Re: Which is heavier, Gasoline or water?
[Re: fullmetaljacket]
#1443875
05/28/13 09:39 PM
05/28/13 09:39 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
specific gravity of gasoline is around... Gasoline, Vehicle 60oF 0.739 Specific gravity of water is 1.000 Gasoline will float on top of water...anything with a specific gravity of less then 1.00000 ..floats.. http://www.engineeringtoolbox.com/specific-gravity-liquids-d_336.html
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
#1443877
05/28/13 09:41 PM
05/28/13 09:41 PM
Posts: 1,978 USA
Suregrip391
USA
I'm no Chemical/liquid scientist, but I weighed a gallon of Poland Spring water today and the scale read 8.5 pounds. The Plastic container must not even tip the scales at an ounce or so. I've always heard that Gasoline weighs 6.5 pounds. Are they both different in weight because of their molecular structures?
All I know is that water weighs 8.34 pounds per gallon,
[Re: 696pack]
#1443882
05/28/13 10:10 PM
05/28/13 10:10 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
.......Water is the heavyist liquid on earth other than mercury......
???? I don't know if there are other qualifiers to this statement or not, but there are a bunch of liquids heavier than water.
[Re: BSB67]
#1443884
05/28/13 10:44 PM
05/28/13 10:44 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Not to mention, "liquid" is one of 3 forms of matter that a substance can be. H2O can be a solid (ice) liquid (water) or gas (steam).
And since density changes with temperature you must add a temperature as another qualifier. I have no idea what liquid oxygen weighs per gallon, but I can tell you that it's VERY cold. And at some point, mercury will freeze into a solid just as at some point, iron turns into a liquid.
**Photobucket sucks**
[Re: Supercuda]
#1443886
05/29/13 01:50 PM
05/29/13 01:50 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Some things "sublime" and skip from solid to gas without ever being a liquid like CO2. However, at a very high pressure and the correct temperature it could also become a liquid.
#1443890
05/29/13 05:26 PM
05/29/13 05:26 PM
RapidRobert
The occaisional water globules in my eddy carb bowl are always on the bottom, that's why I added a drain bung on my new A body gas tank, to deal with that (& switched gas stations)
[Re: Supercuda]
#1443891
05/29/13 05:59 PM
05/29/13 05:59 PM
Posts: 5,169 CT
GTX MATT
CT
There are four forms of matter, plasma being the fourth.
https://en.wikipedia.org/wiki/Plasma_%28physics%29
Where do ghosts/spirits fall into this?
According to Michio Kaku, they could be from another dimension, if they exist.
Do you think that because of their different specific gravities that they might experience time dilation at different rates, keeping the water fresher than gas, particularly if we were able to time travel? ![](/ubbthreads/images/graemlins/Dino2.gif)
