Re: Goodyear Polyglas tire date code
[Re: 52savoy]
#1443616
06/03/13 01:10 AM
06/03/13 01:10 AM
Posts: 17,563 Las Vegas, NV
6bblgt
Las Vegas, NV
I thought it might be..
Couldn't it be for an earlier Corvette also. Maybe a replacement tire from a Goodyear store in 1971?
Yes, Corvette started using that tire - nylon/F70-15 (Firestone & Uniroyal also) for the '68 model year (RWL in '69).
[Re: Big D A12]
#1443618
11/03/13 11:47 PM
11/03/13 11:47 PM
6bblgt
Las Vegas, NV
MJU2 DXA411
MJ = (plant) Topeka, KS Goodyear plant U2 = (size) F70-15 DXA = (type) nylon cord (SPEEDWAY) white stripe 411 = (date) 41st week of '71
This post has explained the plant and date for Goodyear tires well. What is missing is a chart of codes for the size and type of tire. If someone has such a chart, would you mind adding it to this post? Thanks.
What do you have? I've been collecting data to see if there is a way to reverse engineer any info from it.
..... but I'd need numerous examples to prove the "educated guesses" - one tire I've been looking for proof of is a Firestone Wide Oval pre-1970 that is fiberglass-belted.
[Re: 6bblgt]
#1443619
11/05/13 10:25 PM
11/05/13 10:25 PM
Posts: 305 Wisconsin
Big D A12
Wisconsin
The picture below is the spare from a 69 Bee. G70 x 15 Redline. Doesn't seem to match any info in this post. Any ideas on the code?
Thanks. D
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
[Re: Aero426]
#1443620
11/06/13 04:14 AM
11/06/13 04:14 AM
6bblgt
Las Vegas, NV
Older style (seven digit) decoder ring.
UN01B46
U = 1969 N = June 01 = Akron, OH (plant #1) B46 = ? #
[Re: 6bblgt]
#1443621
11/06/13 08:22 AM
11/06/13 08:22 AM
Big D A12
Wisconsin
Thanks for the reply Dan. I am slowly learning how to read these charts.
[Re: Big D A12]
#1443622
11/06/13 12:09 PM
11/06/13 12:09 PM
Posts: 5,271 NY
70440+6bbl
NY
Thanks. D
Here is the original spare tire from my A12. Almost identical codes.
[Re: 70440+6bbl]
#1443623
09/12/14 04:53 PM
09/12/14 04:53 PM
Posts: 273 ontario, canada
plumcrazy704406
ontario, canada
would a member mind decoding this for me please.
UK05A42
It is from my car and appears to never have left the trunk. all the markings are on it still even across the treads. If someone wants photos I can post.
This thought may not be politically correct, but is an opinion offered. It may be correct? or it may be wrong? It is not designed to appease those needing shelter from the real world.
[Re: 6bblgt]
#1443624
09/12/14 05:09 PM
09/12/14 05:09 PM
6bblgt
Las Vegas, NV
UK05A42
U = 1969 K = October 05 = Gadsden, AL A42 = serial/mold #
Sure we like pics, but what kind of car, what assembly plant, & size/style of tire? Also, got pics of the date on the wheel?
[Re: 6bblgt]
#1443625
09/12/14 06:55 PM
09/12/14 06:55 PM
plumcrazy704406
ontario, canada
tire is from my 70' Challenger RT, 16000 original miles Nov.69' build. B/C sheet says w23, road wheels. I will get a pic of the rim codes over the weekend. thx for the help Moparts! JS23: Dodge Challenger Special, R/T 2 Door Hardtop
V0B: 440 390HP 3-2BBL 8 CYL 1970 Dodge Main, Hamtramck, MI, USA
18660: Sequence number
[Re: plumcrazy704406]
#1443627
09/12/14 06:59 PM
09/12/14 06:59 PM
plumcrazy704406
ontario, canada
and last one. If you want more or something else close up, pm me your email and I will get the pics needed.
