: 7,506 Az
Crizila
Az
Installing a PCV system will definitely help with the moisture problem. I would run one on the street for sure.
Fastest 300
[Re: an8sec70cuda]
#1444239
08/08/13 11:46 AM
08/08/13 11:46 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Well here is a pic of the condensation on the inside of the valve cover and the "K/B Stack. What PCV valve would be a good choice? As in what application would I buy one for? I ran the car at the track for TNT, and hot lapped it. Got too hot on the last pass. I sure didn't expect to see this mess inside! Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1444243
08/08/13 12:23 PM
08/08/13 12:23 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Looks like 'leak down' and 'pressure test' of cooling system time to me. That's alot of moisture. You are running gas right..??..not alky.
If you like drag racing, support your local track.
[Re: Hemi Allstate]
#1444245
08/08/13 12:41 PM
08/08/13 12:41 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Looks like a lot of moisture to me. Isn't that a KB block? Did you get the head gaskets from KB?
[Re: an8sec70cuda]
#1444246
08/08/13 12:54 PM
08/08/13 12:54 PM
Hemi Allstate
Mt. Eden Ky.
No Chip, it's a World block . I am using Cometic gaskets.
Cooling System is holding 15 lbs.
[Re: Hemi Allstate]
#1444247
08/08/13 02:13 PM
08/08/13 02:13 PM
an8sec70cuda
OK, I couldn't remember. Have you drained/checked the oil to see how much water, if any, is in the pan? No bubbles in the radiator? I hope it's just condensation, it could be, but it sure looks like a lot to me. If it isn't putting water in the pan, I'd go drive the snot out of it and then look again.
[Re: an8sec70cuda]
#1444248
08/08/13 02:53 PM
08/08/13 02:53 PM
Hemi Allstate
Mt. Eden Ky.
Chip The last time I drained the pan, the oil was milky, but no water sepperated to the bottom. I am going to drain it again and see what I have now. Mark
[Re: CHAPPER]
#1444250
08/08/13 03:03 PM
08/08/13 03:03 PM
Hemi Allstate
Mt. Eden Ky.
No, right now it is dead cold.
[Re: rickraw]
#1444252
08/08/13 06:27 PM
08/08/13 06:27 PM
Hemi Allstate
Mt. Eden Ky.
I have changed oil 3 times in less than 20 miles and three 1/8th mile test passes. I am concerned that if it is antifreeze, my bearings will be toast. I cannot confirm it, but I think the rad. level may be down some. No oil in radiator. Radiator Pressure tester drops from 18 psi to 15 psi in about 1/2 hr. Oil is cloudy and brown. What should I test next? Is there a "test strip" for the oil to test for antifreeze? Thanks, Mark
[Re: rickraw]
#1444254
08/08/13 10:21 PM
08/08/13 10:21 PM
Hemi Allstate
Mt. Eden Ky.
Thanks for the info on the test kit. It seems to me if it was just water in the oil pan, it would have sepparated and the water would be on the bottom of the pan. Not so. I have used a leak down to check ring seal, but not to find a coolant leak? Is this just for head gasket to cylinder leakage?
[Re: rickraw]
#1444256
08/09/13 02:05 PM
08/09/13 02:05 PM
Hemi Allstate
Mt. Eden Ky.
Well, It is antifreeze for sure. Now to look at the bearings and see what damage is done, and try to find the leak Thanks, MARK
